Question about Epson Stylus C84 InkJet Printer
Does not print on paper but with new ink replaced
My unit used CISS before. i shifted to genuine ink.
all is okay on screen, but nothing is printed on paper.
any help, pls...
  • 2 more comments
  • Anonymous Mar 06, 2008
    printer will not print on paper
  • LauraOnAMac Mar 30, 2008
    I have the exact same problem. Can you replace the nozzles yourself?
  • mkrob Apr 10, 2008
    Epson C82 & C84 I have not used for 4-6 months. Neither printer will laydown any ink of any color on paper.
    Actions and observations as follows:
    The C82 diag showed no Black, Cyan Magenta & Yellow showed 3/4 full.
    Install new T0321 Epson Cartrige(black) and run all cleaning and head checks, ect. Printer will not laydown any ink of any color on paper.
    The C84 diag shows 1/2 black and Cyan Magenta & Yellow showed 3/4 full. run all cleaning and head checks. Printer will not laydown any ink of any color on paper.
    Not a smudge not a drop of ink to the paper!
    Anyone have a clue?
    Marc
  • Anonymous Apr 24, 2008
    i have the same F'ing problem.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 66 Answers
Proably is the nozzle in printhead clogged by dry ink because you dont use genuine ink from epson and i suggest a replacement of the head because it is almost impossible to clean it out
Posted on Mar 17, 2008
Hp office jetpro 8600 will not print
Basic things to try: -you could start by clicking on devices and printers button on MS start sphere - click on your installed printer right click on "see whats printing and see if any documents are queued in printer - cancel them if there are.
have you checked your ink levels - have you checked ink cartridges are okay (genuine) cartridges if you have just changed them. Is there plastic strips on ink cartridges if new?
have you checked all connections to make sure all peripherals are connected okay.
Have you tried restarting your computer. Have you checked nothing is jammed either in paper tray or inside printer. Is there an error message on the printer console?
sorry this is not a complete solution but you might try these things first.......
Feb 08, 2013 | Dell Studio 1737 Laptop
HP Photosmart 3210xi - some colors (magentas) will not print
Remove the magenta cartridge, and try cleaning the head with alcohol, maybe with a small paint brush or an acid brush. It sounds like ink has dried and plugged up that head.
Jun 04, 2017 | HP Photosmart 3210 All-In-One InkJet...
Ink is not visible on paper
First NEVER raise the tanks of a CISS above the height of the printer otherwise all that is going to happen is that the ink will syphon out and end up getting everywhere.
As you have not used the printer in a long time there wil be dried ink in the print heads 3x head cleaning is nowhere near good enough to clear the blockages.
One thing I would do as you have a set of OEM carts is the following presuming you have the equipment.
Drill a small hole in the top of each cart and extract as much ink as ps=ossible with a syringe (you can put it in the ciss ink tanks) and replace with head cleaning solution. Reseal the ink carts (if clean selotape will do) insert carts and do 5x head clean, leave 24hrs and do 5x head clean again. This will allow the head cleaning solution to get right insine of the print head, soften the dried ink and then flush it through..
A lot of messing about I know but you've just shelled out a few bob for a CISS so it's worth it.
NB
Make sure you keep the CISS carts above the tanks whilst outside of the printer.
Aug 24, 2009 | Epson Stylus C88 InkJet Photo Printer
Hi my epson r285 with ciss is leaving ink blotches all over my print outs, predominantly black, but less frequent with the other colours. This is only a new printer. Head cleaning, noxzzle cleaning and...
It might be caused by waste ink at bottom plate around head sprayer. For some CISS (bottle) design, ink will flow to head, and then flow to pad, when printer off. So, you must close respiratory hole at bottle when printer is not used. For cleaning, turn off printer (unplug power) when head is not in parking position. Move head to center. Put wet tissue (with cleaner or hot water) at top of pad (at head cleaning mechanics). Move head to parking position. So bottom plate contact with tissue. Wait for 10 minutes, repeat 3 times. Check nozzle.
Jun 21, 2009 | Epson Stylus Photo 1290 InkJet Printer
Epson CX5500 with CISS ink supply not printing
Ive replaced all the cartridges on my epson 5500 but still nothing prints. Any help gratefully received
Jun 19, 2009 | Epson Stylus CX5400 All-In-One InkJet...
How to fix CISS Unit to Epson RX 610 printer?
replaced all ink colours and now a colour print is almost all black and white with a tinge of magenta? how can i fix this
Mar 29, 2009 | Epson 6 Color Inkjet 5760x1440dpi Photo...
Hi! I have the Epson DX4850 All-in-one printer. I just purchased a Continuous ink system for it and tried to install it. I followed the installation manual very carefully and when I had finished installing...
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Dec 25, 2008 | Epson Stylus DX4850 All-In-One InkJet...
No ink on paper
You need a new print head.....if your pixy is 3 years oldish...only thing that worked for mine try ebay or states.
Mike
Mar 03, 2008 | Canon PIXMA iP5000 InkJet Photo Printer
Cannon smartbase MP360 inkjet printer
Looks like you are either using non genuine inks or have worn out the print head. Just replace the print head and use genuine ink, your print head will last longer and your colors truer. Non genuine ink is cheaper but the profit on it is huge, thats why lots of people sell it. Remember you get what you pay for.
May 20, 2007 | Canon SmartBase MP360 All-In-One InkJet...
Epson Stylus C84 InkJet Printer Logo
80 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
