Question about Canon PIXMA iP1600 Printer
Printing problem my printer was working fine and now only prints red and i have plenty of color ink?
  • 3 Answers
It is a new original cartridge?
or u don't use it for a long time?
try to use a tissue press on the nozzle to see whether there r 3 colours on the tissue if there r means that u cartridge is spoil need to change a new cartridge.
if only can see red colour means that ur cartridge nozzle block maybe not use it for a long period, u may use a bit of warm water to clear it.
put some warm water in a container just 3-5cm high make sure the water do not higher than the circuit board on the cartridge, put the cartridge in for 5 to 10 min, use a tissue to clean up the nozzle and check the colour. most of the cases can be solve by using this way.
Posted on Mar 11, 2008
My Canon Pixma ip6000d isn't printing any images or text. There is plenty of black ink, I ran the tests for alignment and nozzle check. The paper feeds through fine and it sounds and acts as tho
Did you try a test print. Most printers have a option to set the ink color, this is done when your computer asks you if you want to print. Look for an options tab and search for ink color options pick black only and try a test print. The test print is done on printer set up. If all else fails try the manual it usually has a troubleshoot section. Oh yes make sure you have the correct usb port some are configured at a lower level ( mine has 2 different ones a 2.0 and a 3.0 the 3.0 is blue when you look inside of it) my 2.0 port wouldn't set up my printer I had to use the 3.0 port. Hope it helps you some!
Feb 15, 2013 | Canon Pixma iP6000D InkJet Photo Printer
New Cartridges - not all color ink printing!
It sounds that the ink inside the cartridge has partly dried up.
This can happen to my printer when I don't use it for a couple of months too.
Hope this helps!
Feb 04, 2010 | HP PhotoSmart C4180 All-in-One Color...
HP Deskjet 990cxi Printer NOT printing B/W, only red.
To customer of HP deskjet 990cki: I purchased the HP photosmart Plus B209 ~ January 2010. 3 months into, I have learned that when the color ink that you don't use evaporates, the black ink will not work at all, no matter what you adjust or clean.To make it work you have to purchase more color ink...on & on & on..$$$$. Neither HP nor Best Buy will refund my investment. Spoken with HP customer service reps. in the Philippines & Canada both being outside of the US. NO customer satisfaction. No refunds. I suggest Boycotting both corps.
Jan 24, 2010 | HP DeskJet 990cxi InkJet Printer
All my photos have a heavy red tint
Be sure you have plenty of all the different inks and that the print head is clean and functioning well. If you are low on one of the inks the colors can be off.
If you have plenty of ink then on of the color print heads may be clogged and preventing that ink from flowing. A few cleaning cycles will hopefully fix this.
Also realize that different inks will render different color reproduction and will especially look different from what you see on your computer, unless you have special software to correct for this.
Dec 19, 2009 | HP Photosmart D7460 Printer
HP psc 2110xi color printing problem
The printer head may need to be cleaned. You can buy a cleaning kit for the head.
May 08, 2009 | HP PSC 2110 Color Printer
Prints suddenly red & cleaning doesn't help
The Color printer catridge ink might be low . You nned to replace.
Dec 15, 2008 | Canon i860 InkJet Photo Printer
Colors are not printing out true.
I replaced the Office Max ink substitute with an original Canon ink. This did not help. I decided this problem most probably had to be a printer head issue, so I gave up and bought a new printer instead.
Dec 03, 2008 | Canon PIXMA MP780 All-In-One InkJet...
My priter prints blue lines across all colored pictures or text.Any Idea?When printing black only,there is no problem.any colored - blue lines are added.I did reintal the drivers,used old and new but...
Have you tried cleaning the print heads or replacing the color cartridge? where as it it printing black fine it leads me to believe the problem lies in the color cartridge. my first recomendation would be to run the clean print head wizard in the printer settings and if that does not work then replace your color cartridge.
Jul 03, 2008 | Lexmark X5150 All-In-One InkJet Printer
Print diferent colors
Run a test print by pressing ink etc.
Do you see all 4 block lines (BK/C/Y/M) or just BK and red?
It would be helpfull if you post the test print here!
Nov 03, 2007 | Brother MFC 210C All-In-One InkJet Printer
Canon PIXMA iP1600 Printer Logo
29 people viewed this question
old marine
old marine
