Question about Asko D1776 Stainless Steel Built-in Dishwasher
Asko dishwasher d3120
Hi my dishwasher doesn t work at all the potscrub light flashes all the time and a little buzzing noise help me please i can t wash dishes anymore . thank you for your help
  • 1 more comment
  • Anonymous Mar 17, 2014
    D3120
  • Anonymous Mar 18, 2014
    asko red light d3120 circuit diagram
  • Anonymous Mar 30, 2014
    It has the hour light for a two hour wash and it doesn't do anything it stays on.
    Sergeant:
  • 351 Answers
Hi this is known as an L1 fault (Not heating) you need to check the element,thermistor,wash motor,wiring or the pcb.Failing this you need to ring asko
Posted on Mar 03, 2008
  • Ian Greenland Mar 28, 2008
    you may have a faulty pcb
Water will not drain out but the water pump keeps running even when the door is openned or closed.
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Jun 16, 2011 | Asko 24 in. D3120 Dishwasher
DO NOT DRAIN
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
Oct 30, 2010 | Asko 24 in. D3120 Dishwasher
Asko D3120 I have resolved the problem of pum always running by tilting the dishwasher but now I have a new problem of the pump not draining the water in the bottom of the dishwasher. I thought it was...
In the bottom where the filter are, you can see a yellow 'thing'. Remove this and stick one finger in an try to rotate the pump wing. Try to remove particals that is blocking the pump.
Or there is something in the drain hose. Try to drain the machine by holding the drain hose over bucket. If it drain here, then the problem is under the sink.
Jul 17, 2009 | Asko 24 in. D3120 Dishwasher
I have a asko d3120 and it's only draining water and will not start or stop draining :( what can i do?
check the float switch under the pan .. you could have water in the pan or float stuck in the up postion...
Hope it helps if NOT let me know more about your problem... and I will help
Jun 08, 2009 | Asko 24 in. D3120 Dishwasher
Error lights flashing
simple, go back to where you bought it, ask them, do they have a serviceman ? ity should be under some kind of warranty
Dec 13, 2008 | Asko 24 in. D3120 Dishwasher
Asko d3120 flashing coffee cup
I had to slide the dishwasher forward (undercounter installation)and tip it forward as far as possible. Water leaks onto floor, but then the internal controller seems to reset and the ASKO now works normally again. What kind of idiot would design a control module that does not incorporate a power-off interlock? FAIL FAIL FAIL - Bad, ASKO, Bad. Go to your room.
Nov 18, 2008 | Asko 24 in. D3120 Dishwasher
Pump is always running on my Asko D3121 even when door is open. the pump works OK when I put water in dishwasher but never stop
check the float switch ... it is under the dishwasher it could be stuck in the up postioin or you can have water under the dishwasher..
Hope it helps....If NOT let me know more about your problem ... I will Help
Nov 16, 2008 | Asko 24 in. D3120 Dishwasher
Asko D1776 Stainless Steel Built-in Dishwasher Logo
476 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Jose Pino
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
