Question about Epson EMP-S1H Multimedia Projector
Red stripes during projection
Today I turned my projector on, and I realised red stripes all over the projection area. I reconnected all the cables once again to make sure but wouldn't help. I've gone through the users manual. There it says that this is not a malfunction. But it doesn' explain more. What should I do? Will it turn normal itself? Or is it broken?
I would like to thank you in advance for your helps.
  • 563 Answers
Hi there
I promise you that it is not normal for your Projector to do this , so don't read too much into what is said about this problem.
Stripes of whatever nature on a Projector normally means there is a fault on your Mainboard. In which case it will need repair or replacement.
Warning : It is quite expensive !
Posted on Mar 27, 2008
Red warning light
follow this steps and fix it. God bless you
  • Secure the lamp cover and the air filter cover of the projector body if the projector does not power on. Ensure that the power cable is firmly connected to the projector and an active power plug. If the projector was turned off and then on quickly--let it sit for 90 seconds before trying to turn it on.
  • 2
    Replace the projection lamp if the projector will not power on or if the lamp indicator is flashing. Turn off the projector and let it sit for at least 30 minutes. Locate the lamp cover and remove or loosen the lamp cover with a screwdriver. Carefully remove the projection lamp from the projector housing using the handle, if available.
  • 3
    Place the new projection lamp into the projector housing and secure it to the projector. Replace the lamp cover and reset the lamp timer. Power on the projector to ensure the new lamp is working correctly.
  • 4
    Remove the projector from the enclosed area to allow air circulation if it constantly overheats. Place the projector into an open area and make sure there is no blockage for the ventilation holes. Unplug the projector for at least 45 minutes to allow it to soft reset.
  • 5
    Clean the air filter to allow the projector better air circulation. Turn off the projector and unplug it from the outlet. Remove the air filter cover and use a vacuum to remove dust from the area. If the filter is unable to be cleaned correctly or is damaged, then replace it. Pull the air filter from the projector and place the new one in the now empty slot. Close and secure the air filter cover.
Oct 29, 2013 | Sanyo PLCXU355 LCD Projector
Red lamp/ orange/lamp After a "break" of about
test this steps and fix it. God bless you
  • 2
  • 3
  • 4
  • 5
Oct 28, 2013 | BenQ PB6110 Multimedia Projector
Projector cuts off during play and red light flashes
Might be getting noise on the input cable. If it is HDTV, they are very sensitive... I had to buy a VERY expensive HDMI cable (I have a different model though)
Feb 10, 2013 | Epson Ex7200 Multimedia Projector
Projector problem HELP!? my projector was on whiles the utility power went out, and when the power came back i realised it had affected my projector, when i put it on (press the power button) the:...
Kindly get intouch with Cinesonic Audio Visual Pvt. Ltd. in New Delhi at 10/2, DLFIndustrial Area, Shivaji Marg, Moti Nagar,
New Delhi-110015
Contact: ' Board: +91-11-47424444 (30 Lines)'
e-mail: Robert@cavpl.com
For any problem related to Casio Projectors
Mar 21, 2011 | Casio XJ-S31 Projector
Hello, My projector has approx 400 hours of run time. It will not project any hues of red. Any suggestions?
Does it show red hues without any devices connected to it? If the colors are fine without an input device, the problem is your cabling or a connection. To check these, do the following:
1) Disconnect all your cables and observe the ends to make sure they are undamaged. If they look good, reconnect them.
2) Flex the cabling, moving a few inches at a time, starting at one end and moving slowly to the other while watching the projected image. If you see any change, you have found a damaged cable and need to replace it. If nothing is found, then try step 3.
3) Replace your cables with any spares you might have. If this does not fix the problem then go to step 4.
4) Go into your projector menu and find your color settings. Try adjusting these to see if you get the red hues.
If none of the above provided a helpful solution, The problem is usually the internal color panel. The last time I had one of those repaired it cost about $2000. If you are not very experienced repairing electronics or electronic components, you should not attempt this.
Aug 30, 2010 | Hitachi CP-X260 LCD Projector
I am trying to project a presentation from my toshiba laptop to a Hitachi data projector (new). The desktop and all have a red/pink tinge. i even tried just going into my pictures and doing a slide show -...
This sounds like a bad cable... do you tight the scew? inspect the cable connector at each ends to dbl check that there is no damaged pin, and also on the projector side...
Oct 15, 2009 | Computers & Internet
I have a viewsonic pj500 projector which has functioned perfectly for 5 years. Now the area around the image area either shows a dark blue with dark stripes and the image area has a yellow cast which seems...
LCD projector 101, your blue device is dying inside of projector. Consider purchasing a dlp based product, they do not suffer from color decay.
Really you are blessed , most lcds last about 3-4000 hours or 4 lamp changes. good luck
Apr 13, 2009 | ViewSonic PJ500 Multimedia Projector
Faulty Panasonic Projector
90% that this is a bad psu !
had mine fixed today with used psu from ebay.
try to find a faulty pt-ae900 for a exchange psu !
60€ faulty projector + 60€ psu = 120€ for pt-ae900
hooray :)
cheers,
tobias
Dec 31, 2008 | Panasonic PT-AE900U Multimedia Projector
Red-striped ghost images.
when you leave your TV (no matter what kind) and you leave it for long periods of time on a static image or something.. the image tends to burn in to the screen... so changing the glass would be a way to fix it.... the problem is that that kind of repairmen is more expensive and difficult than buying a new set...
Dec 24, 2007 | Sony Grand WEGA KF50XBR800 50" Rear...
I have a vt46 and the projection background is red, Ive tried cleaning the lcd and the complet optic system but I cannot help myself with this partial solution, can anybody help. Thanks
Hello
PlsCheck the clear white image on the display after taking out three RGB Panel ribbon Cables. or Reconnect the red Panel, if not then replace.
Viren
Rave Services India
Sep 19, 2007 | NEC VT460 Multimedia Projector
Epson EMP-S1H Multimedia Projector Logo
184 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
