Question about Canon PowerShot A450 Digital Camera
Can't Take Pictures
Everything is working on the camera display and the zoon feature and it has new batteries, but when I push the shutter button nothing happens. I have it set on Automatic and I have tried to determine if I have some other setting wrong, but I cannot find anything. Whatelse can I do/try? Thanks.
  • Canon Master
  • 4,738 Answers
Please see this post from someone with a similar problem: http://www.fixya.com/support/t415564-picture_when_flash_turned
Charging of the flash may be overpowering the batteries that you're using. Are you using alkaline batteries? If so, recommend instead trying rechargeable NiMH batteries rated at least 2500mah to see if the problem still exists. Walmart sells these for around $7 for a package of four (about $15-19 for the batteries with charger). Keep in mind they'll save you big bucks in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may slap yourself for not buying them sooner.
Posted on Mar 02, 2008
Shutter-release button doesn't work
The manual only can give two reasons why the camera would not take pictures.
One, there is no memory card placed.
Two, the memory card is full.
You are sure you have placed a working empty memory card.
If you did save all the pictures on the memory card to a computer, try formatting the card in the camera.
When you are pressing the shutter release button half, does the camera say it is focused correct? light bottom corner of the display.
Your camera has a setting to take pictures with a remote control. Did you put the camera in that setting? Read page 76 of the manual.
success
Jan 16, 2014 | Konica Minolta DiMAGE A200 Digital Camera
Panasonic Lumix digital DMC-FZ7 not working.
If the camera is new[ i year or less] then it will be replaced by whereever you bougjt it from.
If you are having difficulty with this contact Panasonic support
Dec 31, 2007 | Cameras
Display not working
if shutter is working it is the dfective CCD so replace the CCD.
Apr 03, 2010 | Kodak EasyShare C533 Digital Camera
Power failure upon pressing shutter button
hi
dear ur battery is not working properly replace the battery
Dec 14, 2009 | Canon EOS 40D Digital Camera
Battery level don't show on display.
hi friend,
follow these steps
  1. Turn off your LCD display screen. I know this is hard—who likes shoving their face against the camera to compose a shot through the little viewfinder? But the LCD screen single-handed-ly drains a lot of power.
  2. Minimize the picture preview to the least amount of time possible—usually one second. This uses less LCD screen time, thus less power.
  3. Dim the brightness on your LCD screen. A dimmer display extends battery life by consuming less power to light the screen. This might make the display harder to see, but usually only in direct sunlight.
  4. Set the power saver to the least amount of time. Power saver lets your digital camera “sleep” when not in use, but doesn’t shut it down entirely. To “wake up” your digital camera, simply click the shutter button.
  5. Use your zoom as little as possible. The motor that moves the lens uses power. This also goes for repeatedly turning your digital camera on and off if it has an extend able lens.
  6. Turn off the continuous focus. Again, constantly using motors and electronics to ready your shot drastically minimizes battery life.
  7. Don’t push the shutter button half-way down until you’re ready to shoot. Pushing the shutter button (constantly resetting and refocusing) will drain battery life.
  8. Use the flash only when necessary. Your digital camera’s “auto flash” option should take care of this, but make sure your flash isn’t going off in broad daylight.
  9. Don’t delete pictures from your digital camera unless necessary. This consumes power. Wait until you download the pictures to your computer before deleting.
  10. This one’s basic, but charge your battery often. Lithium ion batteries, which most digital cameras use, don’t have “battery memory” like older alkaline. In fact, lithium ions work better and last longer if charged completely and regularly.
thank u for using fixya
regards,
sivaranjini
Aug 11, 2009 | Kodak EASYSHARE M1063 Digital Camera
My shutter will not open. The power button presses in and nothing happens. I have since got a new battery that was the problem, shutter still will not open. Camera is not operative, please...
Can you get any signs of life? playback pictures etc? Try pressing the playback button instead of the power button. If camera display works then press the picture button and see if the camera will switch over and the lens extends. Also check if the tab on the battery door is not broken. This operates a micro switch to cut off power
Jun 19, 2009 | Fuji J150w Digital Camera
Displays all white in all modes. Kodak V570. Turn the power on and all I can see is white. I have tried a different battery an no battery, just power cord. I know the camera good enough I can go into the...
displays all white because all the color screen have RGB mode if any of mode's are not work correctlly it's mean's color chip was fail and not working. u have to repair ur camera and change ur display screen.
Mar 01, 2009 | Kodak EasyShare V570 Digital Camera
HP R707 wont take pictures - get F2.8 1/60 message
Does it work while connected to charger? If yes, you need a new battery.
Feb 04, 2009 | HP Photosmart R707 Digital Camera
Shutter release
Hi , to release the shutter open the lense and push shutter button , rotate the camera mode to auto or manual release shutter.donnot set on bulb or lower speed can cause stuck camera miror and stter curtain, or blade.
Feb 19, 2008 | Photography
Canon PowerShot A450 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
