SOURCE: My Wacom Intuos3 tablet won't switch into pen mode
I had the same problem with my Intuos3 on Vista. Tech support suggested the following.
Do this.....Go to Start--->control panel---->system(in classic view)---->device manager--->click on "human interface devices"--->then click on "Wacom virtual HID driver" and right click on that and disable it. Your computer will ask you to restart and you will want to do that.
Everything works fine now.
SOURCE: Wacom Tablet...PEN not WORKING!!!!
go into the system preferences. mine shows up under other. click the tablet icon. go in and under tool erase the existing mouse and pen tool. then put each item on the tablet pad so it will recognize them. They should then reload into the tools section and be reset to the original settings.
SOURCE: Wacom Tablet overly sensitive
I also had this problem. Then I tried changing the frimness of the pen, and now it works perfectly fine.
Go to Pen Tablet preferences, then in the Pen tab, change the softness scale to "Firm" then it should be fine.
The winning answer came courtesy of Mr Benedikt Schmitt of Wacom Europe, who offered the following solution: from the Windows Device Manager, disable the “Wacom Virtual Hid Driver” device. (Go to Control Panel > System and Maintenance > Device Manager, find the driver, right-click it and choose “Disable”.) One reboot later (welcome to Windows-land, circa 2008?), everything works as desired. Pressure and tilt sensitivity inside Photoshop still work, and the pen functions just fine in the rest of the Windows desktop. The absolute mapping makes it an absolute pleasure to point quickly and precisely. It makes my laser mouse feel rather clumsy navigating a large 24′ screen!
To make the 1st solution even easier, disconnect the tablet from the usb port, lay the pen flat on the tablet surface and plug the tablet back in. Worked like a charm for me.
www.manualslib.com/manual/121620/Penpower-Tooya-Pro.html
