Low volume from Akai turntable attached to Pioneer Surround Sound Receiver
Hello, hope you can help. I have an Akai AP-A201 turntable that had great volume on my old JVC receiver through Jensen speakers. I now have it hooked up to my Pioneer SX-316 Multi-Channel receiver and cannot seem to get much volume when playing records through it. Is there something I need to do or buy to correct this issue.
  • bazooka666 Aug 14, 2008
    I have a similar problem. When I hook up my tower speakers to an onkyo 5.1 receiver, I get really low volume when playing cd's. I have them hooked up to "speaker b" which is for 2 channel sound. any suggestions.....
  • Anonymous Mar 17, 2014
    There is no audio.Adjusting volume shows volume bar moving but still no audio.only hook up to tv is the cable to satellite receiver
If you receiver doesn't have phono inputs,you will need to buy an inline phono amplifier.Phono inputs have a built in amplifier,all others don't.Try Crutchfield.com.If they don't carry them,they will tell you who does.
Posted on Jan 27, 2009
I have the following setup: AV Receiver: Pioneer
Very common problem with today's receivers. Receivers made today don't have a true preamp section in the amplifier and do not amplify the sound to the extent of an older receiver. I have large 15" front speakers on my system, and have stuck with my 15 year old receiver just because I know that a new receiver will not have the power to drive them well. Many of the newer receivers need to be turned up to 50-60% before you can even hear anything from the speakers.
Aug 08, 2013 | Pioneer Audio Players & Recorders
My pioneer pl-200 doesn't play loud enough through my pioneer vsx-521-k receiver
The PL-200 has no pre amp and your VSX-521 has no phono input. You need an RIAA preamp.
Jul 11, 2017 | Pioneer Vsx-521-k 5.1 Channel A/v Home...
I have connected my Akai AP A510 turntable to my Technics SA EH770 but i don't get any sound till i turn it up on full, can you help
"PHONO" is the only designated connection on a receiver that is literal and exclusive. Nothing but PHONO will work right on it and old-school turntables would require it to preamplify the tiny current produced by a Phono cartridge.
If your unit doesn
Feb 21, 2011 | ION Audio Audio Players & Recorders
I just purchased a used Sony turntable PS LX 160H & am hooking it u Sony surround sound amp (there is no phono input but am using audio input) and getting sound but very low volume at max volume... How...
Just look around the web for a "Magnetic Cartridge Preamp".
You plug your turntable into this and the preamp in an aux socket of Surround Amp and the sound will be the same level as the other devices.
Sep 05, 2010 | Sony PS-LX250 Turntable
Significant volume decrease when using Comcast cable box
you might have to talk to comcast about that most signals are low for reasons of conservation of bandwidth, they may also be sending 5.1 which tends to be lower volume and adds surround in.
mono is always loud, and that is what you get with 75 ohm coaxial cable (single screw in ).
hope this helps.
Mar 15, 2009 | Akai LCT2715 27 in. LCD Television
Turntable
Hi Harpwailer,
I was unable to locate an owner's manual for VSX-D412 on the Pioneer website. I did find a VSX-D411, which I believe is very similar. Since there are no turntable jacks, I would try any set of open analog (RCA cable, like the ones that come out of your turntable and are probably red and white) jacks. Just plug the red cable into the red input jack, and the white into the white. The only thing to be careful of is to make sure that you use the input jacks, since some components (like tape decks) have input and output jacks, so that you can record to/from them.
This will work fine assuming that the output from your turntable is strong enough. Many turntables are designed to go through a pre-amp circuit; if this is the case with yours, you'll know it since the output volume will be very low, even when turned up very high. If this is the case, you'll need to purchase a pre-amp to put in the circuit between your turntable and the receiver, or else buy another turntable that outputs at a higher level (they can still be had rather inexpensively, surprisingly enough!). Also, you'll probably have a ground wire coming out from your turntable as well. You'll need to hook it to a chassis screw on the amp to prevent an electrical hum from being picked up and output through your speakers.
I hope this helps, and good luck listening to your vinyl. If you deem it appropriate, I would appreciate a rating on the help I have provided. Thanks!
Bob
Aug 26, 2008 | Pioneer VSX-D412 Receiver
LOW VOLUME ON MY SL-B35 TURNTABLE
Hi Tim,
You probaably do not have a phono input on the digital surround amp you are using. Your sound is bad for 2 reasons
  1. Your Turn Table has low output level,about 100 times less than a CD player.
  2. You need RIAA equalisation to reduce the treble and boost the bass. This is for replaaying any modern vinyl or LP's
You can get an outboard preamp that matches the output of your T/T to suit the normal aux input on todays digital surround amp.
You can get one online from here. Or if you are keen build one from a circuit here
I am more than happy to answer any other questions you may have about it, please get back to me here, or use the ASK function to go straight to me :) If you are still unsure, have problems, or we need to look at the situation more deeply, then before you give a rating for this advice, hit the ASK button Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards robotek
Jun 23, 2008 | Audio Players & Recorders
Very low audio output
Make sure your receiver has a PHONO input. If you are connecting it to a LINE or AUX input, then there is not enough signal to boost the sound coming from the turntable. Turntables require a PHONO input, because phono input's have a pre-amp on them, which boost the turntable signal. If you do not have a PHONO input on your receiver, you will need to buy a Phono Pre-Amp.
If you have a phono input, then you might have an issue with the turntable's RCA cables, or your cartridge may be at fault.
- TWEAK AV LAV
Nov 22, 2007 | Audio Technica AT-PL120 Turntable
Media Receiver
There should be fans inside this unit too. open the top cover and see where the noise is comming from. I am sure you will find it. Good Luck
Mar 21, 2007 | Pioneer PureVision PDP-4340HD 43 in....
912 people viewed this question
 Grubhead
Grubhead
