Question about XO Vision GX1042 10.4 in. Car Monitor
Flip down monitor
When I ran the red 12V wire to the red 12V wire to the harness and the same with the black wire the monitor started smoking and blew the fuse. I replace the fuse and still no response. I took it down looked at the wires and they were all still in place nothing loose but the plastice was melted No power is going to the monitor. What do you think the problem is?
    Champion:
    Scholar:
  • 216 Answers
Check with a 12VDC from those drill battery.
Positive to red wire
Negative to black wire
Turn on radio.
atdlee@netzero.com
Posted on Mar 08, 2008
Specifically I'm trying to identify the wire on the spark plug coil assembly to which I should connect the signal wire of a Tachometer to. The wire colours are, red, yellow, green/white, and blue.
It says the tachometer wire is Yellow/Green, you do not have that listed. You will find it in the list below, it is highlighted..
WIRING INFORMATION 2001 Subaru Legacy
WIREWIRE COLOR LOCATION
12V CONSTANT WIRE WHITE Ignition Harness
12V IGNITION WIRE GREEN Ignition Harness
12V ACCESSORY WIRE YELLOW Ignition Harness
STARTER WIRE WHITE/BLACK Ignition Harness
POWER DOOR LOCK (-) WHITE Harness In Driver's Kick Panel
POWER DOOR UNLOCK (-) GREEN/RED Harness In Driver's Kick Panel
PARKING LIGHTS (+) ORANGE At Light Switch
DOOR TRIGGER (-) PINK/BLACK In White Connector Behind Fuse Box
TRUNK TRIGGER (-) YELLOW/BLUE In White Connector Behind Fuse Box
TRUNK RELEASE (5-wire) LT.GREEN/YELLOW At Motor In Tail Gate
FACTORY ALARM ARM (-) Factory remote only
FACTORY ALARM DISARM (-) Factory remote only
TACHOMETER YELLOW/GREEN At Ignition Coil
BRAKE WIRE (+) WHITE/BLACK At Brake Pedal Switch
HORN TRIGGER (-) RED/GREEN Harness At Steering Column
LEFT FRONT WINDOW UP BLUE/RED At Driver Window Motor Inside Door
LEFT FRONT WINDOW DOWN BLUE At Driver Window Motor Inside Door
RIGHT FRONT WINDOW UP BLUE/RED Harness In Driver's Kick From Driver Door
RIGHT FRONT WINDOW DOWN BLUE Harness In Driver's Kick From Driver Door
LEFT REAR WINDOW UP BLUE/RED Harness In Driver's Kick From Driver Door
LEFT REAR WINDOW DOWN BLUE Harness In Driver's Kick From Driver Door
RIGHT REAR WINDOW UP BLUE/RED Harness In Driver's Kick From Driver Door
RIGHT REAR WINDOW DOWN BLUE Harness In Driver's Kick From Driver Door
Feb 07, 2016 | 2001 Subaru Legacy
Flip down monitor how to wire it
The proper connection for these wires are: the red and black on the RCA cable go to chassis ground and a switched 12volt wire (accessory or ignition) and should be fused at the connection with not more than a 15 amp fuse.
No info on the dome light wire connections
Jun 27, 2012 | Car Audio & Video
Which wires go to what in the radio
ITEM - WIRE COLOR - POLARITY - WIRE LOCATION
12V - red - POSITIVE - ignition harness
STARTER - white - POSITIVE - ignition harness
IGNITION - red - POSITIVE - ignition harness
ACCESSORY - red - POSITIVE - ignition harness
SECOND ACCESSORY - yellow - POSITIVE - ignition harness
BRAKE WIRE - white - POSITIVE - brake pedal switch
RADIO 12V - red - POSITIVE - radio
RADIO GROUND - black - NEGATIVE - radio
RADIO SWITCH - yellow - POSITIVE - radio
RADIO ILLUMINATE - pink - POSITIVE - radio
POWER ANTENNA - gray/orange - POSITIVE - radio
LF SPEAKER - white - brown - radio
RF SPEAKER - green - orange - radio
LR SPEAKER - yellow - black - radio
RR SPEAKER - orange - blue - radio
Jul 02, 2011 | Hyundai Motor 2003 Elantra
Where can i get a wiring diagram for my 2002 chrysler neon auto
12V CONSTANT WIRE RED and PINK/BLACK Ignition harness
12V IGNITION WIRE DARK BLUE Ignition harness
12V ACCESSORY WIRE BLACK/ORANGE Ignition harness
STARTER WIRE YELLOW Ignition harness
PARKING LIGHTS (+) BLACK/YELLOW At Headlight switch
POWER DOOR LOCK (5-wire reverse polarity) ORANGE/PURPLE Harness Coming Into Vehicle From Driver's
Door
POWER DOOR UNLOCK (5-wire reverse
polarity)
PINK/PURPLE Harness Coming Into Vehicle From Driver's
Door
DOOR TRIGGER (-) YELLOW/BLACK At Headlight Switch
DOMELIGHT SUPERVISION (-) Use door trigger
TRUNK TRIGGER (-) GRAY/BLACK At Light In Trunk
TACHOMETER WIRE TAN/BLUE or BLACK/GRAY At Ignition Coil
BRAKE WIRE (+) WHITE/BROWN At Brake Pedal Switch
HORN TRIGGER (-) BLACK/RED Harness Coming From Steering Wheel At
Column
CAUTION! SRS airbag wires are not enclosed in protective loom at the steering column. They are a twisted pair of wires that run with rest of
ignition harness. Be careful not to cut or probe these wires.
Radio:
(Black plug)
Rear Right speaker -: Blue w/White stripe
Rear Left speaker -: Brown w/Yellow stripe
Front Right +: Purple
Front Left +: Dark Green
Rear Right speaker +: Blue w/Orange Stripe
Rear Left speaker +: Brown w/Blue Stripe
Power Antenna/Amp: White
(Gray Plug)
+12v battery wire: Pink or Pink w/White Stripe
+12v Ignition wire: Red w/ White Stripe
Front Right speaker -: Blue w/ Red Stripe
Front Left speaker -: Brown w/ Red Stripe
May 03, 2011 | 2002 Dodge Neon
I need a wiring diagram for a Sony car stereo so I can figure out which wire color works for what.
yellow 12v battery
red 12v accessory
black earth
blue/white amp rem
blue power antenna
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
green rear left +
green/black rear left -
purple rear right +
purple/black rear right -
that should help u pls rate
Mar 30, 2010 | Sony CDX-F7710 Car Audio Stereo CD MP3...
What are the stereo color codes for a 2002 jaguar x type 2.5.. hooking up amp with the factory deck and dont wanna buy the iso harness thaNKS
| ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|red/grn & red/org |+ |ignition harness |
| STARTER|gry/blk or lt. blue |+ |ignition harness |
| IGNITION|green/black |+ |ignition harness |
| SECOND IGNITION|pink/white |+ |ignition harness |
| THIRD IGNITION|red/wht (key sense)|+ |ignition harness |
| ACCESSORY|yellow |+ |ignition harness |
| SECOND ACCESSORY|pink/yellow |+ |ignition harness |
| POWER LOCK|black/blue |- |DDM *1 |
| POWER UNLOCK|black/white *2 |- |DDM *1 |
| LOCK MOTOR|yellow/black | |DDM *1 |
| UNLOCK MOTOR|white/purple | |DDM *1 |
| DISARM DEFEAT|white/green | |pass. kick, harness to rear |
| PARKING LIGHTS +|use neg. wire only | | |
| PARKING LIGHTS -|white/green *3 | |headlight switch |
| HEADLIGHTS|white/green *3 |*3 |headlight switch |
| DOOR TRIGGER|black/white *4 |- |underdash light |
| DOME SUPERVISION|comes on w/unlock | | |
| TRUNK/HATCH PIN|white/black |- |REM *5 |
|TRNK/HTCH RELEASE|black/blue |- |release switch or REM *5 |
| FCTRY ALARM ARM|arms w/ lock | | |
|FCTRY ALRM DISARM|disarms w/ unlock | | |
| TACHOMETER|brown or brn/stripe | |main harness pass. firewall |
| SPEED SENSE| | | |
| BRAKE WIRE|org/yel or org/blu |+ |brake pedal switch |
| HORN TRIGGER|gray/orange |- |FEM *5 |
| WIPERS|red/blk(L),red/grn(H|+ |wiper motor |
| LF WINDOW UP/DN|white - yellow |A |DDM *1 |
| RF WINDOW UP/DN|wht/pur - yel/pur |A |FEM *5 |
| LR WINDOW UP/DN|blu/red - pur/blu |A |REM *5 |
| RR WINDOW UP/DN|blu/orn - pur/wht |A |REM *5 |
| RADIO 12V|orange/black |+ |radio |
| RADIO GROUND|black |- |radio |
| RADIO SWITCH|yellow/green |+ |radio |
Notes:
NOTE: This vehicle is equipped with a passive immobilizer that needs to be bypassed for remote start operation only. Use DEI part number 555U to bypass. *1 The DDM (drivers door module) is located in the center of the drivers door. *2 Requires a double pulse to unlock. *3 Parking lights require a negative trigger with a 1800 ohm resistor in-line to the white/green wire. Using a negative trigger with a 780 ohm resistor in-line to the same white/green wire will turn on the headlights as well as the parking lights. *4 This wire may cause the aftermarket alarm to false when the vehicles electrical system shuts down. Use a relay to isolate it. *5 The FEM (Front Electronic Module) is located in the drivers kick panel. The REM (Rear Electronic Module) is located in the trunk, just above the battery. hope that helps
Sep 27, 2009 | Car Audio & Video
Suburu radio wire harness. trying to match up with a new soni deck
Hello uze7, Here is the wiring match up for a 2009 Subaru Forester using the Metra 70-7552 wiring harness: NOTE: The actual harness will be listed as a Nissan harness, but has been used by Subaru since 2007. Also, I'm assuming that your Sony deck uses the standard color code. If not, you should have a manual that lists the function along with the colors. Match the wiring by function, not by color (although the colors may be the same). 2009 Subaru Forester Radio Wiring Color Code: Battery BLUE/RED (+) RADIO HARNESS Accessory YELLOW/RED (+) RADIO HARNESS Ground BLACK (-) RADIO HARNESS Illumination VIOLET (+) RADIO HARNESS Dimmer BLACK/WHITE (-) RADIO HARNESS Power Antenna YELLOW/BLACK (+) RADIO HARNESS LF Speaker (+) BROWN LF Speaker (-) BROWN/WHITE RF Speaker (+) BLUE/WHITE RF Speaker (-) BLUE/YELLOW LR Speaker (+) WHITE/BLACK LR Speaker (-) RED/YELLOW RR Speaker (+) GRAY RR Speaker (-) GRAY/RED Metra Harness: Yellow ? 12V Constant Red ? 12V Accessory Black - Ground Orange ? Dash Light Dimmer/Illumination Green ? Left Rear Speaker (+) Green/Black - Left Rear Speaker (-) White ? Left Front Speaker (+) White/Black ? Left Front Speaker (-) Purple ? Right Rear Speaker (+) Purple/Black - Right Rear Speaker (-) Gray ? Right Front Speaker (+) Gray/Black - Right Front Speaker (-) Standard CEA Color Code: Blue - Power Antenna Blue/White - Remote Turn-on Pink/Black - Audio Interrupt In (Phone) Orange - Illumination Red - Ignition (Switched 12V) Yellow - Battery (Constant 12V) Black - Ground Gray - Right Front Speaker (+) Gray/Black - Right Front Speaker (-) White - Left Front Speaker (+) White/Black -Left Front Speaker (-) Violet - Right Rear Speaker (+) Violet/Black - Right Rear Speaker (-) Green - Left Rear Speaker (+) Green/Black - Left Rear Speaker (-) Hope this helps.
Aug 13, 2009 | Car Audio & Video
Installing remote start
1996 Mercedes E-Class Alarm, Remote Starter, Keyless Entry Wiring Information Constant 12V+ Red Ignition Switch Harness Starter Purple Ignition Switch Harness Ignition Pink/Black Ignition Switch Harness Ignition 2 Pink/Yellow Ignition Switch Harness, Accessory 2 Accessory Pink/Blue Ignition Switch Harness Tach Black Coil Brake Switch Black/Red Brake Switch Trunk Pin Brown/Yellow/ (-) Trunk Light Parking Lights Gray/White L And Gray R at Light Switch or Alarm Module Head Lamp White/Yellow (+) Light Switch Factory Disarm Blue (-) Driver's Kick Panel Door Trigger Gray/Black (+) Gray/Red Head Light Switch Door Lock Blue/Yellow (-) Driver's Kick Panel Door Unlock Blue/Black (-) Horn Wire Black/Yellow OEM Alarm in Trunk
Jul 18, 2009 | 1996 Mercedes-Benz E-Class
Stereo wiring 98 saturn
That stereo is now most likely dead. speaker wires are mostly green/black stripe, white/b s, grey/b s and violet/b s. ground is black and power are red and yellow.
May 31, 2009 | 1992 Saturn SL2
Radio wiring harness color codes for 2004 Jeep GC
This is for a 2002 cherokee:
RADIO 12V - red/white
RADIO SWITCH - white/red
May 16, 2009 | Cherokee Car Audio & Video
XO Vision GX1042 10.4 in. Car Monitor Logo
300 people viewed this question
Top XO Vision Car Audio & Video Experts
jason
Are you a XO Vision Car Audio and Video Expert? Answer questions, earn points and help others
