Question about Kitchen Ranges
Help! burner on stove is dysfunctional
Please help. I bought an older home that contains a Tappan Centennial electric stove. The oven and the two front burners work fine. However, the two rear burner (left and right) don't work properly. They burn only on red hot whether I turn the knobs to high or to simmer; there is absolutely no difference. I tried exchanging the element from the working front one to the bad back one, but there was no difference. The back still worked improperly.
What should I do next? What is the problem?
    President:
  • Kitchen Ranges Master
  • 2,651 Answers
The elemnt is workin fine, its the control switch(infinite switch) thats having the problem, replace them both
Posted on Mar 02, 2008
Tappan gas range electric pilots will not light
The gas line in your Tappan could be closed or
stucked up. Have it check.
Sep 23, 2009 | Tappan TGF320 Gas Kitchen Range
My oven is not workin
I take it this is an electric stove. The display and controller only are used for the oven operation. Check to make sure you have power coming in on all three contacts. If it's electric, it uses 1/2 of the 220 for the burners and the other for the controller. I assume you have already tried un-pluging it and plugging it back in. There should be a tech sheet in the back of the oven. If there is somebody that can read some simple voltage or has a meter make sure power is getting to the controll board. If it is, your controller is probably bad. Hope this helps.
Scott
Jan 23, 2009 | Tappan TEF242 Electric Kitchen Range
GE profile stove, Gas-electric
All oven elements are 115/130 VAC. Stoves use 220/240 so that you can use both the burners and Oven at the same time. Since the burners are Gas, then 220/240 VAC isn't needed.
(Note: 220 is simply dual 110 hot leads with a common ground)
Aug 31, 2008 | Tappan MEF500 Electric Kitchen Range
Burners and oven not heating tappan range 560s111po1
You need to check the connection at the back of the unit that hooks to the house power. Turn off breakers or pull fuses before checking. It sounds like you only have half of the voltage you need. One of the wire connectors may be burnt or you may have a problem with the house wiring.
Apr 23, 2008 | Kitchen Ranges
I have a double gas oven and no instructions
I have an O'Keefe & Merritt double oven gas stove. The model number is 72 7242 23. The upper oven is about the size of a large microwave and sits above the range burners. The lower (full-size) oven is below the burner unit and includes a broiler draw below it.
So, when you say, double oven, I wonder if you are just talking about the main oven with broiler drawer (both of which are below the burner unit.)
Mine was a builder-supplied appliance in the new house we purchased in 1986. The upper oven has never performed very well. And, yes the upper oven can only be used for baking.
I have an instruction manual for it, but it doesn't provide that much information. Getting parts for it is extremely difficult, since Tappan is no longer manufacturing this brand. (I've been trying to locate a flat oven ignitor for the upper oven and can't seem to find a replacement that's the same 6-1/3" length.) In the 1980s Tappan apparently purchased O'Keefe & Merritt and marketed this brand for several years. Models originally manufactured by O'Keefe & Merritt in the 1930s-1950s are considered collectible antique stoves!
If you want to email me, I'm at oldvic@erols.com
Apr 20, 2008 | Stoves Premier 900GRa Gas Double Oven
Oven will not lite
Older is BETTER !! Replace the igniter,even if it is glowing
REPLACE it !
note:there is a 2% chance the safety valve is the problem.And I'll bet you ,you are in the 98% side on this one.EVEN THOUGH YOU SEE IT GLOW -----IF ITS JUST GLOWING---------GLOWING--------GLOWING---------it's gone ! !
Please Rate This & Thank You ! !
Feb 01, 2008 | Tappan TGF363 Gas Kitchen Range
Kitchen Ranges Logo
210 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
