Question about Mitsubishi WT-46809 46" Rear Projection Television
Blurred colors and bowing top and bottom
Perhaps this is the same convergence issue describe by others: Sometimes (not always) the picture bows top and bottom, the colors blur together and little, very fine electrical lines dart about. Will simply changing the bulb help? I am not adept at involved repairs involving soldering, etc. ow much would it cost to have it repaired by expert? Thanks.
    Sergeant:
  • 395 Answers
The problem is the convergance and would need to have the amps replaced. may be some resistors as well. the repair may cost $350.00 or so. there is no bulb inside just three CRTs which are no longer available for your set.
Posted on Mar 02, 2008
My rear projection television is showing a double picture with the blue out of allignment. It also shows a bow on the top and a bow on the bottom.
The tv have a problems known as a convergence problems,tv convergence board it is dead.Tv have R,G,B colors lines mis alignments,have colors pictures shadows or 3D pictures look alike?Yes.The tv convergence board it is dead.Must require replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv picture convergence problems.The tv shop,will cost u like $300-350 for parts and labors.
Apr 24, 2011 | Zenith IQC50H95W 50" Rear Projection...
Borders bowed inward,blurred red,blue, & green
the next time it is not working go into the customer menu with remote and call up the convergence grid and look---there---if convergence is way off and or comes and goes---this set uses 2 Stk-392-570 ic's and it is quite common to see them become intermittant.
Aug 03, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Bowing of picture at top and bottom towards center.
Projection sets have two very common problems outlined below.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can more info and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 12, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Colors have separated. and top and bottom af pictures are bowed. i have a sony kp-46s55. its about nini years old and it was free. currently the colors are separated and the top and bottom of the pict
nbad convergence ic , this need to be done by a profecional tv tech , because need to check for the pico fuse and resistor around the area
May 08, 2009 | Televison & Video
Phillips 55PW9363
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 24, 2008 | Philips 55PW9363 55" Rear Projection...
Problem with convergence
bad convergence ic's
Jan 03, 2008 | Philips Magnavox 9P6034C 60" Rear...
Trouble Aligning Colors
If the convergence is missing in the menu in screens,you have a bad reg ic on the convergence power supply the part number is 215530,the power supply is located on the black plastic above the right module with all the heat sinks
Nov 15, 2007 | RCA P56930BL 56" Rear Projection...
Rca d52w2052 d523c10df itc222
The issue is the Deflection board. The Fl1231 is open. The Deflection board needs replaced
Nov 11, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Help with bowing
Usually consumer described bowing is bad solder connects
on pins of convergence IC's. If the effort is made to pull the center PC board out,then replace both Stk392-570 IC's for
durability.
Note: V-Pin amp and pin out relates to left/right side bowed-in
  issues,a problem not usually found on your model.
Aug 30, 2007 | Mitsubishi WS-55908 55" Rear Projection...
Mitsubishi WT-46809 46" Rear Projection Television Logo
47 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
