Question about Karcher 2500 PSI Pressure Washer
Bosch aquatak 120i pressure washer/tetergent
This is my 3rd time using this machine. I filled the detergent tank but no detergent comes out. only water !
  • cahahn Apr 05, 2008
    I have a 2700psi honda pressure washer has the hose that you put in a bucket an then gets cyphoned into the pressure washer it seems to start going thru the tube but then stops i dont know why i cant get the detergent to go thru the washer. I have put a new hose an screen on it i have adjusted the pressure but still nothing im hoping you may have a solution
  • Anonymous Mar 21, 2014
    when i use high pressure spray water comes out of the detergent dispenser
The end of the chunky sprayer has a grad scale-one end is MAX and you think the other is MIN buut it is MIX-set on min it mixes the det. with the water --wont mix on any other setting.
Posted on Apr 24, 2009
Hi Guys there isnt a problem with your machine you just need to pull the end of the spray lance out -the lumpy bit where the water exits the machine (it kinda clicks out)
Posted on Jun 27, 2008
    Problem Solver:
  • 14 Answers
Hi hope i can help!!
Try this empty the detergent tank then have your machine ready to work then half fill the tank with warm water and use the machine, this may take a few attempts so dont think its a 5 min fix! What happends is the detergent when left in the machine goes thick and gooy the warm water thins this and eventualy cleans it out but dont use boiling hot water this may damage the seals.before storing machine away do this method.
Hope this helps .Sean
Posted on Mar 04, 2008
Which oil should be used for Bosch Aqautak 100 pressure washer
No oil mentioned in the instructions
https://www.tooled-up.com/artwork/ProdPDF/Aquatak110_manual.pdf
more information here
What is the quantity & the type of oil of Bosch Aquatak 10 pressure washer? Thanks
The link has changed in the meantime i see
You can use every EP zinc-free hydraulic oil what you want for it PERLUS ZF46 is a very good alternative
Bosch aquatak 100 plus pressure washer instruction manual - Fixya
www.fixya.com/support/t12257542-bosch_aquatak_100_plus_pressure_washer
Apr 1, 2012 - Hi, A 6ya expert can help you resolve that issue over the phone in a minute or two. Best thing about this new service is that you are never ... What is the quantity & the type of oil of Bosch ...
Jun. 19, 2016
Oil leaking from bosch aquatak 110 pressure washer
Nov. 16, 2013
What type of oil for aquatak 1250
Feb. 26, 2013
Re Bosch Aquatak 100 Plus pressure washer leaking an
Aug. 7, 2011
More results from www.fixya.com
Bosch Aquatak 100 (part1) - YouTube
? 2:34
https://www.youtube.com/watch?v=J1LE9bnUat0
Mar 20, 2011 - Uploaded by bogdanxp2000
Bosch Aquatak 100 high pressure cleaner, engine opened. ... How to Disassemble and Reassemble the Pump ...
Jun 04, 2018 | Bosch Garden
Shampoo will not come through
remove pressure nozzle or use low pressure nozzle only for shampoo
Apr 20, 2014 | Bosch AQUATAK 150 PRO X Pressure Washer
Bosch aquatak
First off check your pressure wand / water nozzle make sure it's clean. if that doesn't help then it could be your water pump.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/anthony_e4f197748c31eabd
Jan 14, 2018 | Garden
Bosch aquatak power washer will not start
Check to make sure the outlet (power supply) is energized. This piece of equipment is supposed to be used on a ground-fault protected circuit, so make sure the ground-fault on the outlet didn't trip or the circuit breaker (fuse) at the electric panel did not trip (or blow)
Check to make sure you are going through the proper starting procedures as outlined in your user's manual on page 8.
Follow the troubleshooting tips on page 10 of the user's manual.
Beyond that, Bosch requires that you have your power washer repaired at an authorized / qualified repair center.
I did locate a web site that shows an exploded parts view of the pressure washer, if that helps. http://www.magic-parts.co.uk/acatalog/BOSCH-Aquatak-1200-Plus.php
In case you don't have a user's manual, you can view it at: http://www.manualslib.com/manual/537062/Bosch-Aquatak-110.html#manual
Best wishes on your project.
Nov 08, 2013 | Bosch AQUATAK 115 PLUS Pressure Washer
A blockage in the inlet of an aquatak 115 plus.
nothing to worry about could be due to water intake,wear on nozzle or just the gauge
Oct 14, 2012 | Bosch AQUATAK 115 PLUS Pressure Washer
I have a Bosch aquatak 120i the motor keeps running all the time
Hello sir, that is a on going problem with power washers the pump not working, than works sporadically. the main cause is leaving the pressure hose hooked up to the machine over a long period of time,not draining hose & machine, in the winter time the hose & pump will freeze causing hose & pump to expand and burst.handle to leak busting the o rings, build up of calcium deposits from hard water clogging up pump nozzle,valves in the gun handle,clogging hose fittings and screens.one of these has to be your problem.you can find a parts brake down at KARCHER.COM.orRJ BOWERS.COM . and manuals,these are good info,sites,hope this helps.thankyou. ~~
Feb 19, 2012 | Garden
Bought bosch aquatak 100 pressure washer. No manual or instructions in box. Store bought at cannot help.
Contact Bosch directly, they have been very helpful in the past.
Robert Bosch (Australia) Pty Ltd
1555 Centre Road
Clayton, VIC 3168
Phone: (03) 9541 5555
Fax: (03) 9543 5485
May 07, 2009 | Bosch Washing Machines
Karcher 2500 PSI Pressure Washer Logo
1,764 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
