POWER BUT NO ACTION
RED LIGHT ON, BUT WONT COME TO LIFE
  • 1 more comment
  • ktaylo Apr 14, 2008
    My amber light is on, but the W 4200 HD will not power up.
    I have unplugged the TV over night, plugged it back in - nothing happens.
    I have held the power button on for 15 seconds - nothing happens.
  • mgb9076 Jan 09, 2009
    when powering on red power light comes on no picture.
  • Sherry1981 Apr 06, 2009
    I turn on My magnovox and the green light will light up then a few seconds later the red light flashes. No response from the TV. Unplugged it and plugged it back in. Worked yesterday but not today?? Is this fixable??
Push and hold your on power button for 2 seconds worked for me. Thank you
Posted on Apr 05, 2008
  • 231fds Apr 05, 2008
    Thank you
    Problem Solver:
  • 5 Answers
Push and hold your on power button for 2 seconds. Or just hit and hold a channel button for a few seconds.
Posted on Mar 03, 2008
Having trouble with an aftermarket radio hrness in a 2001 saturn sl it wont turn on what can i do
the only 2 wires you dont want to cross are red and black . once you have red from radio red from harness, black from radio black from harness connected it should light up ..the speaker wires can be "trial and error" . if red and black together dosent light it up check the fuse on the radio and on incoming red wire. try bringing 2 wires straight from the battery with a fuse between the red one to radio,if it dosent light up then with "direct power " then the radio needs to come apart to see ether internal fuse or burnt our circuit. ps: sometimes you only need to connect the red "live" wire and touch the black on the casing of the radio to test for life.
May 01, 2015 | 2001 Saturn SL
The switch on our almost new Life Gear Glow 300 hour LED spot light is not working. We replaced the batteries as we assumed that was the problem. When the switch is depressed the light flashes briefly
sounds like the switch is intermittently contacting an needs cleaned , tightened ,or replaced
try some wd 40 in it .it wont hurt the electronics
or take the switch apart an clean
Oct 12, 2014 | LifeGear Life Gear Flashlights LED 300 Hr...
Plantronics ml10
Same problem for me: I start chargering (red light) and when I unplugged It don't power on anymore.
The solution for me was resetting the unit. Follow next steps:
-Start charging the ML10 (a red light will appear)
-Press PowerButton and Volume(-) (a blue/right light will appear for less than a second).
- Voila! It comes to life!
Feb 10, 2012 | Radio Communications
Tv has no life in it at all wont switch on no lights nothing only 2 yrs old tried changing fuse, unplugging from wall but still nothing help me plzzzz
if you have no life and you changed the fuse the you have a dead power supply,.that is the board you replaced the fuse,.is there a red light showing, or flashing, if not then you do have power problem,.did you see and capastors popped,.
Jan 19, 2012 | LG 42LC2D 42 in. LCD HDTV
Tv wont turn on Red standby/temp light and green lamp light are both blinking
The tv projection lamp been inside the tv like 1 1/2 or 2 years already,used tv every day like 4 or 5 hours a daily?The Lamp life are ended.Time to replaced the tv projection Lamp.
Dec 20, 2010 | Samsung HL50A650 50 in. TV
Camera wont charge. green light comes on for a second then a red light flashes and then goes out
This normally indicates a battery problem. Remove the battery and wipe the contacts (battery and camera) firmly with a dry cloth to remove any corrosion that may have built up on them. Heavy corrosion may require cleaning with a fine wire brush, steel wool, or sandpaper. After cleaning, remove any debris that may have fallen into the battery compartment, then insert the battery and connect the camera to the charger. If the green light stays on, the problem is gone and you can charge the battery for several hours and then use the camera. If the red light comes on, it's likely time to replace the battery - especially if it's more than a year old.
HINT: Always remove the battery if you don't plan to use the camera for a week or more. This will prevent corrosion buildup and extend both battery life and camera life.
Bill B
Apr 25, 2010 | Kodak Easyshare M753 Digital Camera
Wont charge
There are 2 possible reasons. Charger is incompatible/defective or Battery is no longer charging due to its 500 cycles life. You may check the output of the charger with Voltmeter/Multimeter if its stable 5V, If its stable then best thing to replace the battery.
Good Luck
Jun 11, 2009 | Kyocera Finecam SL300R Digital Camera
Brother HL 5250 red light flashing
I found this solution on the web-- Hope it helps.
The HL-2070N gets stuck in a toner end-of-life error condition. Perform the following to clear :
With paper loaded, new toner in,
Open front door
Turn off printer
While holding down the GO button, turn printer back on
When all four LEDs light up release GO button. All LEDs will turn off
Press the GO button 2 times. The 3 LEDs (toner, drum, paper) will light up solid
Press the GO button 5 times
Paper light will be blinking
At this point the toner end-of-life condition has been reset. Close front door.
BTW, I got this from Brother Support. Also, just a reminder, timing is important here so don't pause between button presses.
Jan 28, 2009 | Brother HL-2070N Laser Printer
Televison & Video Logo
465 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
