Question about Compaq Armada M700 Notebook
When turning on amn error screen is showen
Invalid memory module plugged in
  • 520 Answers
Wrong kind of memory card
Posted on Mar 03, 2008
Touch screen working
May be your phone is locked with some particular network.Hence when you insert other networks it shows the error message "Invalid Sim"...If you want to use the Samsung C3303 with other networks you need to unlock it.To unlock you can approach Simpleunlocking.com and get the requires unlock code along with free unlock instructions.
Aug 27, 2013 | Samsung C3303 Cell Phone
Hi! I have problem with my compaq armada M700.when i turn it on writing comes out "INVALID MEMORY MODULE PLUGGED IN!" Can you pls.help me what to do?
Sounds like you either have a bad memory module or else it isn't properly seated in the memory slot properly.Access to memory slots in laptops can be as easy as taking off a panel, or as difficult as taking ff the keyboard. Sometimes, one slot us under a simple panel, and the other one is under the keyboard. If you are mechanically inclined, you may want to remove and reseat any memory you find under a panel on the bottom.There is a "how to" here that shows you how to remove and replace a memory module in a laptop:http://www.ehow.com/how_5468843_change-ram-laptop.html
Mar 02, 2012 | Compaq Computers & Internet
I am trying to install Memory in my GT5252 desktop. After I install it my computer will only boot to a black screen
First, make sure it is the right type of memory.
Second, If the memory is correct, take out the original memory and install the new memory.
If it boots , leave the new mmemory in and install the old memory. Again, test to see if it will boot.
  • Make sure that you are working in a static safe environment. Remove any plastic bags or papers from your work space, and make sure to keep your computer plugged in but with the power turned off. Keeping your PC plugged in will keep the case grounded, thus reducing the chance of damaging the module or system. Touch an unpainted metal part of your case before touching your new modules or any other components in your system.
  • Remove and reinstall the modules to make sure that they are seated securely in the socket.
  • Make sure that your new memory is the same type as your old memory (i.e. FPM/EDO/SDRAM, parity/non-parity/ECC, buffered/unbuffered). Using EDO or SDRAM in a system that does not support it will not work, often resulting in a blank screen and no POST (power on self test), or a BIOS/CMOS setup error.
  • Fill your slots starting with the largest density and working to the smallest (put the largest module in slot 0, and the second largest in slot 1, and so on). Some systems go in reverse order, so if this doesn't work, try reversing the procedure.
  • If you get a memory mismatch error follow the prompts to enter setup, then select save and exit. (This is not an error - some systems must do this to update their CMOS settings.)
  • If your system is only reading half of the new module's memory, and the module has chips on both sides, then your system probably will only recognize single-banked or single-sided modules. Please return the memory and request single-sided modules with the same density.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 11, 2011 | Gateway GT5252 PC Desktop
I tried to change the ram on my asus laptop and turned it on and screen does not show anything but laptop turns on but black screen help me?
Good day.
Memory modules are sensitive. You must take a lot of care when handling memory modules.
The first question is why did you change the ram? Nevertheless, if the one you replace is certified in good condition, then the problem lies in the insertion of the new ram. First to note is the use of correct memory module type and speed. Use of incorrect type/speed may result to errors. Secondly,clean the module's contact points using an eraser. See to it that you align the module's cut (located in the contact point) to the proper slot in the memory module's slot. Do not force to insert the memory module if it is not in the proper slot, it will break the board and/or the memory module. You can hear a slight click sound or a firm position signifying you have correctly inserted the memory module. Power on test your laptop. If you have more than one modules, you may try one another to isolate defective one.
Feel free to post your problems here at Fixya.
Good luck.
Tedmac
Oct 08, 2010 | Computers & Internet
Tried to startup and computer shuts down citing ''Fatal Error''
just try to boot the system in safe mode and run thse chkdsk command.
Jan 15, 2010 | Computers & Internet
Hi Iwill be glad to assist you:
Description There is a problem with the printer memory. The dual inline memory module (DIMM) that caused the error will not be used. Values of X and Y are as follows: X = DIMM type 0 = read-only memory (ROM) 1 = random-access memory (RAM) Y = device location 0 = internal memory (ROM or RAM) 1 to 4 = DIMM slots 1, 2, 3, or 4 ZZ = error number 0 = unsupported memory 1 = unrecognized memory 2 = unsupported memory size 3 = failed RAM test 4 = exceeded maximum RAM size 6= invalid DIMM speed Action
  1. Press Cancel Job to continue.
  2. If the problem persists, turn the printer power off and then turn the printer power on.
  3. It might be necessary to replace the specified DIMM. Turn the printer power off, and then replace the DIMM that caused the error.
Nov 05, 2009 | HP Color LaserJet 3500 Printer
Dell Inspiron 1520 laptop. Blue Screen
Dear, Requested data was not in memory. An invalid system memory address was referenced. Defective memory (including main memory, L2 RAM cache, video RAM) or incompatible software (including remote control and antivirus software) might cause this Stop message, as may other hardware problems. What you can do is if you have more than one memory modules, you can boot the system with single and see. If this is due to memory leakage issue, you can find it here
Oct 16, 2009 | Dell Inspiron 1520 Motherboard
53.10 Error "Shut off printer and turn back on"
The error points to your memory see below. the .10 indicates internal ram. You may need a formatter bd.
53.XY.ZZ PRINTER ERROR To continue press cancel job Description There is a problem with the printer memory. The dual inline memory module (DIMM) that caused the error will not be used. Values of X and Y are as follows: X = DIMM type 0 = read-only memory (ROM) 1 = random-access memory (RAM) Y = device location 0 = internal memory (ROM or RAM) 1 to 4 = DIMM slots 1, 2, 3, or 4 ZZ = error number 0 = unsupported memory 1 = unrecognized memory 2 = unsupported memory size 3 = failed RAM test 4 = exceeded maximum RAM size 6= invalid DIMM speed Action
Jan 20, 2009 | HP LaserJet 4350dtn Printer
Dell PE 1600SC invalid memory configuration detected
You may need to install memory in matching pairs. If the new memory is a single 1Gb module and you didn't already have a similar one they may not work together. Try removing the original module(s) and see if it makes a difference.
Oct 28, 2008 | Dell OptiPlex GX280 PC Desktop
Sony Cyber-shot DSC-W70...
It's a flash error, something has malfunctioned with your flash and the system board will continue to give this error until reset by service technician
Feb 27, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
Compaq Armada M700 Notebook Logo
73 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
