Question about Ovens
Fan direction for Creda Concept Solarspeed cooker
Have just fitted a new oven fan motor and the fan turns clockwise but the arrows seem to indicate that it should turn anticlockwise. Can anybody advise please?
barkencoa
  • 3463 Answers
SOURCE: can not reset clock or timer, oven will not work
Try pressing the first 2 buttons on the left, and the last button on the right of the timer all at the same time.
It may differ to this depending on the actual model, but it is usually a combination of 2 or 3 buttons.
Hope this helps, if it does solve the prob, please feedback.
Thankyou.
Posted on Dec 21, 2009
  • 157 Answers
SOURCE: I need a new element for my Creda fan oven but
what do you want model creda concept 46307
Posted on Mar 09, 2010
  • 40 Answers
SOURCE: creda cf50g cooker oven not getting hot
sounds like the ffd is at fault, this is a safety device that alows the main flow of gas through. when the cooker is cleaned the sensor can be moved by accident from its position over the flame, another reason could be a build up of grease etc, stopping the flame reaching the sensor. if none of these then the ffd unit needs to be replaced. they are about £20.00 for the part
Posted on Apr 07, 2010
blackmar
  • 235 Answers
SOURCE: Creda Concept Solarglo Cooker. Grill
Most common problem is that the grill element is probably faulty/blown. Also check the wiring at the grill element terminals as wiring sometimes burns off. The grill controllers don't normally get faulty as they generally last a lot longer than the elements.
Posted on Feb 12, 2011
Testimonial: "Many thanks for the prompt reply. I'll follow up your recommendation!"
SOURCE: How to change an oven lamp in a creda concept oven
Hi
Got a Creda Europa oven/grill and the control panel will not illuminate at all? Any suggestions as to how i get front panel off to replace strip light in behind would be appreciated email gary.connell@talk21.com
Cheers
Posted on Dec 16, 2011
Creda concept c361e main fan oven not working have installed new element
Also check the thermostat as these can fail and stop the oven working. If that is OK, then check the operating switch.
Feb 29, 2016 | Creda Ovens
Hi, the oven is not working in my Creda Collection freestanding cooker. I have had the element tested and proved to be ok. Also the fan does not move. The timer is set to manual. Can you assist?
If the element is okay and the element and fan aren't working together then it will be a problem further up the line. The next question I would normally ask is is the electronic timer in manual mode. When you turn the oven on does the oven indicator light come on?
Feb 17, 2011 | Ovens
Creda Concept Solarglo Cooker. Grill not working. Elements seem ok as top oven works fine. Any ideas gratefully accepted! Thanks in anticipation.
Feb 11, 2011 | Ovens
How do I remove the fan from an electrolux EGC652 oven
The model no. does not seem correct.but it seems as if the hole in the fan blade which is normally D shaped has worn round.The thread on the shaft is Left handed and you will need to undo by turning clockwise. If you can get a vice grips at the back of the blade to hold the shaft then try again,or you will need to get into the back casing and try jamming the shaft at the motor housing you may need some help.Then if that works you will need to undo the 3 bolts holding the Motor body to the rear casing.The new fan would normally come with new bolts,blade and nut.To tighten fan blade nut use a 10mm socket hold the fan blade and tighten anticlockwise.Hope this is helpful.
Good luck.
May 04, 2010 | Electrolux Ovens
How do I change the fan oven thermostat on cooker Tricity Bendix SIE 531 TCGR
These will give you the basics
1 How to change a fan oven element and How to change a cooker oven fan Motor
2 How to fit a New Thermostat to a Cooker or Oven
If you have a electric Cooker or Fan Oven which is not heating it could be one of the following problems.
3. If you have the opposite problem i.e. your oven is over heating and burning everything then you will need to replace your oven
thermostat
Mar 04, 2010 | Ovens
Hi
Cheers
Aug 09, 2008 | Ovens
Hotpoint fan oven motor removal
hi it is left hand thread i just checked it with a brand new one i have here :- turn the spanner or socket to the right to take it off
Mar 11, 2008 | Ovens
Ovens Logo
207 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
