Question about Acer Aspire 5100 Notebook
Vga hi i have a acer aspire5101awlmi i would like to atatch VGA lead and hook up to my tv.What steps do i need to take to get laptop to display on my TV please advise thankyou.
  • 97 Answers
You’ll need two outputs on your laptop that are typically found on most: the first is a small round yellow socket usually found on the back of your laptop, which is the S-video socket. The other socket you need is either a line out (unlikely) or headphones socket (more likely). You also need a TV with the correct inputs, which will ultimately decide which cables you need
First, you need two separate cables for video and audio: S-video to S-video...and Stereo 3.5mm plug to 2x RCA plugs..Both cables are two metres long and longer cables are also available..Your TV will require either equivalent S-video and RCA audio inputs or a SCART socket - if it only has the latter, you’ll also need a SCART adapter
Once done, plug them all in and switch your TV on, switching to the A/V channel. If nothing appears, open the Display Properties Control Panel, switch to the Settings tab and click Advanced. Look for a Display tab or something similar where you’re able to switch on the S-video port to enable the laptop’s display to route through the TV. Finally, when watching DVD movies (you’ll need a DVD player to do so), look for the option to run them full screen, so you get the best possible picture from your TV.
Posted on Mar 02, 2008
Connect acer to tv
Assuming your TV has a VGA input socket, plug the VGA lead in, select Computer input on your TV and power up your laptop.
Mar 20, 2014 | Acer TravelMate 6293-6727 (LX.TQP0Z.C54)...
Hi, could you tell me how/if i can connect my Acer Aspire 5742 laptop to my televison please, Thanks Alix
Hopefully your laptop has a VGA output, if you do not know what that is there is a link below:
http://www.computertroublesolver.com/image-files/laptop-vga-connection.jpg
Now check to see if your tv also has a VGA output most modern tv's do now, if it does buy yourself a VGA cable but with both the same connectors at each end then just plug one side into your laptop then the other into the TV.
if not buy yourself a vga to rca cable which look like this: http://networkcable-tester.com/wp-content/uploads/2011/03/vga-to-rca-cable2.jpg
hopefully your tv does have an rca output.
here is where you can by a VGA to VGA cable quite cheap: http://www.amazon.co.uk/gp/product/B002N2KY54/ref=pd_lpo_k2_dp_sr_2?pf_rd_p=103612307&pf_rd_s=lpo-top-stripe&pf_rd_t=201&pf_rd_i=B000WTT0EG&pf_rd_m=A3P5ROKL5A1OLE&pf_rd_r=1K0C1AGYT9XC9CHTQ1KV
here is a VGA to RCA cable : http://www.amazon.co.uk/1-8M-VGA-LEAD-CABLE-LAPTOP/dp/B000P3NZ68/ref=sr_1_1?s=electronics&ie=UTF8&qid=1310838406&sr=1-1
Hope this helps.
Jul 16, 2011 | Acer Computers & Internet
I am trying to connect an acer one notebook to a beko 32" flatscreen and everytime i plug the vga lead in the laptop screen goes black an the tv says no signal,,what am i doing wrong??
It could be a no. of things:
- Wrong input selected via the TV
- The VGA input on the TV is turned off
- Problem with the VGA cord
- Problem with either VGA port
there the basics, if there all great and it's still no working, try setting your Computer display to EXTEND rather then projector only, then play around with your graphic output settings.
UPDATE all your Drivers and check all your cables. PLUG IN YOUR LAPTOP, yes it will make a difference to the way the graphics card operates.
Hope this helps.
Mar 05, 2011 | Acer Aspire One PC Notebook
I have an ACER Aspire laptop that i would like to connect to my Samsung Series 5 500 tv but in the manual it only explains how to connect a PC how do i hook up my laptop to my tv?
Look for a VGA output on your laptop. You will also need a VGA cable. Also there are function keys along the top of the laptop (should have a small display icon) that you need to set to route the video signal to the external VGA connector.
Jan 13, 2011 | Samsung Televison & Video
What do i need to hook laptop to tv
I am sorry but you need external TV out converter to do that for that specific model.
May 11, 2010 | Computers & Internet
I have a acer extensa 4230 and wanna watch download movies on tv
You should be able to connect using vga if the TV has a vga input. Once it is hooked up you can toggle the display using the key combination fn+f5.
Mar 13, 2010 | Acer Computers & Internet
I have an acer aspire 5100 laptop i need to hook up to my tv for a presentation tomorrow. there is no s-video output on it,. how do I hook it up to my tv?
If your TV has RCA jacks on the back or front. Input type. Then you can go to radio shack and get a vga cable to RCA jack converter. That is all you can do. Is the TV a flat screen if yes then you can hook up you pc with a monitor cable like your usine now in your house. Find out the type of TV.. Ask someone to check the tv for a computer port on the back.
I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
Oct 09, 2009 | Acer Aspire 5100 Notebook
Hooking up to the tv, aspire one acer notebook???
hi there, try a 15 pin male vga to vga cable ...select vga mode on monitor
May 17, 2009 | Acer Aspire One PC Notebook
Acer Aspire 5100 Notebook Logo
121 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
