Hello had a atv that did this, atv had set for a while, went to ride it, had all gears, went to downshift , to first, stopped then took off again, only had first gear then second no other gears, i tried everything, all different kind of oil additives, they never worked, more than likely, my atv had set for a while and the shifter fork inside the motor had rusted just a little bit, the gear had got stuck , i had to split the motor cases, to fix mine, make sure your shifter isnt stripped out, maybe it needs adjusting, i have seen people tap on the gear shifter sometimes and it would break loose, some atv mechanics, say to ride it, eventually it will come unstuck, or break the case in half to fix shifter fork and gears....
