Question about IBM ThinkPad T22 2647 Notebook
Connecting a T22 Laptop to a Matsui television
Please could you tell me how to connect my laptop to the tv.
I have a 7 pin s video output and the Matsui has two scart socked - Audio out and the aerial socket.
I dont know what I am to ask for when I buy the cable or where to put it.
Many thanks.
  • Naswadi Jun 27, 2008
    I have IBM T22 2647 Laptop It has vga and s-video port but both is not
    working I have download latest drivers but not working please help me
    Thanks
    Farid
  • Elzy Jul 08, 2008
    I've a similar problem, I have an S Video 7 pin connector from my pc to my hdtv but the signal doesn't work as soon as vista boots. However it does work in safe mode, but I can't live in safe mode!
Dear
You suggest does not solut my Problem
Thanks
Posted on Jun 27, 2008
  • 97 Answers
You’ll need two outputs on your laptop that are typically found on most: the first is a small round yellow socket usually found on the back of your laptop, which is the S-video socket. The other socket you need is either a line out (unlikely) or headphones socket (more likely). You also need a TV with the correct inputs, which will ultimately decide which cables you need. The solution you decide on will be determined by your budget, and the prices and codes below are taken from here, so shop around and you may get a better bargain locally or online.
First, you need two separate cables for video and audio: S-video to S-video (£3.60, 35551), and Stereo 3.5mm plug to 2x RCA plugs (£2.80, 35491). Both cables are two metres long and longer cables are also available from the same site. Your TV will require either equivalent S-video and RCA audio inputs or a SCART socket - if it only has the latter, you’ll also need a SCART adapter (£3.25, 35570).
Once done, plug them all in and switch your TV on, switching to the A/V channel. If nothing appears, open the Display Properties Control Panel, switch to the Settings tab and click Advanced. Look for a Display tab or something similar where you’re able to switch on the S-video port to enable the laptop’s display to route through the TV. Finally, when watching DVD movies (you’ll need a DVD player to do so), look for the option to run them full screen, so you get the best possible picture from your TV.
Posted on Mar 02, 2008
Dell 820 win7 conected on tv phillips 32''. Quatro NVDIA nvs 11OM.Their is problem (only on tv) the red color is not displayed.The cable its ok, and the laptop colors are ok. Can i fix it;NiktheGreek
Try connecting the laptop with the same VGA cable to a PC monitor. This will tell you if the problem is with the TV or the VGA output from your laptop.
Make sure there no bent/missing pins on the 15-pin VGA connector ans cable.
May 05, 2018 | Dell Televison & Video
We have a bang and olufsen beovision 7 40 inch tv. when we try to connect our laptop through vga port the tv appears blank without any display, tried connecting the laptop through dvi port also. The...
First, try setting your monitor refresh rate at 60Hz using a known-working monitor. (The VGA input of the Beovision 7 is recommended for 60Hz refresh rate). If this fails to produce output from the Beovision 7, it is very likely, your video driver's resolution is set too high for the Beovision 7 to display signal. If you are using the Beovision 7 as your primary monitor, first connect a known-working monitor to the computer and reduce the resolution to 1024x768. Once you have changed the resolution, try connecting the Beovision 7. If you get video signal, increase the resolution incrementally until you find the maximum resolution the Beovision 7 will handle.
IF YOU ARE USING THE BEOVISION 7 AS A SECONDARY MONITOR USING EXTENDED DESKTOP, reduce the resolution on Monitor 2 output to 1024x768. If video appears on the Beovision 7 at that resolution, incrementally increase the Monitor 2 resolution until you find the maximum resolution the Beovision 7 will accept as a secondary monitor.
Jul 14, 2011 | Televison & Video
Connecting and recording camera with s video output on 1221 tx
The cam setup you're trying in your surgery is similar to the type I often setup in Dental operatories for there intra-oral cameras.
You need an tuner, if your external has S-Video port, you can simply plug into it and use windows media center or the cards software(if it came seperate) to record from the s-video feed.
Then you can hook the S-Video output from the laptop to the TV monitor in question and run the laptop in mirrored mode to show the same image on both screens.
Hope this helps,
Chris
May 26, 2009 | HP Pavilion dv6000z Notebook
Your laptop has Tv Tuner card and if it takes TV input via cable , you get a S-Video / DVD cable to regular cable converter and use the laptop as a video recorder - if you are in US , any Radio Shack will be able to help you with the cables
May 17, 2009 | HP Pavilion dv6000z Notebook
Computer TV output (RCA) - no colour
I had the same problem and nothing worked for me until I changed laptop settings to NTSC_M
So, briefly what I have: S-Video to S-Video cable, laptop (Thinkpad R51, Windows XP, with Intel(R) extreme graphics controler ) and TV set (Samsung, quite old one). The problem was that after connecting my laptop S-Video (4 pin) with S-Video (4 pin) of my TV, I had black and white (no colour) picture.
Solution is the folowing:
- connect your laptop and TV (both S-video 4 pins)
- mouse right click on your laptop desktop screen
- in the popup menu select: 'Graphics Properties'
- "Output to"
- select "TV"
- properties "NTSC_M"
keep in mind that if your are not connected to TV, Graphics Properties don't show TV as an option. So, that was very confusing for me, as I saw similar solution somewhere but was not able to find NTSC_M settings on my laptop
Good luck
Dec 15, 2008 | Computers & Internet
Connecting my laptop to my Samsung DNie 29' Tv
Are you connecting the S-Video directly into the video output port of your laptop? S-Video 7pin? Video output port 7 pin too?
Is there an adapter for the video output port, for your laptop?
Aug 14, 2008 | Dell Latitude D600 Notebook
Connecting to a P.C
It it really has 11 pins I'm not sure but then my guess is that this is the service port connector which normally should have 9 pins. A vga connector has 15 pins and LG (as far as I know) uses standard 9 pin serial ports for service and plain old dvi or vga ports for connecting a computer.
Please visit Hardware Book for more info on connectors and cables.
Jan 15, 2008 | LG RZ-20LA70 20 in. LCD Television
How to connect my Sharp LC-26DA5U to my computer as a monitor
There are two possible problems: 1. You are connecting a 15-pin (on the laptop) to the 9-pin (on the TV) connection. This isn't the video-in connection for the TV. The TV has a DB-15 connection near its DVI input connector. You should be using a 15-pin to 15-pin cable. The DB-9 connector on the TV is a serial port for servicing the TV. 2. You aren't enabling the external video port for the laptop. Try hitting Fn+F5 on the laptop to cycle between the three display modes: laptop only, laptop + TV, TV only. Make sure to wait a few seconds after hitting Fn+F5 to let the displays sync up.
Feb 20, 2007 | Sharp LC-26DA5U 26 in. HD-Ready LCD...
IBM ThinkPad T22 2647 Notebook Logo
571 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
