Question about LG WM-1290FHB Front Load Washer
Warning light fe is coming up on lights thanks
  • 57 Answers
Go to:
http://www.lge.com/
Choose your country and download your free manual.
Cheers.
Satisfactory response? Please vote! :-)
Posted on Mar 02, 2008
?why brake switch fuse warning light illuminate for 2015 hyundai santa fe?i need more information and detail for this consern
There shouldn't be a warning light for the brake switch fuse. This vehicle is under warranty. If any lights on, contact dealer for your concerns
Jul 13, 2015 | 2015 Hyundai Santa Fe
Tailgat warning light stays on 2001 santa fe
BAD GROUND ON SWITCH OR SWITCH ITSELF
Feb 26, 2015 | 2001 Hyundai Santa Fe
Warning light is on....looks like a pump symbol
The only one that looks like a pump to me is the low fuel warning light but there are others I have had people tell me was a pump. I have attached a link that has the symbol names in red just click on them until you see the one you have on in your vehicle (after clicking there is a picture) or you could look it up in your owners manual (which is what this link is from the Hyundai site).
Hyundai Santa Fe Warning lights Warning and indicator sights Features...
Mar 25, 2014 | 2011 Hyundai Santa Fe
Fe warning light
Fe error code means "Water Overflow Error". Check the upper level sensor of the machine.
Dec 22, 2013 | LG Washing Machines
My dashboard lights (battery emergency brake light & air bags) are flashing on my dashboard while driving but go out when I come to a stop on my 2001 santa fe
Whenever this warning light or any other stays on in the dash it is indicating that the systems control module (or the system sensor in the case of lights like low oil pressure, door open indicators etc.) has detected a fault, it then disables the system (this applies to ABS,TCS, TCM, SRS and BCM faults and others) as long as the light is on. You must now have the dealer hook up a special electronic diagnostic tool and "scan" the system for the fault code that is stored for the problem(s)
Legend of Abbreviations. ABS Antilock brake system.TCS Traction control system, TCM Transmission control module, SRS Supplemental restraint system, BCM Body control module
Oct 17, 2012 | 2001 Hyundai Santa Fe
I have a 2004 Hyundai Santa Fe. The low fuel light came on after I put in 3/4 of a tank of gas. Then the light went off, and all seems fine. It was a 100 degree day when this happened. Could that have been...
Well anything is possible.
The low fuel sensor for the warning light is part of the gauge in the tank. As long as the gauge works and the light does not come back on I would not be concerned. You may want to watch your mileage to make sure you don't run out of fuel if the gauge does fail.
Jul 25, 2012 | 2004 Hyundai Santa Fe
TCS light, ABS light, 4 wheel drive light, come on periodically! What causes this? What is the solution? Thanks in advance
Possibly a wheel bearing is going out, which can cause the speed sensor to lose signal quality. Please see my tip at http://www.fixya.com/cars/r6003525-abs_traction_control_lights . These are genericinstructions. If you get stuck or need specific instructions for your car, please get back to me with model, year and engine info.
May 05, 2011 | 2004 Hyundai Santa Fe
2003 Hyundai Santa Fe ABS light is on along with TCS light
you may have damaged the ABS sensor or wire to the sensor up front check the wire that runs from the inner finder well and make sure it connected to the ABS sensor on the spindle
Jul 14, 2009 | 2003 Hyundai Santa Fe
Dashboard warning light
Is that not the warning light for your cruise control?
Jul 10, 2008 | 2006 Volkswagen Golf
Warning light on my car's dash board
hi, this warning light is either telling you the water level is low or the temp is to high.
If this light comes on as soon as the ignition is switched on then its more than likely low water level or it could be that the sensor itself as give up working, these are not that expensive to buy but check your water level first and top up if needed.
If the light comes on after you have been driving for a while then this is telling you it is getting to hot which usually means the thermostat needs replacing.
Any of these problem shouldnt cost to much to repair as their are plenty of parts available so will be cheap and easy to get.
Hope this is some help to you if you have any problems or questions then give me a shout back.
As for driving 300 miles then if the light comes on as soon as you start the car then you should be ok but if it comes on after the car has been driven then it could over heat and this can cause the head gasket to blow and then this mean very expensive repair. So if this is the case then when the light comes on its best you switch of and rest for 30min to get the temperature down. If the lights on as soon as you start the car then you should find you will be ok.
May 20, 2008 | 2003 Hyundai Santa Fe
LG WM-1290FHB Front Load Washer Logo
67 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
