Question about EPoX EP-4PLAI Motherboard
Help!!!!!! can you give me an idea how to fix my pc problem?its difficult to me to understand because my pc have a long beep again even i clean the memory and connect it again in the slot1 and slot 2 but when i tried to clean my memory and video card with eraser of a pencil sometimes i heard a long beep and sometimes it have no beep but no appearance on the screen?pls help me to solve this my memory is tested by memtest and no error was detected and is new with warranty
  • enigma pulp Mar 02, 2008
    help me my friend
    Scholar:
  • 93 Answers
If ram is ok, check processor and PCI devices, if these are all ok chances are your motherboard is dead
Posted on Apr 02, 2008
  • David Moulder
    David Moulder Apr 20, 2008
    you need to go back to basic, un plug everything, hard drives, dc drives, take the video card out, and anything else you have plugged into PCI, take 1 stick of ram out, so that all you have connected is motherboard, CPU and 1 stick of ram, make sure motherboard has power and turn the computer on, if you get a boot screen and it starts OK, plug the video card in, if it beeps after that, change video card, if it doesnt, plug the next thing in, it will give you an idea what component is causing the problem
  • 73 Answers
Hi jake_ponce,
first step: just check the ram with ur friend pc if he has good pc if the ram starts in ur friend pc it means ur pc does not support ram of high speed
second steps; beep is coming again the problem will be in a motherboard
third steps : beep is coming again remove ur cmos battery & try again if again beep is coming than ur ram is burn
Fourth steps:beep is coming thantake it to the shop & tell him is not working
Fifth steps: it has a warranty the shopkeeper will replaced it
regards
shailesh
Posted on Mar 11, 2008
2 Suggested Answers
vhal
  • 17 Answers
SOURCE: cant run
Kindly check the placement of your memory card if it is place correctly. it should fixed firmly and tightly. If there is an error again, try to check your video card if there something damage or anything there. and if there is no other way, clean it again and try to dry them up with hair dryier but check the temperature for safety.
me reynald from philippinse..tnx
Posted on Mar 03, 2008
My m/b is Compaq BL30G and recently i had to reinstall winXP and it automatically installed audio driver (intel(r) 82801BA/BAM AC`97) but now it gives a continues "beep" sound. I even tried...
First of all open your chassis and then reconnect all the connection and remove hard drive. If you have two RAM in your PC then remove one RAM Now plug the power supply and ON the machine. If it is giving beep sound then press esc again and again untill the beep sound could be stopped. If it is continuous then remove the RAM and fix the other one then ON the machine And if it is giving beep sound the press esc again and again. Before fixing the RAM you have to clean the RAM with a soft cloth smoothly. I hope this can work for you ! and beep sound is stopped then attach your HDD then ON the PC
Sep 14, 2011 | Abit BL7-RAID Motherboard
My computer won't boot up and the orange light just stays on. The moniter is working, the fans in the power supply is working. I was fine yestyerday. I put in hibernate and tried to cut back on today...
Remove the RAM and install it again and restart.....it will work if still not work then change remove RAM again and start your machine..it will give beep sound...if it will not give beep sound then understand your machine's mother board is faulty......
Sep 09, 2011 | E-Machines eMachines Desktop PC
Acer aspire T180 wont start screen says no signal input computer is beeping cant tell beep code possibly 2 long beeps repeated or just one long beep repeated
Remove the side panel and remove the RAM.
Clean the RAM slot with dry brush or cloth.
Clean the RAM.
Fix the RAM back in the slot.
Close the cover and Start the PC
If you feel that my answers have helped you getting solution to your problems then please give a vote.
Thanks.
Jul 13, 2011 | Acer Aspire™ T180 PC Desktop
My Dell Inspiron E1705 PC Notebook two light just blinks and doesnot boot
make sure the ram is properly installed just remove ram and check it give the beeps if it gives the beep that means board is ok clean the ram with pencil eraser and fix it again.
Have a nice day and do not forget to rate please...!
Dec 27, 2010 | Dell Inspiron E1705 Notebook
My e-machines etower 633is won't boot up. The beginning black screen comes up then the E-machines screen and that's as far as it will go. It gets stuck there. Can you give me some idea what is causing...
I cant really seem to understand but if the computer beeps then you should take the RAM out and clean it and re-insert it. and try again. Sometimes the processor can give that kind of problem if it is faulty.But if after cleaning the RAM it still doesnt work please take it to the tech department.
I hope this solution is helpful.
Sep 26, 2010 | E-Machines etower 633is PC Desktop
My Computer Beeping when star-up. The Beeping sound is continue such as Beep...Bee...Beep...Beep..until I force it by pressing the start up button to stop it total. I think due to the new mouse and...
Beeps always indicate error excluding a one single beep only which indicate process.Every manufacturer has its own beep setting. it comprises on short and long beeps. If previously it working good, then your idea may be correct. replace both the keyboard and mouse with existing. start computer if now it not giving beeps it meant that one of them is causing problem. connect one by one and start computer you will reach. AND if even after replacing keyboard and mouse it gave beeps then shut down your system. Open casing remove processor and memory chip out and connect them again it will work now INSHALLAH.
Sep 24, 2010 | Computers & Internet
Hp tower will not reboot
Sorry to hear you're having problems.
As simple as it sounds - remove the cover and blow out the system.
I hear that Best Buy and Staples are giving free check ups. I would check with them for the freebee and not tell them it isn't booting. Just an idea - sneaky in a way but I have had pc's not boot and them after a cleaning boot right up.
This isn't a permanent fix you understand.
Best of it
Rice
Mar 28, 2010 | HP Compaq dx2300 Microtower - RT950UTABA...
Cant run
find an old graphics card (maybe the swapmeet) and try that. When installing the devices hold cards from both ends and push in evenly. The problem is most likely installation.
Count the beeps and which ones are long and short.
For example: two long beeps and three short ones.
Then in google lookup your bios beep codes.
For example: Award beep codes
There you will get a definite answer to what is ailing your machine.
Mar 03, 2008 | EPoX EP-4PLAI Motherboard
EPoX EP-4PLAI Motherboard Logo
83 people viewed this question
Top EPoX Computers & Internet Experts
Marvin
Marvin
David
David
Steven Wander
Steven Wander
Are you an EPoX Computer and Internet Expert? Answer questions, earn points and help others
