Question about HP Pavilion dv6000z Notebook
Blue srren fatal error
My laptop just few minutes back showed a blue screen stating fatal error and something about physical memory begenning to dump ... and somethng about hardware and software and also about windows update ... my computer was kind of hang .... so i took out the battery n agaain start my laptop ..... what should i do but now its not showing any of those signs
  • sugandh Mar 03, 2008
    sir
    as my computer was hanged and kept on pressing F8 but then there was no respond .... so i took out the battery ... so when i again restart the computer it is working alright .. but every now n den there is some message about terminating the programe ... should i opt for system restore ... please suggest .......... what should i do to get my computer working well ....
  • ali oz Apr 30, 2008
    my laptop is imb thinkpad and it keeps on saying prees f12 to take a short cut to start the laptop and the it starte saying fatal error
I have that problem too but it is restarting when i press F8
byronne tula
Posted on Mar 16, 2008
  • 520 Answers
You was probably installing updates in the background and youve interrupted install and shutdown improperly (reason)
turn on pc and press f 8. if youve never done this before;as soon as you see anything at startup keep pressing f 8 youll still get to the place you want to be.select start up using last known good configuration.
Posted on Mar 02, 2008
  • tat4u
    tat4u Mar 03, 2008
    you can try system restore if you have restore dates in but consider that the system cant always restore but it doesnt take a long time so no harm to try.a better optionis to repair os;even better is to reinstall fresh copy if theres no files you desperatly need.
    how to do....make sure os disk is in drive,restart;pc option appears press any key to boot from disk,press a key..disk boots giving option install windows or repair windows choose install windows system will check existing os and tell you that os is already installed...at this point you can choose install windows or repair windows.if you choose to repair follow instructions.if you choose to install new copy first delete partition and create new partition....format and install,if you are missing any drivers after instalation dont worry this is common ...drivers can be easily found on hp site
Error code after running diagonistics
If you run Advanced System Care that will repair your errors, if repairable.
Looks like a fatal error though. Back up your data,NOW!
Nov 17, 2013 | Dell Xps 15 Laptop Computer (Intel CORE I5...
Physical memory dumping
once your computer take an BOD or blue screen of *****. it is an indicator that one of you perepherals was damage. in that case you only have to option the memory cards or the HDD. if some point you dont experience a hard time in booting it is not the HDD. maybe your memory cards was in defective state. sometimes good sometimes bad. try to chkdsk first or scan your HDD for posible bad cluster. and make a test also in your memory using some stress memory tester
Aug 21, 2017 | Intel Motherboard
Physical Dump of memory
Hi...
There are two thing you should try..
Check the memory.
Reinstall the OS.
Thanks
Kindly rate
Smith
Aug 13, 2009 | Dell Inspiron 1420 Notebook
Physical memory dump blue sreen
This is error message is primarily related to the physical memory of your system is not working properly.. or else it might be a issue with the slot for the memory on your computer.... i would recommend you to contact a local guy or else you can also try to reinstall your windows on the system...
Jan 22, 2009 | Intel Motherboard
Causing fatal error when not plug into KVM Switch
dear sir,
her eu have a chek yr kvm switch is connected thru earth.. this becouse some of time eart bypass thru switching yr monitor keyboard and mouses and mosr of time laptop don't face high static electricity.. it's first chance........ other is that yr pc has serious visus problem may be it's face thru Pen drvier or a internet or a some cd's which has infaction before data write in to cd.. so have to cek virus........ one more thing happen if yr pc is connated thru electticity and yr laptop is thru battry that time when u switch yr kvm module it's pass bunch of power so u have to chek all this thing's it's help u...:)
IOGear 2-port KVM Switch
Nov 17, 2008 | IOGear GCS632U 2-port KVM Switch
Blue screen
hi daget200;
can you post the exact error message? its located at the top few lines so that we will know whats causing it. have you inserted a new hardware recently? when does the error occur? intermittent? does it happen when you are playing games or something? pls expound. thanks
Jun 07, 2008 | Computers & Internet
Memory dumpping
That is usually called a fatal error. It's not really fatal but you need to fix it. Download ccleaner and regscrub xp both for free and run them to clean your system up. It should run much quicker after that.
Oct 21, 2007 | Logitech Keyboard
HP Pavilion dv6000z Notebook Logo
89 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
