Question about AMD Athlon XP 2600+, 2.08 GHz (AXDA2600BOX) Retail Processor
AMD Athon XP 2600 dropped speed
Turned my comp on was working away and it rebooted by itself, when it restarted the CPU speed had dropped down to 1250. Tried restore, AMD web site (no help what so ever), even had a good look thought the BIOS, i just can get the 2.6gig speed back, appreciate any help
  • Anonymous Sep 02, 2008
    kernel stack error and freexe frame
  • 32 Answers
Some times when a computer shuts down unexspectedly like that it will reset itself back to its defaults in bios thinking there was a problem. Go in there and check your cpu settings. The fsb should be set to 266 mhz. Make sure it didnt default back to 133 mhz.
And FYI the 2600 is acutally a 2.13 gig cpu not a 2.6 gig..
Posted on Mar 02, 2008
What must I do into the bios To changes the cpu
Apr 17, 2010 | ASUS A7N8X-X Motherboard
Amd athlon xp 2400+ problems witha epox ep-8kra2+ motherboard?
It sounds to me like the processor that you bought is not fully supported in the current bios in your mobo. I would check the epox website for newer bios. Be careful flashing the bios, if you misstep in the flash, you may end up with a brick. If you are successful, you should be able to run the processor at the speeds you expected, though within the limits of the hardware on the mobo. Also look at the spec's for the mobo on the site to see if your processor is listed as being supported.
Feb 14, 2010 | EPoX EP-8KRA2+ Motherboard
2600+ with ASUS MB A7V266-E/AA
Here is the CPU Support list from Asus Support, for the Asus A7V266-E,
Scroll down the list. 34th one down, that is listed.
1.Did you get the Athlon XP 2600+ that has a 266MegaHertz, (MHz), Front Side Bus? (FSB)
The AXDA2600DKV3C?
There is an Athlon XP 2600+ that has a 266MHz FSB, and one that has an FSB of 333MHz. <-This one Won't work.
Model number ->AXDA2600DKV3D will Not work.
Both are Thoroughbred A/B Core models.
The AXDA2600DKV3C has a 12.5x multiplier.
Your 1900+ has a 12x multiplier. (AXDA1900DUT3C) They both have an FSB of 133MHz. (Shown as 266MHz because AMD processors are 'Double-Pumped')
A.The AXDC2600DKV3C will not work. It has a 16x multiplier. (Thorton Core)
B.The AXDC2600DKV3D will not work. It has a 333MHz FSB. (Thorton Core)
C.The AXDA2600DKV4C will not work. It has a 15x mulitplier. (Barton Core)
D.The AXDA2600DKV4D will not work. It has a 333MHz FSB. (Barton Core)
E.The AXDA2600DKV4E will not work. It has a 400MHz FSB. (Barton Core)
2.Are the jumper blocks -> CPU RATIO, and SYSCLK, still set in the Jumper Free Mode?
By the factory default settings these jumper blocks, (DIP switches), should already be set to Jumper Free Mode.
The white DIP switches should be in the OFF position. (The white switches will be DOWN, towards the numbers on the jumper block CPU RATIO. They will be UP, away from the numbers, on the jumper block SYSCLK))
The CPU RATIO jumper block is right above the processor. It is a blue rectangular block.
The SYSCLK jumper block is down the motherboard, right below the AGP graphics card expansion slot. (And above the first PCI expansion slot)
If those two jumper blocks are not set to Jumper Free Mode, set the DIP switches in the jumper blocks to this setting.
Now go into BIOS Setup. In the main menu use the Right Side Arrow key on your keyboard, and highlight Advanced.
If -> CPU Speed is set to Auto, you won't have access to set your CPU parameters. If it is set to Manual, you will see them. If it's set to Manual, write down the headings, (CPU:System Frequency Multiple, System/PCI Frequency (MHz), and so on) Write down the numbers to the right of these headings. If something goes wrong, you can go back into BIOS Setup, and change them back.
1.CPU:System Frequency Multiple should be
2.System/PCI Frequency (MHz) should be
3.System/DRAM Frequency Ratio should be
4.CPU Vcore should be (1.750)
5.CPU Level 1 cache, and Level 2 cache should be (Enabled)
6.CPU Level 2 cache ECC Check should be (Disabled)
7.BIOS Update should be (Enabled)
8.PS/2 Mouse Function Control (Auto)
9.USB Legacy Support (Auto)
10.OS/2 Onboard Memory >64M (Disabled)
Leave the rest alone.
The AXDA2600DKV3C uses 1.65 volts, has a 12.5 clock multiplier, and a 266MHz FSB. (You will see 133MHz, and set all your settings to 133MHz. AMD processors are 'Double-Pumped'. Intel processors are 'Quad-Pumped')
Aug 10, 2009 | ASUS A7V266-E (A7V266-E AA/PA/WOR)...
How to get my CPU to run at the correct speed
Your FSB should be 400 MHz for the Athlon XP 3200+ processor.
CPU-Z shows your core speed at 1320 and your FSB at 241. If you multiply those numbers by 1.66, you get 2200 and 400. So all you have to do is get the board to the correct FSB speed of 400 and your core will be right.
There are two MSI boards with the number CPU-Z gives you. Board 1
Board two
The AMD page doesn't show the core voltage for the older processors, they do for the current ones. I looked at the MSI site and didn't see their manuals online for the motherboards either, sorry. I'm not positive it was changed using a jumper though, you saw nothing in the BIOS to set it? If the jumpers are on the board they may be labeled FSB and you can try the various positions.
Hope that helps, good luck.
Jan 11, 2009 | AMD ATHLON XP,3200+,512k Cache...
Finding compatible motherboard for new CPU.
Hi kaufam7.
this motherboard will work with your AMD CPU
Biostar M7VIG 400 Socket A+ Athlon 2600
you can check it on this website below
best of luck
Nov 19, 2008 | Computers & Internet
Reboots every 30 seconds or so
Check all your fans and heat sinks including power supply one
Also check CPU heat sink for fluff and dirt
Sep 09, 2008 | Foxconn WinFast K7S741MG Motherboard for...
Win xp didnt detect new processor
Go into device manager and uninstal "acpi multiprocessor" (in computer tab) and reboot and cpu should be detected properly.
Hope that sorts it for you? :)
Jan 04, 2008 | AMD Athlon 64 X2 4200+, 2.2 GHz...
Problem with mobo upgrade ... From Intel CPU to AMD CPU
hi dale, itsnot a good thing when you see the blue screen of death, cause recent changes hardware normaly maybeif you have changed from intel to amd using mobo and all parts are amd now , maybe if you reinstalled your operating system the new hardware that is installed will accept you software cheers steve good luck
Apr 26, 2007 | Jetway 939GT4-SLI-G Motherboard
AMD Athlon XP 2600+, 2.08 GHz (AXDA2600BOX) Retail Processor Logo
70 people viewed this question
Top AMD Computers & Internet Experts
Alun Cox
Robert Monigold
Robert Monigold
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
