Question about Yamaha RX-V995 Receiver
Yamaha RX-V995 no power no audio [dead]
Hi Friend: I have a yamaha RX-V995 receiver with this symptoms:
1.NO power
2.No sound
A.when I checked the AC voltage going to the primary transformer I found 0 volt [no volt at all].
B.I directly applied the 120 ac volts to the primary [the fan run for 2 seconds ] but nothing happens.
C.I removed the 10 amp fuse and installed a 3 amp fuse ,but nothing happens,look like no shorts in the Primary transformer.
D.The secondary volts [with the directly application of the 120ac to the primary power transformer ] are about 9volts ,45 volts ect.
e.Troubleshoting it I can't find short transistor ,burn resistor ect.
Any idea of what the problem could be?
Anthony
  • Anonymous Mar 04, 2008
    i have the same problem in the same amp'
  • Anonymous Mar 30, 2014
    fuse
  • 4 Answers
Sounds like a short in the cpu of the unit
Posted on Mar 07, 2008
  • Brian D. Smith Jul 31, 2014
    NO IT DOES NOT! If you do NOT have any idea what you are talking about, please refrain from casually tossing out advice or opinions that can confuse or mislead and waste everyone's time. The symptoms described here are directly involving the AC outlet, power cord, and power transformer. This is well upstream of any CPU system or power. And "shorts" are NOT the same as open circuits. That term is misused by the uninformed masses.
Yamaha RX-V995: Is there anyway to only listen to
Assuming you have the same Model Variant ( I'm not sure if Yamaha varies model from Country to Country) I just switch mine to effect off ( 2 Channel) to remove the surround component so that only A or B speaker pairs work.That should fix it unless I am mistaken.
Jul 19, 2010 | Yamaha RX-V995 Receiver
Hi i have a yamaha rx-v995 reciver and just percase new pioneer dv-320 dvd. it's output connection is with coaxial conector.when i connect the coaxial to the coaxial onector of my yamaha reciver i dond get...
1) Check to see if the screen says "EXT DECODER". If it does, press the EXT DECODER button again and this should fix the problem
2) Press input mode button until the display reads auto or digital. It may be set to analog.
Nov 16, 2009 | Yamaha RX-V995 Receiver
RX-V995 Earthing issue
your main lead wire contains only two core, could be brown, black, anyway..open the cover of the unit, and change the cord, get three core main wire, and take the old one off, replace the other one, which should have earth, you can screw it to the transfomer base, try this
Nov 09, 2009 | Yamaha RX-V995 Receiver
Mp3 connect yamaha rx-v995 ---> muddy sound
Try getting into the configuration menu of the MP3 player and adjust the output controls for external devices....it sounds to me like it might be too high and/or the wrong output decoding.
May 09, 2009 | Yamaha RX-V995 Receiver
Yamaha rx-v995
I'm in the same boat w/ my v995 - it has a bad volume motor and its $150 for the part. You want to sell your v995? Adam
Mar 01, 2009 | Yamaha RX-V995 Receiver
Yamaha RX-V995 receiver turns on & then powers off 2 seconds late
I suggest you run self diag.  press [FM/AM] key + [Input mode] key and press the [power/standby] switch.
ps prt = power supply problem
dc prt = shorted output or leakly cap in channel
tmp prt means to hot on heatsink
you'll likely have to measure the resistances of the output FETs to find a short,
Jan 02, 2009 | Yamaha RX-V995 Receiver
Yamaha RX-V995: Remove On Screen Text
Here is a dumb try :). Connect your video source directly to the TV/projector, bypassing the receiver from inserting any messages.
If you are probably going to HD sometime, you would need to do that eventually as 995 doesn't have HDMI/Digital Video switching.
Nov 19, 2008 | Yamaha RX-V995 Receiver
Yamaha RX-890
I have the same problem with a RX-V995 Yamaha Reveiver.
Tim
Sep 05, 2008 | Yamaha RX-V995 Receiver
Service Manual
Sorry no - I think you might have to buy a copy somewhere like Vance Baldwin or the other authorized Yamaha replacement part vendor.
Aug 18, 2008 | Yamaha RX-V995 Receiver
Yamaha RX-V995 Receiver Logo
465 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
