Question about Panasonic AJ-D230H DV/Mini DV VCR
Error E-11 When inserting MiniDV Casette (via the cassette adaptor Panasonic AJ-CS750P) I get the error code E-11. In the manual E-11 is: "The reel base which operates in accordance with the size of the tape has been locked or more than 2.5 seconds" - however it does not suggest any way to fix this error (and I'm not even sure that I fully understand the error). Does anybody know how to fix this problem, so that I can play my MiniDV Cassettes in my Panasonic AJ-D230H?? Anders, Denmark. PS:Does anybody have experience with buying add-ons to enable Firewire connection between a MacBook (or older labtop Mac)?? Does it work well?
    Champion:
  • 221 Answers
Most common cause for this problem is defective electrolytic capacitors on the mechanical interface board. a good electronic tech should be able to replace them.
Posted on Mar 26, 2008
I have a Sony Handycam DCR-PC100 that is now flashing an error code C:31:23 in the display when I try to play back the DV cassette in the video camera. Please advise what this code means and if the footage...
  1. Remove the battery or disconnect the AC power adapter for 60 seconds.
  2. Insert the battery or reconnect the AC adapter.
  3. Turn on the camcorder.
  4. If the error message appears, service may be required.
If your camcorder still shows the same error code, then you'll have to send in your camcorder for service.
Try playing the dv casette on another player, it should be fine.
Aug 11, 2008 | Sony Televison & Video
Why is my handycam beeping c:31:23 when I turn it on?
Dear Friend,
While asking your query you should have given full information regarding your product like: Brand Name ( Sony; Panasonic; etc) Model :( DCR-HC42 etc) and more description of the fault.
From your question I understand that you have a Sony handycam and it gives error massage of C:31:23.
Sony has defined Self Diagnostic code for each product. According to which your handycam has Supply Reel Fault ( Try using other cassette, if it is resolved ). This code is generated when the supply reel is not rotating while cassette is loaded.
If supply reel is rotating and still you see the same error code, the there are chances of :
  1. Problem with reel sensor of camera
  2. Problem with End sensor of camera
If problem remains unsolved, best thing you contact nearest service center.
Dec 24, 2010 | Cameras
GR-DVL320 keep getting E03 error indication. Ejecting and reinsertion of the tape does not seem to be fixing the problem, also says unit in safeguard mode. What do I do to remedy this?
1. The idler gear does not engage with the reel disk well.
2. Though the idler gear and reel disk are engaged with
each other, the tape is not wound because of overload
to the mechanism.
3. No FG pulse is output from the reel sensor.
4. No power is supplied to the reel sensor.
5. Tape transport operation takes place with a cassette
having no tape inside.
6. The tape slackens and no pulse is produced until the
slack is taken up and the tape comes into the normal
Sep 02, 2009 | JVC GR-DVL320 Mini DV Digital Camcorder
It does not eject the tape,it gives out error c3211
Reel of the cassette must be stuck inside. open the top cover and have a look inside. release the reel if it is tangled up inside. Reset the switch at the bottom of the frot pannel and try to eject the cassette. It will slove your problem. If it is not then you must consult the nearby sony service centre.
Aug 07, 2009 | Sony DSR-45P DV / Mini DV VCR
Tape deck no longer plays large DVCpro tapes
the tape compartment elevator has switch senors that tell the machine what size tape is in..
does the tape load all the way.. you need to tell us
is there an error code ?
either the sensor or the reel motors the feed and uptake the tape,,
they ride on rails and slide into position to accomodate the tape side they could be having trouble moving, dirty, broken actuator
Apr 07, 2009 | Panasonic AJ-D250 DVCPRO DV/Mini DV VCR
AJ-D250 PANASONIC E-62 PROBLEM
E-62 error on AJ-D250 points to a cassette housing problem. either replace the cassette housing or have it rebuilt (replace gears on the sides that raise and lower the cassette). "replace belts" won't work - the AJ-D250 doesn't have any belts.
Oct 14, 2008 | Panasonic AJ-D230H DV/Mini DV VCR
Hey dude
Yes you need to use th AJ-CS750P on the 230, I have had it work with almost every type of DVCpro machine.
Sep 19, 2008 | Panasonic AJ-D230H DV/Mini DV VCR
Correct Cassette Adaptor
This is likely a firmware\software issue
you need to have a specific version of EPROM FLASH ROM programmed files..
Ed
Panasonic aj-d230h
without knowing the exact error message, I can only speculate, but most rewind errors I have seen with the AJ-D230 are related to problems with capacitors on either the reel motor driver board or the system control board. the firewire upgrade (AJ-YAD230) is no longer available.
Panasonic AJ-D230H DV/Mini DV VCR Logo
531 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
