ERROR UF- Copier displaying error code: UF. What does it mean and how to resolve or clear it? The copier can initialize when I turn on the popwer but cannot copy due to error. I carried out simulation 02 and I was able to print several copies but when I lleave simulation. UF displays again. I'd checked the developer powder and found out that it's running out. Does it have something to do with the error? I'll appreciate any help or assistance you will extend to me. Thank you so much.
  • Tony GEE Mar 03, 2008
    Gestetner Destktop 2412Z Copier displaying error code: UF. What does it mean and how to resolve
    Thank you so much.
  • 1,326 Answers
I can help you, but what kind of copier is it? What make and model?
Posted on Mar 03, 2008
3 Suggested Answers
  • 8 Answers
SOURCE: Gestetner-2412Z copier-error code UF
UF is a panasonic code,the u means user fix.If you have an users guide it will tell u what to do.
Posted on Mar 04, 2008
  • 120 Answers
SOURCE: Gestetner Destktop 2412Z Copier displaying error code: UF
disposal is full or door switch.
Posted on Mar 22, 2008
I get an FE code on my samsung WD0704RQQ short time after setting the machine on dryer mode. Please help as my manual doesnt have the code and its meaning.
http://appliancejunk.com/forums/index.php?topic=17042.0
I SUGGST REMOVING POPWER, SHUT OFF BREAKER, THEN RESET, IF IT DOESNT HELP IT WOULD NEED SERVICE
Apr 14, 2016 | Samsung Washing Machines
What is the reset for error code E000004-0010?
This is fixing error code. The E004 is heater has failed - this usually last the life of the copier. The 0010 part is that the copier was turned off without resetting the error not a problem to reset. After resetting the error, fire up the copier and write down the error as displayed if it comes back. The sub code is very important to correct the problem. Some codes mean you have to replace the fixing heater power supply or the DC Controller. This is how you reset the code: Press the additional function key, then press the 2 & 8 keys at the same time, then the additional function key again. Press copier, function ( across the top of display ), CLEAR, ERR, then OK. Turn off copier and power back up. If the error happens again you may have a major problem that a tech may have to resolve. Good Luck.
Nov 02, 2010 | Canon imageRUNNER 5570 Copier
Error code 021
Press
Function
7
monitor slowly 4 times
6
scroll down to SHIPMENT SET
set
wait for the fax to initialize and come back to READY
Sep 29, 2009 | Panasonic Panafax UF-585 Plain Paper Laser...
Error Code 720 on Panafax UF-9000
error 720 means unable to connect to the POP server.. incorrect POP server ID or POP server is down
Apr 24, 2009 | Panasonic Panafax UF-9000 All-In-One Laser...
Panasonic copier/fax UF 885
It sounds like you are stuck in the boot-up mode.
Try this:
Open the toner door and remove the cartridge
Turn the machine off
Open the document feeder by pulling straight up
While turning the machine back on, hold down the pointed switch actuator closest to the small glass
Close the document feeder..display should read "RAM INITIALIZE"
Scroll down to "SHIPMENT SET"
Press "SET"
Press "2" for "NO"
Wait for the machine to reboot (could take 5 mins)
Some times a bad toner cartridge will cause this.
If this does not work, you have a bad Main PC Board. Uneconomical to repair.
Sep 19, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
Canon ir 5570 - error E000100-0001
Hello prntrfxr,
E000100-0001 is a secondary code to the initial problem. It means verbatum " The power has been turned off and back on again without resetting the error ". So, there was a previous error code that instructed the customer to turn off the main power and turn it back on in an effort to reset the code. Unfortunately this must have been an error code regarding the fusing system. Canon designed the copier to prompt the customer to power the copier off and back on for all error codes, and more often than not the copier can recover to some degree or another. Fuser codes on the other hand WILL NOT reset even though the display says to power off/on . You will need to go into service mode to reset the error. Press "additional functions"......then the numbers 2 and 8 at the same time and then additional functions again. If you have followed these steps properly you will now be in service mode and a different screen. Just follow these instructions. Press copier. Press functions.Press clear.Press err.Press ok. Power off and on . This WILL clear the code. However, if the problem still exists the code will return of course. THAT code is the one we need to troubleshoot! :-)
Apr 17, 2008 | Canon imageRUNNER 5570 Copier
Mar 03, 2008 | Gestetner DSm515pfd Digital Copier -...
UF Error code-Gestetner 2412Z
You may find it easier to solve the problem by asking the same question under its original manufacturer model........Mita DC1257
Good luck
Mar 01, 2008 | Ricoh Aficio 450 Copier
Error Code: UF
failure of data transfer between boards.-or defective of backup battery.cofirm good connector pluging and good soldering points in boads.
Feb 29, 2008 | Office Equipment & Supplies
474 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
