Samsung Rear Projection won't turn on!!!
I have a rear projection Samsung HDTV1080i model HCR4355WX/XAA serial# 31Ey600379N version MV01. when plugged in it makes a twing noise and the LED in the front blinks red 5 times. Unit does not turn on!!!
TV repairman said he has to come out, just wondering if it was a part I can order online. Took back panel off, when looking at it from the back the noise is coming from the right hand side on the TV. PLEASE HELP!!
  • mimi70 Mar 24, 2008
    rear proj. samsung tv wont turn on,. timer light continues to blink , then powers off. have r4emote, just not the origibnal remote for tv.
premtech
  • 934 Answers
SOURCE: colour problem on rear projection tv
This might be something really simple... In a large number of DPTV310 chassis, of which this TV is, the yoke connections where put in place with black electrical tape just below the retaining rings. Job is to loosen the rings, remove the tape and push the yoke back in place and tighten down retainer.. Be careful not to throw off the tilt of the yoke. The adhesive on the tape, over time, gets hot so many time it becomes slippery and allows the yoke to fall away from it's position dulling the look of the image (or focal length) causing the problem you're describing here... It also throws off the convergence - so in attempting to converge it just looks worse. Good Luck Bill
Posted on Jun 11, 2007
easyab
  • 132 Answers
SOURCE: Samsung rear projection television HCN4226WX/XAA
Dead Samsung
I don't recommend working on the TV unless you have some experience and knowledge relating to the safety issues and electronic repair. Most rookies will not successfully complete the repair and probably do more harm than good.
Sometimes when the convergence chips fail, the TV senses the changed load condition and shuts down.
Unplugging the blue, red or green convergence connector on the convergence board removes the overload condition if the IC is shorted and allows the tv to run, with one color missing.
This is done with the tv unplugged. Then plugged in and turned on to see if it starts. Turn off immediately if you here it start.
Now you know if convergence failure caused the shutdown. You can repair the convergence circuit if that is the problem.
If this has no affect, then you could have a number of different faults in Vertical output, Power Supply or HV circuits that require the expertise of a qualified service person. This would be a bench repair in most shops.
If you live around Calgary, Alberta try me instead:
http://calgaryconvergencerepair.weebly.com/convergence-explanation.html
Or try to the find the repairperson part of this website (on the Homepage) and search postal code. Maybe you will be lucky and someone from your area is listed for Projection TV repair.
Most rookies doing this job will cause damage and not be successful. They will pay double for someone to fix their mess or end up scrapping the TV. It is not a simple task. It is more difficult than batteries on a remote.
Good Luck
easyab
Posted on Jun 27, 2008
SOURCE: standby light blinks 6 times
i replaced the thermal fuse on my kdf-55wf655 and still have the 6 blinking lights,,any other ideas.
Posted on Aug 29, 2008
  • 4234 Answers
SOURCE: Picture shadow on rear projection Sony big screen TV
You have 2 distinct problems that should be addressed separately. Please repost the Samsung problem. I will address the Sony problem here.
If the "shadow" makes the picture seem somewhat of a 3D one, the problem is with the convergence circuit. This could be as simple as bad connections on the pins of the convergence ICs or defective ICs. If you can solder and would like to attempt the repair, update this and I'll provide more details and instructions.
Dan
Posted on Sep 25, 2008
SOURCE: Panasonic Rear Projection TV PT-47WXC43
I have a Panasonic PT-47WXC43 47 in Rear Projection. It went off, on picture, no sound.
Posted on Oct 11, 2008
TV lamp has been replaced, still won't come on, no picture. When turned on, I can see a blue, kind of sparking light and noise starts and does this about three times. TV powers down and does this again....
Samsung DLP TV Repair - No Picture - Replacing ...
? 2:41
https://www.youtube.com/watch?v=pBTgk_C5FVU
Jun 11, 2012 - Uploaded by ShopJimmy.com
DLP TV Repair No Picture Bad Lamp Bad Bulb TV Won't Turn On DIY Samsung DLP TV Repair How to replace Faulty LampTutorial Click Here to ... Rating is available when the video has been rented. ... is a replacement for the following DLP Rear Projection TV models: ... SAMSUNG HLR6167WX/XAA
Samsung DLP problems - Help! - ecoustics.com
www.ecoustics.com > ... > Home Video Forum > Projection TV Forum
Oct 26, 2009 - I have attached a picture of to show where the "Light Tunnel" is located. Upload ... So now I have a Samsung HLN5065W/XAA that I am willing to part out or sell as is. ... I replaced the ballast but the TV still won't turn on. .... The lamp has been sitting on a shelf until two weeks ago, when the TV went dark. Samsung DLP Light Ballast
Apr 10, 2009
Archive through October 26, 2009 - Samsung DLP problems ...
Apr 8, 2009
Samsung DLP Flashing Standby light
Jul 1, 2006
More results from www.ecoustics.com
Jan 19, 2016 | Samsung SELECT HLR6167WX/XAA Rear...
I replaced the bulb in my Samsung HLP5674 wx xaa TV and now it turns off by itself intermittantly. How do I fix this?
You may have not gotten the lamp door switch positioned just right when you replaced the lamp door. It's been a common issue with Samsung in recent models. It's possible to defeat the switch by using a wire jumper across the switch plug and eliminate the problem all together if you're electronically apt.
Bill W.
integrityhomeworx.com
Mar 09, 2011 | Samsung HCN473W 47" Rear Projection...
Samsung Tantus Model 553W HDTV1080i, when you turn the tv it just has a black screen and makes a clicking noise like it is turning on and off
Samsung has had a issue with several models, with power supply going out. The clicking noise is what lets you know it is the power supply, it is teying to cut on but has not power from the board so it cuts off. I would call Samsung and see if your model happens to be listed as the models they are covering the power supply for, your exact model number is HCM553WX. If that model is not on the list of covered models, you can ask Samsung what to do, because parts for your tv are no longer available. Hope this helps. You can reach Samsung at 1-800-726-7864
Mar 31, 2010 | Samsung PCH521R 52" Rear Projection...
White dots on my samsung dlp tv
Samsung DLP Projection Tv white dots may caused by DLP Chip. Change a new DMD Chip 19106143W. The post show you how to replace it step by step.
Your chip should look like this:
Jul 11, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung hdtv1080i saying check factory data self focus nt wkg
Hope this link helps mate,
http://www.howtomendit.com/answers.php?id=79076
Darren
Dec 31, 2008 | Samsung HCN436W 43" Rear Projection...
HLP 4663WX/XAA
sounds like the color wheel has gone out
Dec 17, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
My screen is cract
Call the following number to know part price, availability, and delivery cost: 1-866-925-PART (7278)
Dec 15, 2008 | Samsung HCL4715W 47" Rear Projection...
Televison & Video Logo
100 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
