Question about Jobo Giga One 40GB Portable Storage MP3 Player
Jobo Giga One free space problem
I have a Jobo Giga One 40 Gb portable disk which I use to store photographs from the CF cards from my Canon DLSR camera while I am away from home. Returning home I will copy all the photos to my PC and erase the files and folders from the JOBO device.
I do this using Windows XP Explorer/File Manager and do this by 'Shift-Delete' so that the files and folders are deleted and NOT saved in a Recycle Bin. So right now Windows tells me the the Jobo disk has over 39 Gb of free space. I have checked that there is nothing in a Recycle bina nd there are no hidden files or folders. BUT the display panel on the JOBO device tells me the I have only 1 GB of free space and if I try to copy a CF card with say 1.5 Gb of data it gives me an 'ERR' message. So my JOBO device is now unusable even though it is completely empty.
How can I get the device to reset the free space so that it correctly shows what is available ?
  • 5 more comments
  • Ian1947 Mar 02, 2008
    Yes ? Can you offer a solution to the problem ?
    I doubt your suggested solution.
    I have a fully up to date antivirus system installed so there should not be any problem with a virus. Even if there was then it would affect Windows view of the device. Windows shows that there is over 39 GB of free space. I have set the view options for the device to show all hidden and system files and there are none apart from the usual Recycled and System Volume Information.
    I have considered reformating the device - there would be nothing to lose because it is empty. But the device as shipped is formatted with a FAT32 file system. If I try to reformat that with Windows XP it says that the device is too big for a FAT32 file system. I do not want to format it with an NTFS file system because I do not know if the JOBO software/firmware is compatible with that.
    Any other suggestions ?
    I think the proble is with the JOBO firmware/software. It needs to reset its free space counter.
    I am well aware of how to format a drive. I have been a PC Systems programmer since the time of DOS3.3 As I have already stated, Windows XP will not let me reformat the drive as a FAT32 file system because it says that the disk is too big for that file system. The problem is not with Windows view of the device it is with the JOBO's view of the state of the device.
    Nothing helpful so far.
    I have already tried to format the external disk. If you right click on the disk and select 'Format' it only gives you an NTFS option. If you open a command prompt window and try a 'FORMAT M: /FS:FAT32' it verifies all 38154Mb then says that it is too big for FAT32. Which is to be expected since WIndows 2000 and XP arbitraily imposed a disk size limit of 32 GB for an FAT32 volume.
    I do not tink I have the option of formating from an XP boot disk as I only have a manufacturer's 'Recovery' CD which I am reluctant to boot from. Anyway, why should it be any different in terms of disk size limit.
    Let me restate the problem
    -Windows sees the disk as empty apart for the usual system files and is a perfectly normal well functioning external disk
    -the display panel on the JOBO GIGAOne says there is only 1GB free
    So surely this is a problem with the JOBO hardware/firmware/software, it is not a Windows problem.
    Thanks Pincer
    - I did a chkdsk /f and it converted three lost clusters to files which I then deleted. I then powered off/on the JOBO device and it came up showing 38GB of free space.
    Genius:
  • 1,665 Answers
Hi have a nice day!
Perhaps you have used "fdisk" command to delete-create logical drives, and then format NTFS file system.
Please let me know if this way is applicable
Posted on Mar 02, 2008
    Master:
  • 377 Answers
Why don't you try to format your external drive. There's a variety of options where you can format it. The first one is Go to the My Computer then Right Click on the Icon of your External Drive then Select Format, it is better to select full erase of the the drive.
  • 6 more comments
  • pincer
    pincer Mar 02, 2008
    Just follow first my instruction's before you go on to the most complicated one.
    See yah!
  • pincer
    pincer Mar 02, 2008
    Format it on Win XP boot disk.
  • pincer
    pincer Mar 02, 2008
    i think you know that part?
  • pincer
    pincer Mar 02, 2008
    THe installation disk of XP can reformat your drive, there's also a FAT32 option type.
  • pincer
    pincer Mar 02, 2008
    FDISK on XP?
  • pincer
    pincer Mar 02, 2008
    Be sure your drive got no "bad sectors"...
    Try CHKDSK with the drive letter you wan't to Scan...
  • pincer
    pincer Mar 02, 2008
    Lost clusters are storage units undocumented by the FAT (file allocation table) holding partial files at the end of a chain (a sequence of clusters storing a file on a hard drive). These clusters are lost because the FAT was disrupted, perhaps by a power loss or application crash, before it could fully document the chain.
    Windows runs the ScanDisk (Win95/98/Me) or Chkdsk (WinXP) utilities to make sure there are no resulting file errors. ScanDisk and Chkdsk can turn stray pieces of files, or lost clusters, into file fragments for your review. You should review the file fragments Scandisk finds instead of letting it delete them sight unseen. After all, you may be able to rescue parts of some of those file fragments.
    Thanks,
  • pincer
    pincer Mar 02, 2008
    See...! i told you, there's many possible ways i can help you.. at first you never believed on what i say to you..
    anyway, got your player working, and you never gone up which i say to you the most complicated one of what you think first..
    Cheers.
    Guru:
  • 1,894 Answers
Hello sir
  • dewan nafees ahmed Mar 02, 2008
    ya sir
    its not about resetting the device
    its the virus which has changed the file properties and makes it hidden
    the virus may belong to rontok bro family of virus which does this job
    this can be solved in 2 ways
    1>> install a antivirus of enterprise edition and update it for todays update and then check for virus and delete it
    2>> else you will have to loose your files and delete everything(format) the whole drive
    your option is to use any one of these
    thank you sir
    good luck
    have a good day
    dont forget to rate the solutions
After deleting pictures I never get 40GB of memory space back
I found the same thing. Had to go to "my computer" , load up the photobank icon.
Click on the cards folder and then delete each folder.
THEN ,after clearing off the photobank, go to the desktop and empty the recycle bin. You will get the 40gigs back.
Feb 09, 2010 | SmartDisk PhotoBank PB40 40 GB USB 2.0...
Canon 40D and 64Gb CF Card
What i find is that the larger the card the slower the write recovery in taking pictures. If you are an action photographer this is a pain as things happen fast . To have the camera take so long to recover from a write leaves you open to losing some excellent shots. So my rule of thumb is use smaller value cards. If you are just a happy shots photographer then this probably doesn't really matter.
Thanks for using Fixya
Sep 15, 2009 | Canon EOS 40D Body Only Digital Camera
Giga ONe hard drive reformat
You can format your giga one hard drive in MS-Dos mode.
1. Go to Start--> Run
2. type CMD to enter the DOS
3. select the giga one drive path (i.e. if it shows as E drive then simply write E: in DOS and hit enter.
4. type format
thats all that you have to do to format the giga one drive.
Jul 28, 2009 | Jobo GX1040 GIGA ONE Silver 40GB Portable...
Lost 40Gb of photos-7Gb not lost.
First of, I suggest you use USB Flash Drives of High Value., like 500 to 1G. Or a second Hard Drive 2G.
If you lost 40G of data, it is gone. Just remember to use the EJECT format to remove all external devices. If you do not, you can loose data.
Feb 15, 2018 | Jobo GIGA Vu PRO evolution MP3 Player
Fromating Giga one
you need to go to the jobo site, find the driver/software/service link, in that you will find the giga one formatting tool, download and use that. i had the same problem when i purchased my original giga one, i used windows to format the drive - but as people find out windows is unable to format the drive correctly ie fat 32, and you then get an error message. in the formatting tool it tells you why what the different error codes are and error 1 means drive not formatted to fat 32, im not sure how old your giga one is but when i purchased mine approx 4yrs ago it never came with a proper manual and there was no support on the jobo site at the time. I think a lot of these minor problems could be avoided if it came with a manual and explained whats needed to clear the internal hard drive
Mar 19, 2009 | Jobo Giga One 40GB Portable Storage MP3...
My Giga Vu Pro 40 gig will not charge
Have you talk to Linda?
Try Lynda@jobo-usa.com
Jan 30, 2009 | Jobo GIGA Vu PRO evolution MP3 Player
I have 2 problems with 2 photo storage devices
my company the IT Partnership might be able to help , but i need more details of how the devices failed and what is their current state
Jan 25, 2009 | Jobo GX1040 GIGA ONE Silver 40GB Portable...
Wont switch on.
removed the battery & put it back after 42hrs.. just to reset and delete the settings you made there..
Post back again, & feel free to contact me..
~pinc
Apr 28, 2008 | Jobo GIGA Vu PRO evolution MP3 Player
CF card problem
Try a CF card reader. If that shows no files then try some file recovery software with the card reader acting like a drive. There are some nice freeware programs that might help. It may be that the files are corrupted then the solution is more difficult. Good Luck!
Aug 31, 2005 | Canon PowerShot A80 Digital Camera
Open Questions:
See all Jobo Giga One 40GB Portable Storage MP3 Player Questions
Jobo Giga One 40GB Portable Storage MP3 Player Logo
651 people viewed this question
Top Jobo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Jobo Audio Player and Recorder Expert? Answer questions, earn points and help others
