Blank digital screen. It does power up plus screen lit up but no text in screen plus exclamation point lit on on top as well. Also computer doesn't recognize machine.
-   Mine Powers up and you see the fuser light up for warm up ,but no display and the computer does not see it.
Could there ba a wire loose somewhere (other than my head)
If so where and how do I fix it?
thx
Dennis
dennismay@hotmail.com-   dennismay
Ok fine the same prolem with 3050 . Is haviong the some manufating defect . check your usb cable, reinstall the new driver from the hp site. if the problem dose't fixs pls call the hp help for replacment
Thank you
HP laserjet 3030 "door open or no print cartridge" continuously displayed after side...
(More)
HP laserjet 3030 "door open or no print cartridge" continuously displayed after side cover(right cover and left cover) opened and closed several times. The tab that pushes the interconnect lever could not find out in the cover(right or left cover). Can somebody show pictures where is the tab or detail explanation? Also, opened the back(rear) cover of the printer and could not find the arm to the sensor where the arm is and whether the arm was hung or not. I need more detail explanation or pictures where the arm located and how to check it. How to fix this problem "door open or no print cartridge" soon?
(More)
HP laserjet 3030 "door open or no print cartridge" continuously displayed after side cover(right cover and left cover) opened and closed several times. The tab that pushes the interconnect lever could not find out in the cover(right or left cover). Somebody can show pictures where is the tab? or detail explanation? Also, opened the back(rear) cover of the printer and could not find the arm to the sensor where the arm is and whether the arm was hung or not. I need more detail explanation or pictures where the arm located and how to check it.
HP Laserjet 3055 not recieving or sending, have two home lines one for house and one for fax...
(More)
HP Laserjet 3055 not recieving or sending, have two home lines one for house and one for fax internet??
I have a HP Laserjet 3050. I can not print pdf. Print looks like some sort of computer launague....
(More)
I have a HP Laserjet 3050. I can not print pdf. Print looks like some sort of computer launague. What can I do?
