Question about Maytag MGR4452BDS Stainless Steel Kitchen Range
Main door handle
I have a mgr4452bds maytag range that the main door handle has already been broken off. It is one month over warrantee. I am searching for a handle that appears to be a 11 series but can only find parts for a 10 and 13 series. Are any of these cross replacable suitable subs?
    President:
  • Maytag Master
  • 2,651 Answers
What's the serial numbber of the machine??that will determine the series you will need, you say oyou hav a series 11 so im assuming your seial starts with 11*********, in which case use the series 10 handle, series refers to a revision in design, next revision shows up at serial 13**********.
Posted on Mar 02, 2008
MVP V door handle broken
Maytag mvp v microwave door handle parts Questions ...
www.fixya.com > Forum > Tags > mvp v microwave door handle parts
Maytag mvp v microwave door handle parts related problems. Ask your Maytag mvp v... The handle on my maytag microwave oven broke off ... door handle ...
Maytag Microwave Handle Parts from RepairClinic.com
www.repairclinic.com/Shop-For-Parts/.../Maytag-Microwave-Handle-Par...
Shop for your Maytag Microwave Handle from our huge inventory. Return any part for any ... Repair Help for Microwaves .... Microwave Oven Door Handle.
CMV1000ADW Maytag Microwave Parts and Repair Help
www.partselect.com/Models/CMV1000ADW/
Dec 22, 2015 | Microwave Ovens
My handle on my oven door came off. maytag model# mgr8674aw0
seperate the 2 halves(screwed together ) and rescrew it . door should just lift off when door is part way open
Feb 24, 2015 | Maytag Kitchen Ranges
Door lach/handle plastic pins have broken off and two pronge ears attached to door that hold handle in place have also broken off. This is a Maytag Model MDB5600AWW dishwasher.
handle was redesigned with a metal rod through the attachment points to prevent breaking. the handle and latch comes as a complete assembly (you don't have to put it together).
Jan 09, 2010 | Maytag Dishwashers
Maytag MDBH950AWB handle/latch failed.
Replaced handle/latch unit. Killed power to the unit. Removed the inside door panel then unplugged the two switches on the latch. Removed old latch with broken handle (removing inside panel frees latch/handle). Installed new latch with handle reconnected the two switches, reinstalled inside door panel. Very simple. Note: Latches can be purchased with or without the handle. Less expensive to buy with the handle already installed on the latch.
Jun 24, 2009 | Maytag 24 in. MDBH950AWS Built-in...
Have Maytag Model #MER5765Q - Door handle came off (slight weight on it caused it snap off). No broken/sheared bolts or broken plastic. Can't figure out how to reinstall. Help!
u have to take whole door apart to get to it . remove the door then take screws out from bottom and sides then u can removbe the glass to see the other screws helping to hold handle on
Mar 17, 2009 | Maytag MER5765Q CleanDesign Electric...
Handles fell off of the top oven door on maytag gemini glass top
Open the door a few inches, to the first hold-open stage. Lift the door upward & off the mounting bars. There will be screws along the bottom edge.
Mar 08, 2009 | Maytag MGR5765QDQ CleanDesign Gas Kitchen...
The entire door handle snapped off
I have the same problem- funny when we built we went all Maytag and got a bunch of lousy handles- the stove, micro, fridge, and freezer... I glued the pieces of the handle together and used plumber's putty to fix it. It's MightyPutty, but without the repackaging and cost. Just knead the putty until mixed, fill the cavity of the handle and press on the door where it was... No problem after six months so far.
Nov 30, 2008 | Maytag MMV5207A Microwave Oven
Broken maytag door latch assembly Maytag quiet series 300: the latch is not working, door is closed and cannot open, seems something snapped inside, how can I open the door ? and change the broken part ?
To open this latch, the handle works as a lever to push inward when you push up on the handle. If your handle if broken, it has probably ceased to work as a lever (the pivot pins have likely broken). You want to push in on the handle to open the latch, ideally toward the bottom of the handle opening. Once you get the latch open, you'll likely want to order a replacement (here is one source : http://www.repairclinic.com/PartDetail/Door-Latch/W10130694/1266678 ). Remember to turn off the power to the dishwasher, and you'll need a star head driver to remove the screws from the inside of the door to access and replace the latch.
Andrew
Nov 17, 2008 | Maytag 24 in. MDB3700 Built-in Dishwasher
I have a Maytage MER5775RAW electric stove and need to take the door apart
Try this website..it shows and exploded view and a parts list if you punch in your model number.. http://www.pcappliancerepair.com/model-display.php
Hope that helps...
Aug 22, 2008 | Maytag MER5775Q Electric Kitchen Range
Maytag MGR4452BDS Stainless Steel Kitchen Range Logo
290 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
