Question about Jura Capresso C1000 Espresso & Coffee Maker
Sudden low espresso quality
I've had my C1000 for about 5 years now, and have been very pleased with it. About 3 weeks ago, the espresso started tasting very 'off'. Not just bitter, but other flavors that I can't identify. The off taste isn't as bad when I use the pre-ground chute, but still there.
I've changed coffees, cleaned the metal screen, and removed the filter in the water tank in case any of that was causing the problem. Nothing helped.
I have some Durgol solution, but I can't figure out how to put the machine into "cleaning required" mode so that I can clean it.
Do you have any suggestions? Should I get a Torx screwdriver and take the unit apart to clean it?
It's fully operational as is; the quality is just poor.
Thanks for any advice you may provide
    Problem Solver:
  • 10 Answers
Have you been using the cleaning tabs regularly? If not, that is the first step. Second, if the time for brewing is too long then it goes bitter quickly. I time shots at about 11 seconds and add hot water after that. If you take taste tests for longer periods you can tell where it goes bad quickly and adjust the timer to stop at the right spot. Maybe timing changed. Have you had the wiring recall? If not, call Capresso and see if they'll still recall for free and they will also offer and exchange or full repair of existing unit.
Posted on Apr 19, 2008
Problems with colors and display on my Samsung LN37A550P3FXZA flat LCD.
Replace all busted capacitors in power supply board inside.
Jan 10, 2014 | Televison & Video
Poulan Leaf Blower
you may need to turn the Hi screw on the carb in 1/4 of a turn. Make sure the gas and mix are fresh.
Jul 22, 2013 | Poulan Garden
I've purchased my canonE500 a week ago.......colour copy's not good
Try with the adjustment settings either in the printer or in your system. If the print quality is still low, Replace the printer. You may have warranty replacement.
Oct 27, 2012 | Canon Office Equipment & Supplies
I have my Silvia for 3 years and for the last couple week, it gives me espresso watery with no crema. I havent changed anything for the last 3 years. Please help!
It definitely needs preventive maintenance once a year. There could be a couple of issues causing watery espresso. You could have a clogged shower screen or cracked porta-filter basket. They bypass valve from the pump could be leaking causing low pressure (check this by pulling a shot and seeing if water continually flows back into the tank via one of the water hoses).
Mike mikey@espressomachineexperts.com
Oct 15, 2010 | Rancilio Silvia Espresso Machine
Aeroccino deosn't make froth
Our aeroccino worked fine for 2 years and suddenly it didn't made foam anymore. We tried the "inverting trick" without much success. We contacted Nespresso and they suggested switching from regular fresh milk (we used 2%) to UHT milk (harder to find in US) and to use it cold and freshly opened. So we tried that and it works.
Hope this solution works for you too
Aug 08, 2009 | Nespresso Aeroccino Automatic Milk Frother
La Pavoni high pressure also, but all of a sudden
check pipe for pressurestat and pressurestat,maybe just gauge is not corect
Aug 01, 2009 | La Pavoni Professional Black Base
Poor print quality 2300dl
first did you try to clean laser glass ? and maybe you need a new 2'nd transfer roller.
open front cover and under the pc drum there is a blue knob, pull it out and clean the glass
May 28, 2008 | Konica Minolta magicolor 2300DL Laser...
Problem uploading pictures
Remove any Camera CD software and let Windows try for its self Come back with the result.
Sep 23, 2007 | Fuji FinePix A360 Digital Camera
Jura Capresso C1000 Espresso & Coffee Maker Logo
256 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
