The water isnt heated up.
I have replaced the themostat - but to no avail.
I have used an ohmmeter to check the thermostat and both of the heaters near to it -both are closed circuit which means they probably work - any more ideas.
have you also a circuit diagram as it could be a broken wire somewhere.
Find your thermal protection switch. It looks like a big round button with two screws holding it on either side. (Make sure your drier is unplugged!) There will be a wire going from it to the heating element. It is what regulates the temperature, so it doesn't overheat. Unplug the wires off it and check across the terminals with an ohm meter. It should have full continuity. If not, it's your problem. Replace it. Easy repair.
Check the continuity of the cycling thermostat using an ohmmeter set to X1. Disconnect one wire from the cycling thermostat terminals then connect one test lead of the ohmmeter to each terminal. The reading is zero ohms for an apparently good thermostat; further test is required to check its operation.
Unscrew the cycling thermostat from the heater housing and pull it out of the dryer. Using a pair of needle-nose pliers or similar tool, hold the thermostat over a burner and verify if it clicks when heated. Carefully check the continuity immediately before it clicks again. The ohmmeter reading is infinite (open) and zero ohms when the thermostat cools down and clicks again. A good cycling thermostat cycles off when heated, and on when it cools down.
Every heating circuit component in the heater housing need to be checked when the dryer is not heating. Set the ohmmeter to X1 and measure the resistance between the heating element terminals. The resistance depends on the model of your washer. Replace it when the ohmmeter reading is infinite (open).
The thermal cut-off fails when the cycling thermostat fails to cycle off. Check the continuity of the thermal cut-off. Disconnect one wire from its terminals and connect one ohmmeter test lead to each of the terminals. The resistance is zero for a good thermal cut-off.
A blown thermal cut-off is an indication of a failed cycling thermostat. The cycling thermostat must also be replaced when the thermal cut-off is blown. Just unscrew the blown component and screw the new component in place. Specify the brand and model number of your washer for the specific replacement parts.
Warning: Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
It will be a faulty thermostat or element more than likely, or a broken wire.
Remove top cover, and you will see the heater manifold over to the right side, there you will see the element and thermostats.
You will need a meter to test them.
Hope this helps.
filter is located at the bottom rear of the appliance... if its pump obstruction then to lay the drain hose into a bowl is a means of getting the water out manually.. if its a blockage and water wont drain this way then lay the unit down on its R/H side (not soap dispenser side)....then acces to the filter can be made without flooding the place..best if 2 persons were to do this as the machine can be heavy when full with water and clothes.. best of luck..
its seems you're doing your home work. that cylindrical part is the thermostat itself. it should have a resistance in the range of kilo ohms. around 10 kohm to 25 kohms. you can try to change the range of your testing equipment so that you could be sure that te thermostat is really open circuit.
if there is no resistance, then that is the problem. if there is resitance in the kilo ohms range then it could still be ok and you need todo some further testing.
you can check for voltage presence at the terminlas of the heater. if there is no voltage then it could be the relay on the power board that supply voltage to the heater.
or the board itself.
i hope i was able to help..please rate me..tnx
drcool299
First check the one shot thermostat - thete are 2 stats on the top of the heater box - it's the one with the staggered connector terminals - then let me know
The t-stats have blown.. these are located on the top of the heater on top of the drum.. To check to see if their blown check the continuity if they are blown then there will be no continuity ... They come in a pair and are easily replaced.. All you have to do is take off the lid...
