Question about Panasonic KX-TG6071M Cordless Phone
No dial tone and "line in use " message
My phone line has no dial tone and in the base set i have a"line in use" message. When I call from any phone to my house it rings forever without any response
I've had the same problem for the last couple of days. The base says line in use, no dial tone and if you call my number it just rings. I tested the line outside, and that is fine. Also, it will start working all of a sudden, be OK for a while, and then go out again. No rhyme or reason. Any ideas would be greatly appreciated.
  • 4 more comments
  • Petedelu Mar 02, 2008
    I've tried plugging different phones into the jacks, but still no dial tone.
    If you are talking about the wire from the jack to the phone, I've tried different phones with different wires and still no luck. As I stated, at times it will start working for a while (for example, it worked all day yesterday, until this morning when it just went out again).
  • Petedelu Mar 04, 2008
    Found the problem. It was a cracked wire from the junktion box to the house. A little splicing fixed it right up.
    Thanks.
  • Anonymous Mar 14, 2014
    i changed my line rental the the phone isnt working. there is not dial tone and calls cannot be made
  • Anonymous Mar 24, 2014
    LINES ON EXTENSIONS ARE LIT ON ALL PHONES BUT CAN'T GET DIAL TONE ON THE LIT LINES
    The phones suddenly stopped working. Made some strange ringing tones when receiving calls prior. All 4 units stopped working. It is not the phone line
    Master:
  • 377 Answers
There's a short circuit insideon your telephone, an electrical dc could be that make the unit not working.
Posted on Mar 02, 2008
  • pincer
    pincer Mar 02, 2008
    Take a look at the buttom part of the telephone, i know there's a switch like LP & DP mode.
  • pincer
    pincer Mar 02, 2008
    Oh.. I think and maybe you also think this, there's no problem on your unit, i guess the problem is on the line. It is a better option for you to call your Telephone Network Provider to make a test on the line, some calibration from them with the line will fix the problem.
    Thanks,
    Guru:
  • 1,894 Answers
The wire that is used to connect the line to the telephone is not proper...
  • dewan nafees ahmed Mar 03, 2008
    Here at FixYa, we love to get FixYa ratings for offering great advice
    for your problem in our attempts to help you the client with your
    problem.
    If you think I am deserving, A FixYa rating would be greatly appreciated.
    kind regards
    sweet rascal
  • dewan nafees ahmed Mar 04, 2008
    wow thats great.
    i said you right.." wire that is used to connect the line to the telephone is not proper"... tat is what i said in my first post..
    cool..
    good day..
    thank you
    dont forget to rate the solution.
2 Suggested Answers
SOURCE: no dial tone and "line in use " message
Try the simple things first. Try a different phone. In my case, I had the phone company check - outside was fine. After two hours my phone worked. I figured out what happened in my case. Both phones were dead (battery). I think one died with the phone off the hook. once the phones were fully charged, the phone worked.
Posted on Mar 29, 2010
Have out of range of base message
does the base unit have a dial tone . if no then you need to contact your land line phone company of course assuming you have it plugged into a phone line coming into the home
Dec 22, 2015 | Vtech Lands Phones
Dial tone nortel phone
It\'s in system programming: feature CONFIG, Terminals & Sets, enter ext #, Prime Line: set to I/C (for intercom dial tone) or Line xxx. It is probably set to None based on your description.
Aug 26, 2014 | NorStar T7316E Corded Phone
Phone not working
Hi Pam,
Try these..1...remove your telephone line from base unit and fix it into a working land phone and check whether is it having normal dial tone.If it's having engage tone(beep beep...)remove paralleled phones and re connect to cordless base unit.
2.If line is ok (normal dial tone with full volume) & still display indicates line is busy, your main base unit must be having faulty components inside.Commonly these defects happen in thundering or surges through telephone lines.You have to take full set to a repair shop.
Rana.
Dec 28, 2013 | Gigaset As300 Twin Dect Cordless Phone -...
I have 2 problems. 1. The orange message light will not stop flashing no matter what I do. 2. Some how the system was switched from touch tone to dial tone. I can't seem to that switched either.
Resetting the voice message waiting indicator
When you receive a new voice mail message, the new message LED on the top of the handset flashes. In the event your message waiting light gets out of sync with your phone company's
voice messaging system, you can manually reset it back to the "No messages waiting" state.
1. Press and hold FiND on the base for five seconds.
Note: The handsets connected to the base will start to beep, however, keep pressing for five seconds.
2. A beep sounds and the message alert tone is reset.
Changing the dial mode
Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most base networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you will need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, please follow the steps below to modify your phone's settings:
1. Press MENU/SELECT.
2. Select the Global Setup menu, and then the Dial Mode submenu.
3. Scroll to highlight Pulse.
4. Press MENU/SELECT. You will hear a confirmation tone.
If you ever need to change the dial mode back to tone dialing, follow the same procedure, but select Tone in step 3.
Finally for future ease of use, here is a link to the user manual were I copied the above information from:
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DECT1580-3om.pdf
Jul 21, 2011 | Uniden DECT 6.0 Cordless Phone ID
The phone lights up when put to charge also the red light on the base,, but when the phone line is connected it wont work ..What do u think is the problem?
The battery in the handset could be bad . First I would test that the base unit is recieving dial tone by pressing speaker button on base unit. If there is dial tone then problem is in handset or in base unit communication to handset. Try resetting power to base unit. Check manual for any re-initialization procedure. If the base unit is not receiving dial tone then I would test that the phone line is delivering dial tone to the base unit by connecting a known good phone to the line cord. If the dial tone is not present , problem could be in line cord from outlet, outlet, building wiring, or service provider.
Dec 08, 2010 | Uniden Cordless Phone
Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
Jun 05, 2009 | Uniden 2.4 GHz Cordless Phone System
Feb 21, 2008 | Uniden Cordless Phone
Panasonic KX-TG6071M Cordless Phone Logo
483 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
