Question about Tomtom One Europe v2 GPS Receiver
Tomtom one europe
When starting to give instructions voice goes off
I have no saund on my gps tomtom
Posted on Mar 17, 2008
I need to know how to use my device. It did not have an instruction booklet
Usually, you can download the Reference Guide in PDF or HTML format from the TomTom website. The Reference Guide contains detailed information and full instructions for your TomTom product.
Check this link:
http://download.tomtom.com/open/manuals/Start20_series/manual.htm
Mar 31, 2015 | Tomtom Start 20 Europe
Hi I have a to tom go 500. The voices worked fine when I tested it in New Zealand. I then downloaded the Europe map, assumed all was well but on arriving in Europe I find that I cannot get the voice...
It may be possible that the (Europe) map version that you have doesn't have voice instructions (data) that is compatible with the navigation software (that you have on the TomTom GO 500). If you can indicate the navigation software version and the Europe map version, that possibility can be checked further.
Sep 07, 2013 | Tomtom ONE GPS Receiver
Useless instruction book!
manual download
go to tomtom website ----> support scroll down at the right hand side click Find downloads
Apr 17, 2009 | Tomtom ONE 3RD EDITION GPS Receiver
Tomtom one classic frozen
i switch my tom tom one classic on it puts langues on in alpherbetical order i tap english uk it asks yes or no i tap yes it says i have to tap screen anywhere to set some preferences i tap them all till it comes to select voice i select voice it takes ages before it goes back to the beginning
Mar 01, 2009 | Tomtom One Europe v2 GPS Receiver
Tom tom one classic europe
  1. Tap the screen
  2. select "preferences"
  3. move right with the arrow button until you see icon for "change language"
  4. select/ choose " change language"
  5. move using arrow buttons until you see "english2 then select that
That should be it .... sorted.
Good luck
Dec 26, 2008 | Tomtom One Europe v2 GPS Receiver
There are no speaking directions on my TomTom GO720 e.g. for 'turn left' or 'take the next exit' or 'continue for 3 miles'. It only beeps for speed cameras etc. We have ticked all the boxes on the sound...
Hi there
As the TomTom is making beeping sounds, its a good indication that its not a hardware fault, it sounds to me its a software issue.
What you could do is try to reinstall the voices on your device. To do this, follow these steps:-
I presume you have TomTom Home installed already, if not you can download it from
http://www.tomtom.com/home
STEP 1 Make a Backup
  • Connect your TomTom to the computer and switch it on
  • Open TomTom Home
  • Click on 'backup and restore' and make a backup if you haven't done so already
Once the backup has been made, please do the following:-
STEP 2 Remove the existing voice files
  • Open My Computer, you will see the TomTom as two removable drives, one will be the internal memory and one will be for the SD card slot on the device.
  • Click into the Internal memory drive, you should see a whole load of files and folders.
  • You should see a folder called LoquendoTTS or Loquendo, click into this folder and delete the contents (all the files and folders inside the loquendo folder)
  • Go back to the root directory of the TomTom and delete the folder 'Voices'
STEP 3 Download and Reinstall the voices via TomTom Home
  • Go back to TomTom Home
  • Click on Add Maps, traffic and Voices
  • Select Voices. Loacate the voice of Jane and Tim and add them to your device
  • Go back to the main menu of TomTom Home, click on Add Maps, traffic and Voices -> Computer Voices and install the voice of Kate or Simon (UK English computer voices)
  • Close TomTom Home and also Close it from the system tray. (in the bottom right hand corner of your screen down by the computer clock, you should see a red icon for TomTom Home, Right click on it and choose 'exit')
STEP 4 Install the Clear Flash Tool from TomTom
  • Once Home has closed completely, please download and install the clear flash tool from:- http://www.tomtom.com/updates/clear_flash/clear_flash.exe (Home must be completely closed, otherwise it may not install correctly)
  • Accept the license agreement and keep pressing the Next arrow until the clear flash tool has installed.
  • Your device will start flashing to say there is some activity on your device
  • When your device has finished flashing on the screen (might take a minute), use the 'safely remove hardware' feature of your PC to disconnect the TomTom
  • Switch the TomTom off then take it out of the dock.
STEP 5 Test the voices
  • Switch the TomTom back on, but not connected to the dock
  • Let it load up to the main navigation screen
  • Tap onto the menu and tap onto 'Change Preferences -> Voice Preferences'.
  • Select a non-computer voice i.e. Jane or Tim and press test. You should now hear the voice instruction
  • Try selecting the voice of Kate or Simon i.e. the computer voices, and press test, you should now hear the computer voice.
This should get the voices working again, if not it might be worth giving TomTom Support a call and they can talk you through it.
Hope this works for you
regards
The Warlock
Sep 17, 2008 | GPS
Tomtom one europe
Power up your tomtom. On the Map screen . Tap the screen , then select " change preferences " , Then scroll right until you see the " Lips " icon , Select the "Lips" under it , it says " select voice " . once in there , you can scroll left or right allowing you to choose the voice / language you require . Hope this helps.
Sep 06, 2008 | Tomtom One Europe v2 GPS Receiver
TomTom One Europe
What is happening is your map updates are being copied onto your memory card without overwriting the old maps hence you are running out of memory.
In the tomtom home browser you should be able to delete your old map before installing the new one. Make sure you have a back up of the map card before you try this though so you can reinstall if something goes wrong.
Also have you replaced the voice prompts on your tomtom? The voice files take up a lot of memory so if you have put new ones one without removing the old ones you will be wasting memory.
There is one window in TThome that lists eveything installed on yuor card so have a good look at this and see what you can get rid of.
Oct 30, 2007 | Tomtom One Europe v2 GPS Receiver
Tomtom One Europe v2 GPS Receiver Logo
61 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Will Halftowaite
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
