Question about Panasonic DMR-E55 DVD Recorder
DMR E55-P will not read DVD-R
Hi... My DMR E55 will play all commercial disc including CD-R. But it will not read DVD-R so it will not go into record mode. I tried to updatate it with firmware but still it cannot read a DVD-R disc.Please help me. Thanks.
  • benyto Mar 03, 2008
    Hello Palmbeach,
    Thanks for your response. I did not try it on a DVD-Ram disc, since all finalized recorded materials will be on a DVD-R format.
    the recording problem started gradually,it will record on any brand of DVD-R blank disc before until it became selective and will read only HP,TDK,Sony and imation blank disc.But recently it will accept an HP disc only and sometimes not,I have to switch off first the power and power it on again,the unit will go on selfcheck and can now read the disc This go on for about a few weeks until finally will not read all DVD-R disc,even his own previous recordings,playable on other units. It will load the DVD-R disc and display "READING.Then "CANNOT READ" Check the disc.Even if I switch it OFF and ON again, the problem is still the same, CANNOT READ THE BLANK DISC. Also it will not go into selfcheck mode anymore. I have clean the lense I believed you have incountered a problem like this and was able to fix it.
    I am a technician like you and will be very happy to hear a solution on this particular problem. thanks a million in advance..
  • Palmbeach
    Palmbeach May 11, 2010
    A few questions
    1) Have you tried using DVD-RAM discs?
    2) The DVD-R you are trying to use, is it a blank disc?
    3) Have you successfully used discs from the same pack before?
    4) What exactly happens when you put a DVD-R in the unit?
    5) What does the display do?
  • 185 Answers
Hi Benyto
Thank you for the information. Sorry that you are having such problems.
Nearly all the problems on ths DMR E55 are due to a faulty power board. The greatest load on the power supply is when the unit first reads discs and also when finalizing. Sometimes the unit cannot read discs and sometimes it continuously self checks.
Try replacing IC001 on the power board. This is a 5 pin regulator #STRG6353. This component gets very hot and the heatsink is poor. When I replace these, I use a larger heatsink and some heatsink paste which helps to prolong the life of the component. If you look at the regulator, you will see by the colour of the circuit board that it gets very hot. It fails after two or three years in all DMR E55s.
Be careful when you take the old regulator out because the print can lift away from the circuit board.
I have posted full instructions on how to replace the STRG6353 >HERE<
Hope this helps
Posted on Mar 03, 2008
  • 4 Answers
Try velocity dvd-r they should work just fine........
Posted on Mar 14, 2008
Will play commercial dvds but will not play home recorded dvds
The home recorded dvds disc have diffrence finalizing codes,that the Panasonic dvd recorder doesn't share those codes.That why u can't play those home recorded dvds discs.
Oct 24, 2010 | Panasonic DMR-E55 DVD Recorder
The panasonic dmr e55 will burn a disc from my video camera and play on the dvd player but no other dvd player. and i read all the instructions step for step
Have you finalized the disk after recording? Are you using DVD-R disks? Also, I can replay my recorded DVRs on my portable DVD player, but not on a TV with a built-in DVD player. That one is just to finicky.
Nov 19, 2009 | Panasonic DMR-E55 DVD Recorder
The dvd recorder will not recognize any discs. It attempts to read then states "no disc" or "no read". Can this be repaired or is the laser dead?
Hi! there are many reasons why a dvd is note reading. 1. dirty pick up lens, 2. defective spindle motor, 3. defective ribbon wire, 4. defective pick-up lens and defective mpeg board. but first things first try cleaning your pick-up lens with a cd lens cleaner.
Oct 16, 2009 | Panasonic DMR-E55 DVD Recorder
My panasonic DMR-ES 15 cannot read anymore!
There maybe a problem with the optic lens (dirt) try to clean it very gently with cotton, also the motor plate that holds the cd/dvd is not holding it very well so it not rotates at proper speed try to clean the both sides where the hole of the cd/dvd is when it´s inserted, if you think that you migth not have skills for that don´t do it.
Hope it help
Jun 25, 2009 | Panasonic DMRES15 DVD Recorder
Can't play recorded discs on other players or computer only DMR-E
TRY FINALIZING THE DISC IN THE SAME UNIT IT WAS RECORDED IN.
Mar 17, 2009 | Panasonic DMR-E55 DVD Recorder
Panasonic DMR E55 Won't record AT&T U-Verse programs!
Make sure you only use the correct type of discs: DVD-RAM or DVD-R for recording and DVD-RAM, DVD-R, DVD-Video, DVD-Audio, Video CD, CD-Audio (CD-DA) and CD-R/RW (MP3, CD-DA, Video CD formatted discs) for playback.
DVD-RAM disks are in plentiful supply on eBay, both new and used. Keep an eye open and you should pick them up, new, for less than £1 Sterling each!
I am unclear, though, what you mean about recording to and from the VCR. The DMR-E55 doesn't have a VCR facility, just DVD.
Jan 26, 2009 | Panasonic DMR-E55 DVD Recorder
Will my non finalzied discs play on a panasonic ez 28 or ex 768
You will have no problem playing your non finalized discs on any of the Panasonic DMR range including the DMR EZ28 series. The DMR E55 can also easily be repaired if you can use a soldering iron and a little care. Please checkout my other postings for full repair details.
Cheers...
Oct 08, 2008 | Panasonic DMR-E55 DVD Recorder
Panasonic dvd video recorder dmr-e55 user manual
http://service.us.panasonic.com/OPERMANPDF/DMRE55.PDF
Oct 13, 2007 | GoVideo Home Audio&Video: Go-Video DVD...
Panasonic DMR-E55 DVD Recorder Problem
I have been told that panasonic now have a faster speed disc on sale to suit the newer dvd recorders that dmr-e55 cannot record on as they are too fast. You have to buy the slower speed ram discs to suit the dmr-e55.
Aug 26, 2007 | Panasonic DMR-E55 DVD Recorder
Panasonic DMR-E55 DVD Recorder Logo
1,061 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
