Question about Lanzar 4 Gauge Digital Installation Kit w/1.2 FARAD Capacitor Car Audio Amplifier
Capacitor First my subs started working off and on for no reason. I have a 4 farat capacitor and it normally would say 14 volts or so. Now when I turn my car on it says 8.4 or so. The subs do no sound and after a couple minutes the display on the cap just turns off. I can hear that the amp is on like a whirring noise. Please let me know whats up.
  • nitro_fusion Mar 04, 2008
    Fixed! The ground had melted fiberglass all over it. I cleaned it and bolted it down properly. Thanks a ton!
  • kalyanram_B Dec 11, 2008
    Hi, I have a BOSS CAP20BK Capacitor, and am unable to know, how to connect it, also need guidence with what else is needed for best performance, along with safety, and effeciency. Please advise .
  • 38 Answers
Sounds like a bad connection to me, check all your cables,
Most likely to be an earth, so check all your earth cables including the battery earth, its always a good idea to upgrade your battery earth anyway, It will be better that way anyway
Posted on Mar 04, 2008
Installation or a 2 farat for 3 amps
Connect the positive lead close to the amp on the positive lead running to the amp.The ground lead should be grounded to the car chasis.
Jan 29, 2010 | Legacy Lca280sl 2.8 Farad Digital Power...
I have a Pioneer 5400t amp hooked up to a 10" 400w sub of unknown brand. The system was working perfectly for about a week, then I noticed the sub wasnt working. I blew both 30a fuses on the amp. I...
Your best bet is to buy a cap. A capacitor is an external battery booster like device. It boost power to amp. The thicker the wire the better. Power and ground. Shorter thicker ground wire the better. Make sure it is not on a painted surface. Scrape down to metal surface!!!!
Nov 12, 2009 | Cars & Trucks
I have polk amp that is powering 2 12' subs but itis flashing up with low amp/short light with a little buzz noise?
you must check your wiring from head unit back to subs even take subs out of box to make sure no wires are lose 99.9 of the time a wire has come lose which can be bad if your bridging sups as it changes ohms with 1 or 2 subs hope that helps oh and check volts from you batt and check volts at fuse spots and after fuse to make sure your geting at least 12 to 14 volts cheers i just had a ***** of a prob my subs worked but **** bass found out head unit sub out craped out
Oct 16, 2009 | Polk Audio C5001 Car Audio Amplifier
Protect Mode
Your probably not pusing enough wattage to the amp. Look into buying a capacitor for your set up. and you may need to run a thicker guage wire to your amp.
Jun 01, 2009 | Legacy Audio LA1030 Car Audio Amplifier
LOW VOLTS ON '04 350Z
14 volts is about right.  Have you had any starting problems?  Are your headlights dim?  Does the gauge move when you turn on the headlights and the blower motor?  I also have a 2004 350z.
Mar 30, 2009 | 2004 Nissan 350Z
Low ohms light flashes and bass distorts at high volume
Sounds like you need to invest in a capacitor. Those are used when subs receive a bass spike. You just a need a 1 Farat Capacitor (1,000 watts) ran between the head unit and the amplfiier to fix your issue. Also, try reducing the volume gain to half gain and low pass frequency to half gain; this will increase your clarity and make your amp less hot. This may fix it without a capacitor. Also find out what amprage your alternator is. Your alternator may not be designed to run the amplifier. Most alternators are 200 amps now if they are gold plated.
Hope this helps
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=20378
Feb 10, 2009 | Jl Audio 500/1 Car Audio Amplifier
What power cap do i need for my car audio
I would go with a 4 FARAT capacitor then you know your amp won't be dimming your lights or clipping your amplifier signal.
I would actually buy the kinetic capacitor from www.onlinecarstereo.com they rated at being 100 1 farat capacitors. Great buy since it's on sale for $200 with added shipping.. Otherwise the 4 farat is needed.
Here's the link: http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=20378
Feb 09, 2009 | Pyle PLA2200 Car Audio Amplifier
Power surge blowing fuses on amp when car is turned on.
the voltage regulator in the alternator or the capacitor is malfunctioning. get a multimeter on the battery when u start the car (before the capacitor) if it reads a large surge (something greater than 14 or 15 volts) then u may need a new amp, if not, then test it on the back end of capacitor to the chassie negative, see if u detect spike there.
Nov 26, 2008 | Car Audio & Video
Stops working
THEY MIGHT BE DRAWING MORE CURRENT THEN UR ALTERNATOR CAN HANDLE.TRY CONNECTING A CAPACITOR FOR THE SUBS.
Feb 01, 2008 | Bazooka EL1204 Car Subwoofer
My Orion 2500D amplifier turns off then back on at high volume
you need a # 4 gauge wire. check the subs conection no less than 1 ohm. check ground. and if the cap is good. 13.8 volts are for max ouput ......this is 1 ohm of charge at 13.8 volts they give 2500 watts butt only at 13.8 volts whit this relation. i¨n think you need other alternator. good look.
Feb 05, 2007 | Orion 2500D Car Audio Amplifier
Lanzar 4 Gauge Digital Installation Kit w/1.2 FARAD Capacitor Car Audio Amplifier Logo
88 people viewed this question
Top Lanzar Car Audio & Video Experts
Morne Olivier
Chris Ward
xxxxxx xxx
Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
