Question about HP PSC 1215 All-In-One InkJet Printer
Struggling to scan
Haven't used this facility for a long while but it has worked before, have I to have paper loaded as the lights for paper are on but I didn't think that would matter as it is only a scan? Thanking you kindly
I have the same problem. Any ideas?
Posted on Apr 01, 2008
Printer model : hp425 dw I get this message: "Load
send back under warranty, first check there is not a paper jam.
Oct 28, 2017 | Office Equipment & Supplies
Need user manual and software for a HP ScanJet 4p scanner
HP ScanJet 4p Scanners - How to Use the Automatic Document Feeder (ADF) gtabseps.gif
gtabblt.gif Tips for Using gtabblt.gif Step 1 - Load the Paper gtabblt.gif Step 2 - Scan the Document gtabblt.gif To Scan a Single Page gtabseps.gif Tips for Using
  • Remove any paper from the copyboard glass before using the ADF.
  • Straighten any curls or wrinkles from documents before putting them on the document tray. If this is not possible, do not scan these documents using the ADF. Instead, use the copyboard glass or make a photocopy of the documents and scan the photocopies.
  • Remove staples, paper clips, and any other materials from documents.
  • Avoid documents with tears, perforations, or punch holes.
  • Do not use the ADF to scan sheets of uncommon paper or other media, such as the following: - transparencies - gummed-backed paper - magazine pages - lightweight ("onionskin") carbons
  • For paper smaller than 5 inches (127 mm) by 7 inches (178 mm) or larger than 14 inches (356 mm) by 8.5 inches (216 mm), use the scanner glass instead of the ADF. Paper smaller than the minimum size may cause a paper jam.
  • For paper lighter than 16 lb bond (60 g/m sq) or heavier than 32 lb bond (120 g/m sq), use the scanner glass instead of the ADF.
  • Before scanning, always push the front of the ADF downward to the scanner to ensure that the magnetic latches are engaged.
Step 1 - Load the Paper Besides the instructions below, quick reference decals on the input tray and access hatch show the order of steps for paper loading.
  1. Turn on the scanner.
  2. Ensure the scanner's scanner glass is free of paper.
  3. Turn the green paper load lever into an upright and open position. Refer to decal number 1 located on the ADF access hatch.
  4. Put the top end of the paper stack face up on the input tray. Refer to decal number 2 and pointer arrows on the ADF input tray.
  5. Push the paper stack up against the green document guide and slide it right against the green registration stop, which is in the middle of the paper load window.
  6. Turn the green paper load lever 45 degrees into the closed position. This will secure the paper stack. Refer to decal number 3 on the ADF access hatch. The ADF is now loaded and ready for scanning.
Step 2 - Scan the Document The ADF works with many software packages that are compatible with the HP ScanJet color scanners. To scan a document, refer to the user's manual of the software package being used. To Scan a Single Page To scan a single page while the ADF is installed on the scanner, do the following.
  1. Remove any pages from the ADF input tray.
  2. Raise the ADF.
  3. Place the page on the scanner's copyboard glass.
  4. Lower the ADF all the way and do the scan.
Sep 23, 2011 | HP Office Equipment & Supplies
Gidday. Motor started struggling for power and engine light came on for a while then went off but still struggling for power. Maybe a sensor? Mitsi express van wa with motor at front 4g64. How do i extract...
you cannot read the code from a scanner on a non american market vehicle ,they use encrypted software to stop weekend mechanics making more work for the dealer,try changing the mass air flow metering device its in the air inlet manifold pipe .
Jan 03, 2011 | Mitsubishi Minivan Cars & Trucks
Paper jams when using the ADF. Canon IC D780
When using ADF
* Set a document on the Platen Glass if you want to scan it at optimum quality,
* The area (range) within 0.08"/2mm from the top edge if document cannot be printed since the machine cannot scan it.
*Do not load the following types of documents in the ADF. They will jam.
-Wrinkled or creased paper
- Curled paper
- Torn paper
- Paper with holes
- Carbon paper or carbon-backed paper
- Surface treated paper
- Onion skin or thin paper
- Photogragh or thick paper.
1) Remove any documents from the PLaten Glass.
2) Open the Document Tray.
3) Load the document in the ADF.
Load the document with the side you want to copy, or scan face up in the ADF.
4) Adjust the Doument Guides to match the document width.
Note :
Ensure that the edge of the document stack is in line with the Paper Size Mark imprinted on the Document Tray.
Hope this helps.
Please rate my response.
Have a good day.
Nov 30, 2009 | Canon Office Equipment & Supplies
While attempting to feed paper overload light comes on and shredder stops
Over load light comes on only when you have either put too thick a bundle of paper or too hard. So reduce the thickness according to the hardness of the paper. Start with a few sheets of paper only. then increase the number of sheets till you find the shredder is struggling hard to do the job. That is your limit. If you exceed this limit then it would stop shredding and may even burn the motor ultimately.
Nov 29, 2009 | Royal VF1012mx Shredder
Printer will not scan pictures.
Introduction To use the scan features, the HP All-in-One and computer must be connected to each other and turned on. The HP All-in-One software must also be installed and running on the computer prior to scanning. To verify that the HP All-in-One software is running on a Windows computer, look for the HP Digital Imaging Monitor in the system tray at the lower right side of the screen, near the time. NOTE: Closing the HP Windows system tray icon can cause the HP All-in-One to lose some of its scan functionality and result in a No Connection error message. If this happens, correct it by restarting the computer or by starting the HP Image Zone software. Follow the instructions below to scan documents from the all-in-one to an application. Make a Scan Step one: Load paper
  1. Open the paper tray door. Figure 1: Opening the paper tray door c00315283.gif
  2. Pull the paper tray extender toward you, as far as it will go. Flip the paper catch at the end of the paper tray extender to open the extender the rest of the way. WARNING: Legal paper might get caught on the paper tray extender if it is fully extended when you print onto legal paper. To avoid a paper jam when using legal-size paper, do not open the paper tray extender.
  3. Squeeze and hold the tab on the top of the paper-width guide, then slide the paper-width guide to its outermost position. Figure 2: Sliding the paper-width guide to the outermost position c00315284.gif
  4. Tap a stack of paper on a flat surface to align the edges, and then check the paper for the following:
    • Make sure it is free of rips, dust, wrinkles, and curled or bent edges.
    • Make sure all the paper in the stack is the same size and type.
  5. Insert the stack of paper into the paper tray with the short edge forward and the print side down. Slide the stack of paper forward until it stops. NOTE: If using letterhead, insert the top of the page first with the print side down. For more help on loading full-size paper and letterhead, refer to the diagram engraved in the base of the paper tray. Figure 3: Inserting paper into the all-in-one c00315285.gif Squeeze and hold the tab on the top of the paper-width guide, then slide the paper-width guide inward until it stops at the edge of the paper. Figure 4: Sliding the paper-width guide to the edge of the paper c00315286.gif Do not overload the paper tray; make sure the stack of paper fits within the paper tray and is no higher than the top of the paper-width guide.
Step two: Load the original NOTE: Many of the special copying features will not work correctly if the glass and lid backing are not clean.
  1. Lift the lid and place the original face down on the left front corner of the glass, with the sides of the original touching the left and bottom edges. NOTE: For more help on loading an original, refer to the guide engraved under the glass.
  2. Close the lid.
Step three: Scan to an application NOTE: To use this feature, you must have installed the full software package and the HP Digital Imaging Monitor must be running.
  1. Press Scan on the control panel. A preview image of the scan displays in the HP Document Viewer window on the computer, where you can edit it.
  2. Click Done or Finish in the software. The HP All-in-One sends the scan to the HP Image Zone software, which automatically opens and displays the image.
NOTE: To stop scanning, press the Cancel button on the control panel, or in the HP Image Zone software, click Cancel . Have a good day,
Jun 18, 2009 | HP PSC 1410 All-In-One InkJet Printer
Scanning using the DX8400 printer
You need to install the Epson Scanner Driver on your computer. The best way to do this is to install the sotware using the easy install facility. When the software installation has completed you will dind an Epson scan icon on your desktop. Double click this icon to run the scanner software.
The document to be scanned must be placed face down on the DX8400 glass just as making a copy, The scanning functions are all accessed from the PC.
I hope this helps.
Nov 14, 2008 | Office Equipment & Supplies
My printer wont print on photo paper.
Is it worked in past? Have you contact the HP for this problem? Since most of All-in-one printer do not possess better print facility, so it is difficult to use this one for photo print..
Photo paper is thick and may be motor not taking complete load of it. Check out with the roller moving firmly.
Oct 27, 2008 | HP DeskJet F380 All-In-One Printer
HP PSC 1215 All-In-One InkJet Printer Logo
361 people viewed this question
Ben Johnson
