Question about Nokia 5300 Grey Cellular Phone
Nokia 5300 need to reset the phone to manufactures mode pls
I cannot use my scrool key and music keys .when i open scroll mean i cannot use any keys except number keys
Posted on Jan 01, 2009
  • 4,102 Answers
Hi this is the code to do a factory reset type in *#7780#
this will then reset your phone
Posted on Mar 05, 2008
Canon2202ir E0000-000 This error code deals with the fuser unit. It is saying that the fuser is not warming up. It needs to be reset in service mode.
How can I enter service mode on canon ir 2202? - Fixya
www.fixya.com/.../t25374950-any_one_help_me_enter_service_mode_...
Jan 19, 2015 - In standby mode, press the "Settings/Registration" key. 2. Press the "Reset" key. 3. Press the "Back" key. 4. Press the "Settings / Registration" ...
Error Code ir 2202n - CopyTechNet.com
www.copytechnet.com > ... > Copier Technical Discussion > Canon
Nov 22, 2014 - 3 posts - ‎2 authors
... pls help me ....i know how to enter service mode but ......pls help. ... Copier Technical Discussion · Canon. [Error Code] ir 2202n ... ir 2202n. how to print jam history in ir 2202.......i dont know pls help ... mm its a new machine , i need to know how to enter the service mode if u please ... Press the "Reset" key. Error Code canon image ronner 2202N
Aug 21, 2014
Canon IR 2200 error E000001-002
Jun 18, 2009
More results from www.copytechnet.com
Dec 21, 2015 | Office Equipment & Supplies
I have a xda exec phone .the screen is blank with a serial up and 1.0v down the screen .. pls tell me what to do ..
Your phone is in bootloader mode. If you have not intentionally put it in that state, it might have entered it after an usucessful ROM upgrading process. Anyway, to get out of that state, just soft reset your device. The reset pin is located at the left side (in portrait mode, or at the back of the phone, when its screen is slided open). Just lightly press that pin with the stylus pen.
Hope it works for you.
Anyway, please, let me know if you need further informations.
Regards,Carlos
Feb 27, 2012 | O2 Xda Atom Exec Smartphone
I want to reset the password for my imate pdal phone..because i dont know the password.kindly teach me how,pls
If you can get into the menu go to phone settings and reset to factory default settings and look up the factory default password on the net, You should be able to find it from the manufacturer of your phone, Hope this helps,
Sep 19, 2011 | Cell Phones
Need to reset plantronics voyager pro heatset it pair with wrong phone and i cannot reset it or know how
to reset or pair your bluetooth device you need to put the device into discovery mode.To do this most manufactures use the power button,by holding the power button down for 8 to 10 seconds while turning the device on it should put it into discovery mode.Usually a light will remain on then you can find or search from your phone for new device.Once your phone has discovered the device it will ask for a pin\pairing code .Once again most manufactures use a 4 digit pin\pairing code they are as follows,0000,1234,9999, or 1111,try them in this order one will work. Hope this helps
Mar 22, 2011 | Plantronics Discovery 925 Bluetooth...
How to reset a bluetooth i.tech i.oval 303
Most manufactures have a factory 4 digit pin that once you have put it to discovery mode,usually blue tooth manufactures use the power button to reset the discovery mode,by holding the power button down while turning it on keep holding the power button for 6 to 10 seconds a light should appear on your device,thus the device is in discovery mode,once your blue tooth device has been put into discovery mode you should go into your phone menu and turn the blue tooth power on,then it should have an add new or seach for device,click that and it should pair with the phone,you will need a 4 digit pin pairing code,Most blue tooth manufatures use factory pairing pins they are as follows 0000,1234,1111,or 9999 try them in that order,i hope this helps you
Feb 22, 2011 | Itech i.Tech i.Oval 303 Bluetooth Headset
I-mate Ultimate 8150 stop in welcome screen
Your Phone Is Ok ,No Prob In OS,So Dont Worry
Just Hard One Key Is Jam So Kindly Find out Before Power On
Hint: You Can Start Your Phone For Testing Mode:::> Press Window Key>Press Reset Button>Release Reset Button(Window Key Dont Release)>Wait ,Your Phone Is Start ...Awsome
But You Need Find Out Jam Or Block Key Otherwise Other keys Not Work Proper
Pls Press Helpful If you got Solution,Thanks
Nov 21, 2009 | i-mate Ultimate 8150 Smartphone
3650 phone start up failed pls help me
u have to reset or mobile ..to do that follow this
1. Removed your MMC card first.
2. Make sure you have at least 3/4 charge of battery before performing the
" Safe Mode, and follow-by phone reset *#7370# ". Or maybe you can have the
charger on and plugged into the phone to act as a full power source.
3. Press and hold the ABC key and then press the power button.
Remember not to release the ABC key till you seen the
"Safe Mode" standby screen.
(Fyi, there's no special indicator that telling yo're on a "Safe Mode"
standby screen.)
4. Once in the "Safe Mode" stanby screen press *#7370# to carry-out "Phone Reset"
task.
5. Once "Phone Reset" task completed and back to normal standby screen again,
switch off your phone and re-insert your MMCmag-glass_10x10.gif card.
If any error showing on the phone boot-up, please have the memory card formatted and by next phone
start-up you will not have the error msg again.
If you some important data or programs files on your MMC card, please use
a card reader to have them copied onto a pc before performing memory card
formatting
Dec 04, 2008 | Nokia 3650
Nokia 5300 Grey Cellular Phone Logo
52 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
