Question about Whirlpool GEW9250 Electric Dryer
Whirlpool ulitimate car II does not heat!!!!! what 2 do?
Why dryer will run but will not heat!!! what should i do?
  • 57 Answers
If your unit has a fuse, check it. Look in the instruction manual, which you kept with your warrenty, right? :-) No luck?
Unless you really feel comfortable taking apart a dryer, there really is'nt much else you can do. Most likely a heating element has burnt through assuming you're running on electricity. If gas, check that your supply is not interupted. Unfortunately, more than likely, it's time to call the repairman.
I assume that all knobs feel normal when you turn them and nobody has been fiddling with them.
Sorry I couldn't offer more help.
Posted on Mar 02, 2008
How to fix a broken belt of motor of whirpool wash ultimate care 2
  • Replacing the Belt in a Whirlpool Ultimate Care II ' Home ... homeguides.sfgate.com > ... > Mortgage-Backed Securities Replacing the Belt in a Whirlpool Ultimate Care II by Rogue Parrish. Email; ... The Ultimate Care II washer, ... it may have a broken belt.
  • Whirlpool Washer: Ulitimate Care II - YouTube www.youtube.com/watch?v=bVmjmSzMXHE
    • BY CHERRY HILL
    • 3 MIN
    • 36K VIEWS
    2012-05-30 · Video embedded · Whirlpool Ultimate Care II: ... This is fully funcational washer. Direct Motor Drive works perfectly through each ... Whirlpool Washer: Ulitimate Care II
  • How to replace a broken dryer belt. Whirlpool Ultimate ... www.youtube.com/watch?v=PU8QZeDRl_0
    • BY BAILSOFSTEEL
    • 5 MIN
    • 3.5K VIEWS
    2015-04-04 · Video embedded · This video shows me replacing a belt in a Whirlpool Ultimate Care II ... a broken dryer belt. ... Whirlpool ultimate care II clothes washing
  • http://www.bing.com/videos/search?q=broken+belt+of+motor+of+whirpool+wash+ultimate+care+2&FORM=HDRSC3
    Jul 15, 2016 | Washing Machines
    I have a Whirlpool Ulitimate II Washing Machine problem. Model LSQ9010KQ0 Serial CM2756127 Type 111. Seems to be working fine expect that after the spin cycle the clothes are still pretty wet. Water is...
    It sounds like what you're describing is a weak clutch. The clutch could be worn & slipping or may have oil residue on the clutch pads. I would recommend replacing the clutch. Here is a link to the part.
    Jan 12, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
    My Whirlpool GOld Ultimate Care II electric dryer is not drying well any longer. It is 5 years old and a load must be run 2-3 times to get it to dry. Please help.
    it could be your heating element but if you use dryer sheets take your lint trap out and see how well water will run thru it it may need to be washed in hot soapy water hope this helps
    Dec 13, 2009 | LG DLG2524 Gas Dryer
    Does not heat turns but no heat Ulitimate care 2 not at top loader
    possible element issue or thermostat that controls heat elemsnt
    Oct 16, 2009 | Whirlpool Dryers
    Whirlpool gas dryer no heat
    One the terminals on the flame sensor fell off. II guess this is a common problem. relaced the sensor and
    I'm back to drying clothes.
    Oct 03, 2009 | Whirlpool LGR5636L Gas Dryer
    Whirlpool ultimate care II dryer will not dry clothes
    does dryer heats up if yes take hose out from back of your dryer run dryer if you have good power air coming out from your dryer i think your dryer is fine you need to clean your air vent. system.
    Feb 28, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Whirlpool dryer will not stay on, no heat, and timer acts weird
    sounds like the motor or the even heat board is out i would say the even heat board is more likely
    Dec 09, 2008 | Kenmore 62602 Electric Dryer
    Whirlpool ultimate ii electric dryer stopped heating
    change out the heat element, you can get the part at Sear
    Nov 27, 2008 | LG DLG2524 Gas Dryer
    Ultimate care II Whirlpool dryer
    yes its located on the houseing where the heating element is and is a small round disc with two wires get a putty knife and push in between the top panel and body of the drier about 2-3inches of the edge lifting the top as you do remove the front panel by removing the two 5/16 in screws and pull the panel the locate the heating coil and check the thermal limiter
    May 24, 2008 | Dryers
    Whirlpool GEW9250 Electric Dryer Logo
    Top Whirlpool Dryers Experts
    Tim Whalen
    Sal De
    Craig Butler
    Craig Butler
    Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
