Canon copier iR2016
My copier canon iR2016 have multiple problems like E007,E001,E808 and it can't lift the paper from drawer also.
  • iali307 Mar 05, 2008
    thank for your reply .I live in india and here the standard is 220v.
    but your suggestion is very helpful amd I am trying to replace the fuser/fixing unit.
My Canon copier IR2016 Problem code E007 Solve the problem pls
help me
Posted on May 06, 2009
  • vivek_1313
    vivek_1313 Mar 14, 2013
    replace the fixing flim or fuser
Hello sir
help me
Posted on Oct 10, 2008
  • vivek_1313
    replace the fixing film or fixing film
    New Friend:
  • 18 Answers
For E007 replace the fixing film or fuser
For E001,808 Check thehalf cut bush of the fixing & readjust it
Posted on Mar 14, 2013
Respected sir/ medam
i have problem when i print from ir 2016,in the page one line black (1/2 inch )show on the paper,if i;m not wrong is that have pc roller problem,if yes how where from i purchase in india.email id-nischal_neer@rediffmail.com
Posted on Nov 04, 2008
  • 287 Answers
Hello iali307. All three error codes have to do with with an item called the fuser. This component, when working properly, is designed to provide extreme heat (to melt the powdered toner) and pressure (to force the melted toner onto the paper and"fuse" or bond the image to the paper. All manufacturers of all copiers make sure that this system (common to all) is intensely monitored as a building burrning down is not a maketing tool. Your copier's "fuser" can be rebuilt, but I would strongly advise the entire unit be replaced. My company (thet are tight assed) realizes the cost /benefit analysis of trying to rebuild these fusers and opts for replacing the unit. The part # is FM2-3345-000 if you live in a standard 120 v part of the world. I hope this helps,I wish you the best. :-) .......................SPINAL
Posted on Mar 04, 2008
Http://www.ots45.ru/support/canon_2016_2020_codes.html
Posted on Jun 12, 2009
How can i reset a system error E007
Good answer here:
http://www.mytechtime.com/2011/10/canon-error-e001e002-e003-e007.html
<quote>
How to reset E000, E001, E003 and E007
Canon IR2016, IR2020
Enter the service mode by pressing "additional function" key, "2" and "8" keys in that order. SSSW will display. Press "OK" key.
Change Bit switch 1, bit 0 (might display as the first one on the left using number keys) status, (change 1 to 0 or 0 to 1).
Press "OK" than Press "Stop" or "Additional Function key" to end service mode or restart the machine.
</quote>
Jan 20, 2015 | Canon IR2020 Copier
Tip
CANON iR2016/2020 ERROR CODES
E000 0000 Fixing temperature abnormal rise
E001 0000 Fixing unit temperature rise detection (by main thermistor)
0001 Fixing unit temperature rise detection (by sub thermistor)
E002 0000 Fixing unit temperature insufficient rise
E003 0000 Low fixing temperature detection after standby (by main thermistor)
0001 Low fixing temperature detection after standby (by sub thermistor)
E007 0000 Fixing film rotation error
E010 0000 Main motor rotation error
E019 0001 Waste toner full detection
0002 Waster toner full detection sensor failure
E052 0000 Duplex unit connection error
E100 0000 BD cycle out of range
E197 0000 Erroneous communication with printer engine
E500 0001 Finisher communication error
E520 0000 Offset error
E531 0000 Stapling error
E540
0001 Paper surface not detected (standard tray)
0002 Not moved within the specified time (standard tray)
0003 Sensor not reached within 3 seconds (standard tray)
0005 Encoder clock failure (standard tray)
E542
0001 Paper surface not detected (optional tray)
0002 Not moved within the specified time (optional tray)
0003 Sensor not reached within 3 seconds (optional tray)
0005 Encoder clock failure (optional tray)
E575 0000 Stack delivery error
E584 0000 Shutter failure
E716 0000 Erroneous communication with optional cassette
E719 0000 Erroneous communication with card reader (serial communication)
0002 Erroneous communication with coin vender (serial communication)
E733 0000 Erroneous communication between controller and printer
E736 0000 CCU communication error
E739 0000 Erroneous communication between controller and network board
E744
0001 Language file/boot ROM/USB memory error
0002
0003
0004
E805 0000 Fan failure
E808 0000 Fixing drive circuit failure
on Aug 03, 2010 | Office Equipment & Supplies
I have error code showing E007 on Canon iR2016j copier. How can I go ahead to rectify the error. Pl advise necessary assistance
these means that you have trouble with fixing film in fixing assy.So... you need to change fixing foil.
Feb 22, 2011 | Office Equipment & Supplies
Error 001, error 808
the e001 code is something is going with the fixing assembly. one of the thermistors could be going bad.
E808 is a Zero Cross error. We most commonly see power supplies or bad wall voltage cause this code.
The following information is coppied from the IR2016 Service Manual.
E808-0000 DRIVE CIRCUIT FAILURE
A zero crossing signal cannot be detected.
A fixing drive motor failure has been detected.
  • The heater does not turn on.
  • A fixing drive motor failure was detected.
  • Check the connector of the fixing film unit.
  • Replace the fixing film unit.
  • Replace the fixing drive motor.
  • Replace the DC controller PCB.
  • Replace the power supply PCB.
M201 - Fixing Drive Motor - FK2-1067 - J202 on the DC controller PCB - E007, E808
Power Supply - FK2-1074
Jun 14, 2010 | Canon iR 2016i Black and White Copier
I want user manual of Canon ir2116J copier
conon IR2116J printer E001 and E808.Please help me.
Oct 27, 2009 | Canon imageRUNNER 2000 Copier
Canon IR2018 E007
E007 Fixing film sensor failure
The fixing film sensor is faulty. - Check the connector of the fixing film
sensor.
- Replace the fixing film sensor.
- Replace the DC controller PCB.
you need to call a canon technician to sort it out
Mar 22, 2009 | Toshiba e-Studio162D Copier
System error E808
Canon iR2016 / iR2016J / iR2016i / iR2020 / iR2020i Код ошибки Субкод Описание
E540 0001 Paper surface not detected (standard tray)
E542 0001 Paper surface not detected (optional tray)
E744 0001 Language file/boot ROM/USB memory error
0002
0003
0004
Mar 22, 2009 | Canon CLC 1140 Copier
Canono ir2016 system error E007
Fixing film has been displaced e007
Having too much paper in the paper tray will cause your printer to have more frequent paper jams and double printing. Make sure you fill the paper to the fill line. I usually recommend going a little below line. I would also recommend that there is no paper from your previous jams still stuck in there. That will cause it to jam up as well.
Nov 30, 2008 | Canon CLC 1140 Copier
Canon iR2016
most times eoo1 can be reset in service mode if there is no damage to fixing unit. 1) Enter service mode.
Press the operation panel user mode key, 2 key, 8 key and user mode key in this order.
2) scroll to "clear" and press ok then scroll to "err" and press ok.
if that does not work you can go back into service mode as above and instead of scrolling to "err" scroll to "all" and press ok. power off then on. doing this will clear settings service techs might have made but i've done quite a few and had no probs
Mar 29, 2008 | Office Equipment & Supplies
CANON IR2016
hi... try to clean up your copier... usually dust accumulates inside the copier that's why paper inserted will always jam....always see to it that you copier is free from dust and other small particles that would cause your machine to get errors....
Feb 27, 2008 | Canon PC-940 Black and White Copier
914 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
