Flat Panel Televisions
Problem for Flat Panel Televisions
Generic problem for all Flat Panel Televisions
HDMI audio problems with my sharp LC42D64U
By snickers614 on Mar 02, 2008
When I hook up my Sharp LC42D64U with an HDMI cable the audio cuts in and out. I tried that HDMI cable on another tv and there is nothing wrong with the cable. The compoment cables work fine with the Sharp LC42D64U
Clarification Request
Posted by Dobbins99506 on Mar 02, 2008
What source are you using? Cable box? Dvd player? Model and brand of source?
Same Problem
Jun 26, 2008
-   I'm having the same problem on my Sharp...sound cutting out. It's mostly no sound and then a little short sound occasionally. We've had the Sharp since Oct. 2007 and it's been fine up until now. I run a HDMI cable, which my cable company - Cox - doesn't support. I'll try the component cables and see if that's any better.-   trickeydave
May 09, 2008
-   I am having the same problem with the audio cutting out when using HDMI cable connection to a cable box. Does using the component cable connection solve this audio problem with the Sharp LC42D64U ?-   Zeke85308
Mar 22, 2008
-   I'm having the same problem - did you ever figure out how to fix it?-   Guest
Best Solution
posted on Mar 24, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
the problem is that your cable box is putting out too low of a bandwidth to your tv and is cutting out completely. Since its all digital either its there or not. try switching to componant cables. Cable boxes only support up to 720p anyway so you wont sacrafice any quality.
Hope this helps
Solution #2
posted on Aug 06, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I had the same issue with my Samsung. The sound would drop with the HDMI connection from time to time, sometimes two or three times per hour. I checked on Samsung's website and they had a firware update for this particular issue (I guess that I had sent me too many emails regarding this problem and they finally put an update for it.) I updated the firmware last night and TV was running for a few hours without any problems. Check on the manufacture's website of your TV and you might find a solution for it.
Solution #3
posted on May 11, 2008
Not Rated)
Zeke85308
Rank: Apprentice
Rating: 0%, 0 votes
Using the component cable connection solves the HDMI cable audio problem with the Sharp LC42D64U.
Thank you for your help
Was this helpful?
Yes
No
Popular Solutions for Flat Panel Televisions
Questions and Unsolved Problems for Flat Panel Televisions
Answer
What is a good still camera to buy?
Answer
I took a 19 inch TruTech flat screen off of the wall and cannot locate the base, can I purchase one?
Answer
i have a blue screen that i cant change back and i have black marks on my screen
Answer
the tv constantly has a line going through the center it disappears and then appears again.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Flat Panel... Experts
Top TV Repairmen
in , OH
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
