Back to:
Tags:
Routers
Generic problem for all Routers
Wireless speed (by 2 users)
posted by jonseyi on Mar 02, 2008
Hi, I have the belkin N1 wireless router but it does not give me the speed i expected, My desktop Mac is connected and runs at 130mbps but my vista and xp laptops only run at 54 even with the N1 card fitted, is there a solution.
Regards Ian
Comment by jonseyi, posted on Mar 04, 2008
The card and router are both Belkin N1, No's F5D8071 (card) and F5D8231. When I contacted belkin they told me to try changing my wireless security settings but i would have thought that if that was the problem then the mac would only run at 54 also. Regards Ian
Comment by jonseyi, posted on Mar 11, 2008
Problem solved, changed the security authentication to wpa-psk and the encryption technique to aes instead of tkip. Now getting 300mbps steady with the n1 card on the xp laptop and 150 on the vista with the built in wireless.
Regards Ian
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by rajgc01, posted on Mar 02, 2008
I am also facing same problem
Best Solution
Thanks for Trying (70)
pianofun
Rank:Guru Guru
Rating: 85%, 92 votes
These caards and wireless router can be tricky.  The problems you are encountering may have to do with the brand of the router and card.  If they are mde by diff. manufacturers or the speed on the box is different than the router, then it will be slower.  Is your card 801.1 or a tiny bit different?  Make sure they are the same number.  Otherwise, you may have to make do with the different speeds, or else, call your isp to upgrade
Rating Locked! (?) jonseyi has rated this solution as Thanks for Trying
Thank You!
Was the solution helpful?
Show your appreciation by commenting on wireless speed:
I don't want to Accept this solution
Can you Help with these Routers problems?
Routers
have 1 laptop and wan to use wireless
Belkin (F5D5231-4) Router
I purchased a new laptop and am trying ot install the...
Routers
attempting to connect a printer to the wireless system....
Linksys Wireless-G WRT54GS Router (e125894)
We have several computers in our office that work off of...
Gateway 802.11g Wireless DSL/Cable Router [...
My belkin wireless card driver didnt install and i can not...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
