Question about Sanyo DS31590 31" TV
Sanyo DS 32224
U turn it on &within 2 sec it turns off even with remote. after 3 times u have to unpluge it for a couple sec then u can start over
  • minoe Mar 17, 2008
    Same issue but DS32225.
    C493 is bad, but replacing it didn't resolve the problem.
    No Service manual. :(
  • slasher8044 Mar 31, 2008
    model ds31550 32" sanyo turn on and in 2 seconds turns off
    Problem Solver:
  • 11 Answers
I would be 97% sure that you have dry joints on the board. If you are not confident soldering or with electronics then I would recommend that you take it to a qualified technician. They shouldn't charge you more than £10-15 to repair it.
Posted on Mar 28, 2008
My sanyo dp46849 will power on and the light turns on but within 3 seconds turns itself back off
There is a common problem for this mode, i will check out the back lights inverter board first.
Jan 14, 2018 | Sanyo Televison & Video
My battery died on my key remote for my 2002 Ford Expedition. I have replaced the battery, but apparently need to reprogram it. How do I do this?
It should work even after taken the battery out., but here is the process.
1. place key in ing.
2.turn from position 2(lock) to pos 3(off), cycle pos 3 to pos 4, 8 times within 10 secs. your 8th turn ending in pos 4. Doors should lock/unlock confirming the program mode is ready.
3. within 20 secs, program your fob by pressing any button on the fob. the doors will lock/unlock confirm it is programmed. If more than 20 sec pass before pressing the fob button, the step will have to be redone.
Feb 05, 2010 | 2002 Ford Expedition
2000 Celica GT - I can get into the programming mode just fine, but I have tried to program THREE separate remotes and none of them will program. They are used, so I am "rewriting" them, but they never...
I saw this on one of the toyota forums;
1) Getting a Replacement Remote
Look on ebay or google, make sure the remote has the following FCC-ID: bab237131-056
2) Installing the remote (credit to iPal)
1 open door, take key out...
2 insert and remove key from ignition 2 times
3 close and open driver's door 2 times
4 insert and remove key from ignition
5 close and open driver's door 2 times
6 insert key into ignition
7 close door
8 turn ignition from 'lock' to 'on' and back to 'lock'
if you do step #8
*1 time it's for add mode
*2 times for rewrite mode
*3 times for confirmation mode
*4 times for prohibition mode
9 remove key
10 then door lock will cycle 'lock' and 'unlock' a number of times
corresponding to your key cycles in step #8
11 press lock and unlock button together for 1 ~ 1.5 sec then release
12 then within 3 sec press lock button for 1 sec then release
13 if you did correctly door lock will cycle once...
if wrong, twice... then do it over...
Jan 27, 2010 | 2002 Toyota Celica
I need to program my Sanyo remote to all available channels. What is the code for a Sanyo GXBD remote?
I think this may be what you need I will tell you and we can see. Its true most remotes have codes but their are so many of them it would be hard to say. But as a fail safe the remote is programmed with a self coder. turn your T V off stand away from it a couple of feet and aim your remote at it, then start pushing the power button slowly at about 2 second intervals just keep pushing sometimes you may have to depress the power button as many as 50 times but the T V should turn on when it does use your remote and go to menu channel select and scan it should log the channels in automatically in about 3 minutes
Nov 10, 2009 | Sanyo DS20425 20" TV
HOW TO PROGRAM 2003 TOYOTA CAMRY FACTORY REMOTES
1. Driver door open and unlocked. Key out of the ignition
2. Insert the key and remove 2 times in 5 sec.
3. Close and open driver door 2 times in 40 sec.
4. Insert the key and remove it again from ignition.
5. Close and open driver door 2 times in 40 sec.
6. Insert the key in ignition,
7. Close the door,
8. Turn to on and back to lock in 1 second intervals. 1 time for add, 2 times for rewrite, 3 for confirmation 5 for prohibition. (yes, there is no “4”)
9. Remove the key
10. Power lock will cycle to confirm
11. For add or rewrite mode within 40 sec of the confirmation,
A. press “lock” and “unlock” buttons of the FOB at the same time between 1 and 1.5 seconds.
B. within 3 sec press “Lock” button for more than 1 sec and release.
C. If it’s correct, the power door lock will cycle once. If it’s wrong the door lock will cycle twice.
Sep 17, 2009 | 2003 Toyota Camry
Remote works sometime but not always
1. replace with fresh alkyline batteries.
2. If you have fluorescent lights, they will interfere with the remote.
3. Turn OFF lights, remote will work. Turn ON lights, the remote may not work well.
The "code" depends on the Remote brand/model.
Different maufacturers of remote control units don't use the same code numbers (there is no standard remote code for any TV).
Hope this helps!
Sep 08, 2009 | Sanyo DS27510 27" TV
32" sanyo model ds32224
picture 330 lines
video input 700 lines
16.9 full HD has 1080 resolution and this is for a ds 32224
Jan 28, 2009 | Sanyo DS32224 TV
COOL START REMOTE NEEDS REPROGRAMMING
from http://www.crimestopper.com/techweb/InstructionBooks/RemoteStart/rs1300dp_1304dp_a_ops.pdf Note: All transmitter codes must be learned at time of programming!! The unit will learns up to 4 different transmitter codes. 1. Open Hood (If no hood pin installed with your system, then you must ground the Gray Hood pin wire). 2. Turn key to the ON position. (Pink wire must be connected.) 3. Press Programming button 4 times, then after a few seconds the unit flashes the parking lights 4 times. 4. Press button #1 of the transmitter to be coded. You should get 2 light flashes indicating the unit is waiting for a 2nd code, then press button #1 of a second transmitter, the unit will flash 3 times indicating its waiting for the 3rd code and so on. If all 4 codes are learned, the unit will automatically exit code learning mode, otherwise turn key off and close hood. See diagram below.
Dec 16, 2008 | 2-Way Remote Starter
Reprogram remote
xl-7 programming instructions first you need to stuff your head up under the dash and locate your module drivers side upper corner under dash does it say programmable transmitter (the first models had no programable modules) if it says that then......
1 confirm all doors are shut and key is out of ignition
2 open drivers door insert key and turn to on within 10 sec
3 turn ignition switch to off in 10 sec
4 push and release drivers door switch 3 times in 20 sec
5 turn ign. switch to on in 10 sec
6 turn ign. switch to off in 10 sec
7 press and hold lock and unlock button on transmitter for 5 sec within 20 sec of step 6 alldoors will lock/unlockto confirm correct process
8 press lock unlock buttons on second remote within 5 sec after step 7 once again all doors will lock/unlock to confirm
9 to add another remote up to a max of four repeat steps 1 through 8 this was taken directly out of an owners manual supplement that comes with a new keyless entry kit (part number for a xl-7 or grand vitara can't remember which one it goes to but it works on either one is 84900-67810) which you would have to purchase if yours is not programable these instructions are the same for vitara, grand vitara, xl-7 and the esteem hope this helps
Jul 05, 2008 | 2002 Suzuki Grand Vitara
Sanyo DS31590 31" TV Logo
49 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
