Question about Olympus Camedia C-4000 Zoom Digital Camera
Flash Hi I have set the camera on auto and flash not working at all, all i get is dark pictures can you plesae advise thanx.
  • 593 Answers
You can turn flash off via one of the menus, make sure it is enabled. You may have a bad flash is everything looks OK.
Posted on May 13, 2008
Very dark video output and view through the view screen, no matter where the ISO dial is set. The Auto, C1 and C2 mode for Photos is just as dark. I can take good pictures only in P (Program) mode, al
This is most often a problem with the imaging sensor and no reset is going to repair the part. Also, if replacing it, it needs to be properly calibrated after installed. If you need help with this, this is the place we recommend for the Canons: www.CamerasAndParts.com They are the best for these models, they only work on Canons and they are excellent for repairs. They have a service package for about $90 which takes care of an image problem as you have or you can try emailing them first. As far as service and the quality of work, I wouldn't go anywhere else but them for a Powershot. They are the best for these cameras. Good luck
Dec 20, 2014 | Canon PowerShot G10 Digital Camera
How do I lighten the pictures?
Check your camera settings:
White balance should be set to auto,
ISO should be set to auto,
flash should be set to auto,
scene should be set to auto,
Exposure Compensation should be set at 0.
If images are still too dark change ISO setting to 200. If that doesn't work change to 400. If that still doesn't work change exposure compensation to +1. If your photos are still too dark your camera is defective.
Nov 10, 2014 | Vivitar ViviCam 7024 Digital Camera
Pictures are all too dark even with flash
Go to Menu find Adjust ISO settings in camera it may be on Auto or at low setting . The Higher the setting in ISO the lighter the picture this is commonly used in low light settings.Play with it until desired ISo works for you . Nice camera nice lens !
Sep 20, 2012 | Panasonic Lumix DMC F3 Digital Camera
Hi, Don't know how to obtain clear close up of small subject
Mount your camera on a tripod. Set it for "macro" mode. Turn off the flash. Light the jewelry with lamps (like worklight reflector clip on lamps) fitted with daylight balanced compact flourescent bulbs. Use poster paper of various colors for background. Set your ISO to 400. Set your white balance to "auto white balance". Have fun!
Feb 22, 2010 | Kodak EasyShare Z1012 IS Digital Camera
A630 Indoor pictures are too dark in Auto, Flash
try using night mode indoors. otherwise, simply get into setup and go back to factory settings, and use AUTO mode. hope it helps
Oct 07, 2009 | Canon PowerShot A630 Digital Camera
Can't take pictures w/ flash
Maybe you have the ISO set to a very high number. Set it to "auto ISO".
Sep 25, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Images are coming out REALLY dark
first GET TO AUTO MODE WITH FULL AUTO
if this doesn't work try going to manual and setting the exposure up to +1 or +2
Feb 04, 2009 | Nikon D40x Digital Camera
Picture in dark condition.
It may be that your subject is too far away. The range of your internal flash is 12 feet if you have the ISO set for Auto, or 23 feet if the ISO is set for to 1000. You may get Normal 0   Normal 0 acceptable results with the ISO set to 1000 without the flash, but you should put the camera on a tripod (the shutter speed could be as low as 1/8 of a second) and use set the zoom for wide angle (the lens lets in almost 8 times the light as it does in maximum telephoto.)
I hope this helps,
Mike
Jan 03, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Flash forced off
THESE CAMERAS DO NOT HAVE A AUTO POP UP SOLENOID TO OPEN FLASH. THIS HAS TO BE DONE MANUALLY WITH THE BUTTON TO THE LEFT OF THE FLASH.
May 27, 2008 | Panasonic Lumix DMC-FZ50K Digital Camera
CANON Rebel RTI Outdoor pictures are dark
learning to use light metering correctly can have its challenge.
the manual will guide you on how to set up to read light from the subject. spot metering a dark area will cause general overexposure, or a washed out look. spot metering a bright area will cause a dark image. if you are on spot meter and shoot two people standing together against a bright lit background, your meter will see between them if they are centered, and read all that bright background, setting the camera to a less sensitive combination of aperture / shutter speed, resulting in a dark image. use field averaging meter setting and be sure you are metering the subject and not the background. try shooting a wall that is fairly clear of other colors and uniform it light hitting it, you should have a correctly exposed image. since it works in other modes (at least 1, anyway) then it is unlikely you have an exposure compensation issue. that is the only other non defect issue that would cause your problem.
once you confirm that you have these settings correct and still get a dark image, its time to have it serviced.
good luck
mark
Sep 01, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Olympus Camedia C-4000 Zoom Digital Camera Logo
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
