Question about Samsung PCL545R 54" Rear Projection Television
Skewed picture picture bowed, fuzzy, all writing appears in triplicate (red, white, blue)
  • whorl Mar 11, 2008
    Turned-out to be a convergence problem. Tech had to get code from Samung to make additional adjustments.
  • 42 Answers
Is it a projection? DLP? LCD? etc... depending on the type the suspicion i have is it is out of focus.  The symptom of writing triplicate comes from the thing being out of wack.. a tech needs to fix it.  all this is assuming ;you have a projection tv of some sort.
Posted on Mar 08, 2008
I have a 60 inch Philips tv and the picture is kind of blury and a little red. What is tha caused from?
THREE possible reasons for this:
I will list each and describe for you:
1.) If redish picture go to a black and white channel; is the screen somewhat red or black and White? This is adjustable from inside the set.
2.) If colors are skewed or look like they have a red outline it may be a convergence problem. See attached photo.
3.) Some of these sets develop a problem with the coolant which is used to keep the face of each of the three tubes cool; it is called Glycol. You would have to remove back cover and with set on look into each of the three lens (red,green,blue) to see if you have a clear red, green and blue picture.
Which best describes your problem?
Aug 10, 2010 | Philips 60PP9352 60" Rear Projection...
Red and fuzzy picture can you help on my 50 inch phillips magnavox projection TV
This is a very common failure on Projection TV sets.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
The other common problem is cloudy lens fluid. After many years the coolant in the blue and green lens will become cloudy and cause the screen to look dull, red/orange, bright white, etc. You may even see halos around video.
You can see some example photos and find a solution here on Fixya.
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 25, 2009 | Philips Magnavox 51MP392H Rear Projection...
Picture was fine, then lines diagonally, now light
Projection sets have two very common problems outlined below.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can more info and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya
Oct 10, 2009 | Mitsubishi WS-55909 55" Rear Projection...
BOW PICTURE AND HUE GREENS REDS AND BLUES LIKE SHADOWS
the tv had intermittant solder connections already but h\they appeared when the tv was moved to hook up the digi-box. The solution could be as simple as resoldering the power convergence amps.
Aug 06, 2009 | Televison & Video
Skewed picture
you need ned convergance chips
Mar 22, 2009 | Mitsubishi VS-60621 60" Rear Projection...
Tv colors and bows
sounds like convergence ICs but I dont have any info available on the VS55601 model number.
Jan 27, 2009 | Mitsubishi VS-55601 55" Rear Projection...
Triplicate picture.
i had the same problem.trawled the net and tried this advice ....thump the thing around top and sides. it worked for me, it was something to do with bad connections in a soldered joint.problem will probably get worse though
Jan 23, 2009 | RCA P52926 52" Rear Projection Television
RCA P61940 PROJECTION TV
No adjustment will fix this, what has happened is a power supply board for the convergance has failed and needs to be replaced or repaired
Mar 07, 2008 | RCA P61940 61" Rear Projection Television
Orange and fuzzy
have the optical engine replaced
Jan 01, 2008 | Zenith D52WLCD 52" Rear Projection...
Samsung PCL545R 54" Rear Projection Television Logo
75 people viewed this question
Jerry Greenberg
Jerry Greenberg
