Question about Foxconn (945G7MA-8KS2) Motherboard
MB intermedient Display
Our Foxconn MB is 945 series 45CM-S , every time it not booting. many times it boot in 1 chance or many times i have try several.
It is only 3 months we have purchased.
  • 97 Answers
Could be the PSU is failing
Posted on Mar 02, 2008
Floppy boot disk
Try setting the boot order in the BIOS to floppy drive first. If that does not work, try writing the floppy again, preferably to a different, new floppy disc in case that one is failing.
Oct 21, 2013 | Foxconn Computers & Internet
Hi there, I've got a Foxconn 45cmx mb, A intel Pentium 3.0GHz cpu, 2g ram. I've search for two days now and although I found a lot of similar problems, none is the same. My pc is working fine, I can reset...
Hi, try to replace the cmos battery:
So the bios can remember its settings.
The battery is a watch type 2032.
Once you have installed a new batttery
enter the bios and set the boot sequence
for the harddrive as first boot device
and the cd/dvd as second.
You can download a manual from here:
http://www.foxconnsupport.com/download.aspx?models=&category=C000000001&Series=&keywords=45CMX&sort=
Hope this will help you.
Mar 31, 2011 | Foxconn 45CMX socket LGA775 motherboard...
I get a "keyboard not
Are you using a PS2 keyboard or a USB keyboard ? Check your connection, if you are using a PS2 keyboard, plug in a USB keyboard and see if that works
Feb 11, 2011 | Foxconn FlamingBlade LGA 1366 Intel X58...
Stop at foxconn logo canot run
Go check the connection of the hard disk, try to remove the ide or sata cable and also power supply connection then connect again and reseat properly the ide/sata cable.
Restart your computer.
If this will not work, try removing the hard disk before booting up your computer and see if this go beyond the logo. If this goes beyond logo then hard disk is faulty. May need to partition and reformat thoroughly. Or replacement.
Jan 29, 2011 | Foxconn 45CM-S Core 2 Extreme/ 945GC/ FSB...
Cannot get computer to boot, loops foxconn logo refuses to boot. Tried reinstalling windows 7, crashes. tried from usb flash drive and dvd. The drive lets me install windows and works from another comp....
When this happens, it is either a driver issue, or the Hard Drive is bad. You need to try to bootup in safe mode, F8 at boot time. select, boot to safe mode desktop, IF it boots to this, i think, you may need to install the most up-to-date Video driver, in fact, you should, obtain and have at hand ALL drivers for your MB, and add on's/ This way you can install, in a s situation such as this. Store on a USB drive, and install them off this. Now if you cannot, access F8 or the PC, you need to get into the BIOS, set to boot from DVD, Boot from the Windows, install DVD, now perform a FULL FORMAT, and then try an install, if this doesn't work, either your install disc is corrupt, or the hard Drive is, i would suspect, first the Install DVD and then the HDD, you need to swap out a HDD to check. It may also be a piece of hardware attached too, again swapping out is the only way to track down a problem
Apr 04, 2010 | Computers & Internet
Foxconn 648fx4mr-es boots up no display
u take M.B outside .then u install cpu , agp, ram , power supply ,finish u running . please u try.
Dec 11, 2009 | Computers & Internet
Troubleshoting on installation of mb foxconn 45cmx
have you placed the 4 pin block to the motherboad and also check the bois clr jumper to see if it's not being shorted this can also cause the board not to boot pluse check ram sticks making sure they are well seated and clean the cntacts from dirt on the ram sticke if al gose well and still no boot then get a converter and try this if all else fail try a ney cpu if same resaults then replace board.
Aug 26, 2008 | Foxconn 45CMX socket LGA775 motherboard...
Installation of foxconn 45cmx
Hi aligmatos, it is suggested that you use a 24-pin main power connector if you are going to fill up the motherboard & use a PCI-Express graphics card & Dual-Core Pentium CPU. The power supply should not be less than a 450W for this board, 550W would be better. You can use a 20-pin main connector but its not suggested. Make sure you connect the 4-pin 12V power connector. Your motherboard should still function with a 20-pin main power connector. Again I would not suggest it.
Main web site for Foxconn 45CM-S
http://www.foxconnchannel.com/product/Motherboards/detail_overview.aspx?ID=en-us0000328
Search preformed for Recommended power wattage for foxconn 45CM-S motherboard.
http://www.google.com/search?hl=en&q=Recommended+power+wattage+for+foxconn+45CM-S+motherboard&btnG=Search
Good luck aligmatos!
Mike
Foxconn (945G7MA-8KS2) Motherboard Logo
94 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
