Belkin setup problem
Just bought a belkin N wireless router During the set up it says "ISP did not accept the settings shown"
here is the image which comes up:
Phoned Both ISP and Belkin and they keep passing me from person to person :(
    Scholar:
  • 64 Answers
Hi Anya,
First of all, as far as your ISP is concerned, are you using an always-on connection that doesn't require a username/password (such as basic digital cable) or are you using a PPPoE connection that does require authentication (such as DSL)?
If you're using basic cable, you should be able to bypass the setup and configure it manually if nothing else. Let me know.
Ben
Posted on Mar 04, 2008
My laptop wont log on to belkin
Sir,
Check your IP Address, Maybe its conflict with other device.
My advice to turn it automatically.
Or
Installing your Belkin router is still possible even without using its Setup CD. You can set up your router manually through the web-based setup page of the router.
Perform the steps below to set up your Belkin router through the web-based setup page.
NOTE: images may vary depending on the router model or computer you are using.
Power cycling the modem and router
Step 1:
Unplug the modem and router from the power source.
Step 2:
Connect the modem to the WAN or Internet port of the router.
Step 3:
Power ON your modem first, then your router by plugging them back to the power source.
Manually setting up your router
Step 1:
Connect the computer to one (1) of the Ethernet ports of the router.
Step 2:
Launch a web browser and enter "192.168.2.1" in the address bar.
Step 3:
Click Login.
Step 4:
Leave the Password field blank and click Submit.
Step 5:
Under Internet WAN, click Connection Type.
Step 6:
Select your Connection Type, then click Next.
NOTE: If you don't know your Connection Type, contact your Internet Service Provider (ISP). To know how to set up your router according your ISP, refer to the links below:
Cable Internet Service
PPPoE / DSL
Static IP Account
Step 7:
Enter the details provided by your ISP and click Image.
You should now be able to connect to the Internet. To verify, Internet Status on the upper right corner should read Connected.
You can also launch a web browser and go to your favorite website or try visiting the Belkin Site for more information and support on your devices.
as mention On official Belkin website vedio for Belking Online Support:
Setting up the Belkin router using an iOS device Video
Belkin
Or
In case you still need assistance then follow us for Belkin Tech Support on:Belkin Support
Mar 07, 2014 | Belkin N Wireless Modem-Router F5D8633au4A
Connecting Seagate Backup Plus Desktop drive (STCA3000101) to Belkin N750 wireless router.
Usually you don't need to setup any additional settings or creating new users on the Belkin router to access an USB HDD attached to it, if you used the Belkin Router Manager to set it up.
The Seagate drive you are using have it's own power supply, so that should not be a problem. Also the accepted formats are FAT16, FAT32 and NTFS formatted HDD.
You can try to set it up again using the manager. This is the user manual for your router, if it helps:
http://www.belkin.com/networking/manual/MAN_F9K1103_8820-00778_RevA01_N750.pdf
If you still can't get it working, let me know and we will try to find another solution.
Jan 05, 2014 | Belkin (F5D8231-4) Wireless Router...
Hii there I have bought a Belkin wireless Router G F5D7234-4-H V5. Im from Bangladesh and using windows 7 professional as OS. Several times I have tried to setup using the web browser format which was...
Make sure the you are wired correctly. 1) The incoming cable/dsl to the modem. 2) The modem to the WAN (Internet) RJ 45 connection on the router. 3) The router wired to the computer during set up. You can not set up the router unless you are hard wired to the router.
Then try connecting using the IP address Belkin sent you. Probably 192.168.1.1 or 192.168.0.1. Use Internet Explorer.
May 16, 2011 | Belkin (F5D8231-4) Wireless Router...
How do i connect a belkin router without the software??
You may manually configure your Belkin router. Make sure that the computer is connected to the ethernet port (gray) of the router. Then the modem is connected to the WAN port (yellow) of the router.
On your computer's browser, type: 192.168.2.1
It will prompt you for your password. By default, just leave the password field blank.
Once in the setup page of the router, go to Internet/WAN tab. Under connection type, you need to select the type of your connection depending on your ISP. If you are not sure, contact your ISP and ask them if they use PPPoE (you will also need the username and password for your connection) or DHCP, Static, etc.
Then next and then apply changes. Once the router has the correct settings from your ISP, you should be able to get online.
For the wireless settings, just go to Wireless in the setup page and you may change your settings like enabling wireless security.
I hope this helps!
May 12, 2010 | Belkin (F5D7230-4) Router (587009)
Setting of Belkin Wireless Router Connection
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Apr 06, 2010 | D-Link DIR-615 Wireless Router
Trying to set up router,will not accept my isp info,checked over and over info is correct
Normally, your router is not involved with your ISP. Your router should be communicating with your modem which you rent from your ISP or you own. Your modem, once set up properly, will allow your router to use it. That is whaat DHCP is all about. Let it work.
Dec 27, 2009 | Belkin N1 Vision Wireless Router
New Belkin router wont connect to internet.
your user name and password have been entered incorrectly, they are case sensitive and must be exact. Make sure your ADSL settings are set at 0/38 (you'll see where)
Nov 12, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
We formerly used a linskys router, How can we
if you have not changed any settings from belkin router, access the wireless configuration on your windows machine and search for the belkin ssid then hit on connect
Sep 23, 2009 | Belkin N1 Wireless USB 2.0 Network Adapter...
Wireless security
Just open the link below for the step by step procedure in setting wireless security on your router.
Setting up wireless security on a Belkin F5D7230 Wireless Router:
Dec 22, 2008 | Belkin (F5D7230-4) Router (587009)
Set up my belkin g router
You may have to configure the belkin router depending on the type of ISP that you have.
Basically, you can do these to configure your router:
1. connect the computer to the numbered port of the router and connect the modem to the internet/WAN port.
2. turn off the modem, router and the computer for 30 seconds
3. turn on the modem first, wait for the lights to stabilize then turn on the router, wait for the lights and lastly turn on the computer.
Sep 04, 2008 | Belkin (F5D7230-4) Router (587009)
Computers & Internet Logo
1,143 people viewed this question
David Payne
David Payne
