My my samsung d900 bluetooth is not working well anymore. When I connect it to one of my headsets (hands free car kit or bluetooth headset), it connects well, but I can not hear anything through the headset. I can switch the audio to phone, and then I can hear through my phone. But when I switch again to the headset, nothing. The problem is that it works well sometimes and sometimes it doen't work. Can I do some kind of bluetooth upgrade that could solve this problem?
Please help, I just installed a new handsfree kit that cost me $250 and I can't use it!
Thanks
I have exactly the same problem. I have installed a new handsfree system in my car (5000$), and the D900-**** doesnt work from time to time. at the most time it doesnt work, but sometimes it works. I havent found any solutions on this problem. At the end of the day Im glad I have a HTC I can use. I have exactly the same problem. I have installed a new handsfree system in my car (5000$), and the D900-**** doesnt work from time to time. at the most time it doesnt work, but sometimes it works. I havent found any solutions on this problem. At the end of the day Im glad I have a HTC I can use.
You can't post conmments that contain an email address.
Connecting a Bluetooth headset or car kit
You can listen to
music over a Bluetooth stereo headset, or have hands-free conversations
using a compatible Bluetooth headset or car kit.
It's the same procedure to set up stereo audio and hands-free.
For you to listen to music with your headset or car kit, the headset or car kit must support the A2DP Bluetooth profile.
Before
you connect your headset, you need to make it discoverable so your
phone can find it. You can find out how to do this by referring to your
headset manual.
From the Home screen, press MENU, and then tap Settings > Wireless & networks.
Tap Bluetooth settings.
If the Bluetooth check box is not selected, select it to turn Bluetooth on.
Make sure that the headset is discoverable.
Tap Scan for devices.
Your phone will start to scan for Bluetooth devices within range.
When you see the name of your headset displayed in the Bluetooth devices section, tap the name.
Your phone then automatically tries to pair with the headset.
If automatic pairing fails, enter the passcode supplied with your headset.
The pairing and connection status is displayed below the hands-free headset or car kit name in the Bluetooth devices
section. When the Bluetooth headset or car kit is connected to your
phone, the Bluetooth connected icon is displayed in the status bar.
Depending on the type of headset or car
kit you have connected, you can then start using the headset or car kit
to listen to music and/or make and receive phone calls.
<span><span>Connecting a Bluetooth headset or car kit</span>
<span>
You can listen to
<ul>
<li>For you to listen to music with your headset or car kit, the headset or car kit must support the A2DP Bluetooth profile. </li>
<li>Before
headset manual. </li></ul>
<ol>
<li>
<span>From the Home screen, press <span>MENU</span>, and then tap <span><span>Settings</span> > <span>Wireless & networks</span></span>. </span>
</li>
<li>
<span>Tap <span>Bluetooth settings</span>. </span>
</li>
<li>
<span>If the <span>Bluetooth</span> check box is not selected, select it to turn Bluetooth on. </span>
</li>
<li>
<span>Make sure that the headset is discoverable. </span>
</li>
<li>
<span>Tap <span>Scan for devices</span>. </span>
</li>
<li>
<span>When you see the name of your headset displayed in the <span>Bluetooth devices </span>section, tap the name. </span>
</li>
<li>
<span>If automatic pairing fails, enter the passcode supplied with your headset. </span>
</li></ol>
The pairing and connection status is displayed below the hands-free headset or car kit name in the <span>Bluetooth devices</span> section. When the Bluetooth headset or car kit is connected to your phone, the Bluetooth connected icon is displayed in the status bar. Depending on the type of headset or car
</span></span>
You can listen to
Before
headset manual.
The pairing and connection status is displayed below the hands-free headset or car kit name in the Bluetooth devices section. When the Bluetooth headset or car kit is connected to your phone, the Bluetooth connected icon
To connect a bluetooth headset follow the below steps.
1.Switch on the bluetooth headset
2.Set your Bluetooth phone to discover the headset. ‘Settings,’ > ‘Connection’, or ‘Bluetooth’ menu on your phone and then selecting the option to discover Bluetooth devices.
3.Your phone will find the headset and ask if you want to pair with it. Confirm this by pressing the Yes or OK key.
hello switch the bluetooth on your phone go hands free if it has it click on hands free the press the button on the earpeice the phone should start searching for devices when it's found it it might say passcode enter
four 0000 thats it your connected good luck
Pairing: Press and hold until you see a solid blue light (approximately 8 sec) then release.
Search with your blue tooth phone for a bluetooth device and if finds samsung wep-150.
enter pass key or pin: 0000
