Question about Garmin iQue 3600 GPS Receiver
Light is dimmed. Cannot make it brighter.
I replaced the battery in my Garmin iQue 3600. I recharged it overnight and then turned it on. I had lost all my data ... I can fix that. However, the screen is very dim. I adjusted the brightness to maximum but that made no difference. The screen is so dark that I have to hold it under a bright light just to make it out. I did a hard reset but that did not help.
Is there anything I can do to increase the brightness? Or is there someone I can send it to to fix the problem (at a reasonable priced)?
  • Anonymous Mar 07, 2008
    I have exactly the same problem. Replaced the battery and got a dim screen for my trouble. HELP!
  • fiveOse7en Aug 13, 2008
    I have the same problem, tried loosening screws that hold main PCB down as suggested elsewhere but no success. I have checked the wires from display to PCB they look in tact but have not unsoldered and resoldered. The screen is extremely dim but not completely blank so I think it has power. I was hoping this was a software problem that would be fixed with a hard reset but I cannot get device to complete hard reset. When the prompt appears to delete all data I choose this put all data remains so I don’t think it has gone through a full hard reset.
This happened to me, too, when I replaced the battery. Turns out one of the wires that affects the brightness came loose. I found the loose wire, touched it to a few places where I thought it should go, and one of them caused the screen to come on to full bright.
I was extremely nervous dealing with this - never soldered in such tight quarters before, but once I soldered it down, the problem was solved. I have other problems with my ique - like extremely limited battery life - but the brightness problem is solved.
Posted on Sep 23, 2008
Suggest backlight wires broken off main PCB under display.
Black and red short wires on left of PCB break easily when disturbed so ** backlight.
Posted on Mar 09, 2008
Garmin ique 3600 backlight does not work.
When you opened up the unit, you probably loosened one of the wires. Look to see if there is a small, short black wire and a small short red wire attached to the screen and soldered onto the circut board. They control the back light and one of them may be loose or disconnected. It can be repaired if you have a fine enough soldering tool.
Apr 11, 2009 | Garmin iQue 3600 GPS Receiver
Dark screen on garmin ique 3600 pda
Turn the unit on and try holding the on/off button down for three oe four seconds.
Mar 13, 2009 | Garmin iQue 3600 GPS Receiver
Garmin ique 3600
Sounds like a battery problem and I ordered a new battery to see if that will fix the unit.
We will see!
A Sudia
Aug 26, 2008 | Garmin iQue 3600 GPS Receiver
Need to replace memor4y battery in garmin hanhheld gps.Please advise how to. regards George the internal battery is dead on my old garmin gps III , can it be replaced ?
Battery can be replace for around $14 (look at eBay and search for "battery ique 3600"
See this video for insrtuctions:
http://www.viewdo.com/now_viewing.php?id=205
Aug 19, 2008 | Garmin iQue 3600 GPS Receiver
Garmin Ique 3600 - Won't charge at all
There are larger capacity baterys avalable.
I saw several different size baterys reported to fit the 3600 on the web.
I am currently looking for a parts doner 3600. If you want to part with yours.
Thx.
Alex
AlexRands@hotmail.com
Jan 01, 2008 | Garmin iQue 3600 GPS Receiver
Ique 3600 can not charge thru cradle and car unit but only thru travel charger, using the pin connector (Green light does not appear when using the main connector on ique 3600, although hot sync and...
Solved:Opened the iQue and used a heated knife to cut horizontally into the + pin and it comes like a U, upside down, from the circuit board, and the exterior side of it was broken. Used tiny plastic and sealant in the hollow space inside the connector and soldered thin copper wire (used for exploding dynamite) from the horizontal part towards the exterior.
Nov 16, 2007 | Garmin iQue 3600 GPS Receiver
Sound
If you lost "all" sound - click the speaker icon (bottom of screen) and make sure all volume is turned up. If you lost just the voice prompt for turns etc. This happens when you have an extended period of low battery. You need to reinstall the setup CD for the iQue 3600 go through the motions and HotSync the unit - This will reload your voice files.. Jerry ... gandg22@yahoo.com
Aug 15, 2007 | Garmin iQue 3600 GPS Receiver
Unit will not charge, changed battery but still does not work... Help
Sound as though you shorted something on the main board when you installed the new battery. Just sell the unit for parts on Ebay
May 03, 2007 | Garmin iQue 3600 GPS Receiver
Garmin iQue 3600
'Soft Reset' If that fails 'Hard Reset' while plugged into the mains! You will end up with an empty iQue but a HotSunc will re-intall
Mar 29, 2006 | Garmin iQue 3600 GPS Receiver
Garmin iQue 3600 GPS Receiver Logo
287 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
