Question about Kyocera KM-1505 Copier
Blingking code C-6 in my kyocera km 1500
Operation noting blingking code C-6
  • 43 Answers
Fuser error,
may have either a blown lamp, blown thermo fuse or faulty thermistors, but more then likely a combination of at least two.
Posted on Mar 02, 2008
2 Suggested Answers
  • 43 Answers
SOURCE: error code C-6 for kyocera km 1500
Fuser error,
C9050 code
Kyocera code c9050 Printers & Copiers Questions ... - Fixya
www.fixya.com > Forum > Tags > code c9050 > Printers & Copiers
Kyocera printers & copiers code c9050 related questions and answers. ... error code C-6 for kyocera km 1500 blingking code C-6 in my kyocera km 1500 c6-400
Oct 15, 2015 | Cars & Trucks
Tip
How to program your Dish Network remote to your tv
Find your Codes for your devices here first: http://www.dishnetwork.com/customerService/troubleshooting/nhagent/default.aspx
The follow these directions:
OK, I understand that you need help programming your remote control to a TV or other equipment.
Note: After this procedure is started, if a button is not pressed within 20 seconds, the remote will end the procedure automatically. Simply start over again.
Step-by-Step Procedure // Step 1 of 6
Click on the following link to find the remote codes for your brand of TV, VCR, or other equipment. Note that codes for each TV brand depend on the remote type.
Step 2 of 6
Press and hold the correct Mode (TV, VCR, or AUX) button for about six seconds until all mode button backlights come on, then release.
Step 3 of 6
Use the number buttons to enter the three digit number (four digit for AUX mode) corresponding to the equipment. The light will blink off after each digit is entered and then return to a steady light.
For AUX mode ONLY: press 0 for a TV, press 1 for a VCR/DVD, press 2 for any other device.
Step 4 of 6
Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times.
Step 5 of 6
To verify the code works, press the mode button. Try several different functions for that equipment. Some codes may provide partial function, or respond differently than the button's titled function. Try the other codes listed for that device until you find one that offers more complete functionality.
Step 6 of 6
If the remote still does not operate the device, perform the Power Scan.
If the remote still doesn't operate equipment, it may not be compatible with that equipment.
on Dec 02, 2009 | Televison & Video
I'v problem with my nokia 5250, i can't send or receive message, it said that
for sending text messages :
1.go to your message settings and check the message center number to see if it is correct
2. call to your network operator customer care
3. request the message center number...
4.note it down
5. go to message settings>message center number
6. insert the number which is noted by you and save it
this solves your messaging problem ...
Good luck
Sep 30, 2012 | Nokia 5250 Cell Phone
It is blingking when you turn on..and nonthings hapen its jus blingking
-the operating system that you have is corrupted, you need to reinstall the OS, if it is XP you need to use repair install so that you can get files an picture in the computer
windows xp installation guide http://www.microsoft.com/windowsxp/using/setup/winxp/install.mspx
-if it is vista or win 7 just install that OS to the main partition and you can get files in the windows.old folder in drive C:
install windows 7 guide http://www.techtalkz.com/windows-7/514412-windows-7-installation-guide-tutorial.html
cheers
Feb 23, 2011 | Computers & Internet
Good day.. my compaq presario cq40..is powering on but blank on the screen and caps lock and num lock blingking only..thanks
Hello good day,sir
My compaq presario cq40..is powering on but blank on the screen and caps lock and num lock blingking only.I try ready so many time but everything are not meaning for me that's why i need your help,sir.please,give me some advice for power back.
Thank sir.
Feb 18, 2011 | HP Compaq 6735s Notebook
Armstrong upflow,unit works intermittent problem,call for heat nothing happens,error code of 5 blinks then 6 blinks. i have no manuel, and the panels dont have the codes on them. anyone have access to the...
Armstrong
FAILURE CODES
LED Status Fault Description
Off
No Power to the System Control
Steady Flash (11 or more flashes with no pause)
Normal Operation (Standby or call for heat)
2 Flashes
Pressure Switch Closed When It Should Be Open
3 Flashes
Pressure Switch Stuck Open 30 Seconds or Longer After Call for Heat (System in 5-minute delay mode before next call for heat). On/off switch in "off" position during a call for heat will generate this code.
4 Flashes
Open Limit Switch or Limit Switch Circuit
5 Flashes
Flame Sense Signal Sensed Out of Proper Sequence
6 Flashes - pause - 1 Flash (see Note 1)*
Soft Lockout Type 1 (Failure to light within 4 trials for ignition)
6 Flashes - pause - 2 Flashes (see Notes 1 & 2)*
Soft Lockout Type 2 (Flame sense lost during run)
6 Flashes - pause - 3 Flashes (see Notes 1 & 2)*
Soft Lockout Type 3 (Pressure switch opened during run)
6 Flashes - pause - 4 Flashes (see Notes 1 & 2)*
Soft Lockout Type 4 (Limit or limit circuit opened during run)
6 Flashes - pause - 5 Flashes (see Note 1)*
Soft Lockout Type 5 (Flame has gone away after Error Code 5)
6 Flashes - pause - 7 Flashes (see Note 1)*
Soft Lockout Type 7 (Self-check failure)
10 Flashes* - SV9520H8034 only
Line Input Voltage Polarity Reversed
Dec 12, 2009 | Coleman Heating & Cooling
MY SONNY PROJECTION TV HAS NO PICTURE AND SENSOR LIGHT BLINKS 6 TIMES, NO SOUND JUST ONLY THE RED LIGHT THAT ALWAYS BLINGKING AND EVEN ITS IN THE OFF POSITION STILL BLINGKIN
hello o Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
shaun
Oct 18, 2009 | Sony Televison & Video
Hp dj 5550 printer
DriverHP DeskJet 5550 InkJet Printer
Jul 10, 2008 | HP DeskJet 5550 InkJet Printer
Kyocera km C-6
Hi my name is xptareq2000 .My copier error code is 000 C6
How can i reset it please help me any one
Mar 02, 2008 | Office Equipment & Supplies
Error code C-6 for kyocera km 1500
c6-400 code error is poor connection (power supply)
press start and clear/stop button
the code is inizialized
Mar 02, 2008 | Kyocera KM-1505 Copier
Kyocera KM-1505 Copier Logo
669 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Chris Schutte
Marvin
Marvin
Adorjani Laszlo
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
