Question about Phonic PEQ3400 2x15-band Graphic Equalizer Home Equalizer
How to hook the eq up??
Yes i have a peq3400 dual 2/3octave eq and i want to hook it up to a peavey xr700cdual powered mixing console.how can i do this???
  • 682 Answers
Take output from left and right from equalizer and go to line in any two channels inputs in peavey mixing console and adjust your level with faders and other control knobs.
Posted on Mar 21, 2008
Is There A Way I Can Use This Power Mixer As A Power Amp For My Mixing Board?
There should be a line in for the power amp section, though you may prefer to patch in prior to the eq section so you can equalise the system and the room.
Apr 19, 2015 | Peavey XR 8300 8 Channel Powered Mixer
I have a peavey 1220 powered mixer and I'm trying to hook up to two sp15's top's and 2 18; peavey subs for my band and I can't get the bass seperated so it's out of my tops
Hi. The mixer puts out a full range mix, the solution is in your speaker setup.
Many subs have a built in crossover that splits the signal for the tops. Check your sub specs or manual. If your subs have this, run your output signal to them first and then link them to the tops from the special daisychain socket.
If they don't have one, you can install a passive crossover to your subs or buy an external crossover unit.
The last (and not very good) option is to fake a crossover with the desk's stereo EQ. Connect the subs to the left or right channel and the tops to the other and use the EQ to remove the bass from the tops and vice versa, pan everything dead center. Obviously this sacrifices your stereo sound and isn't brilliant.
Jun 29, 2011 | Peavey XR 1220 Powered Mixer Mixer Powered
My pv231 eq just stoped working, the led light is not coming on, what could be the problem? pls help!!
Most common problem is power cord works loose. Beyond that it may be a pwer supply failure.
Apr 13, 2011 | Peavey Pv231eq Dual 31 Band Graphic...
Can I hook up 2 separate power amps to PMP3000? I
Better way... Connect the main speakers via the Speakons and then put a Power Subwoofer to one of the Monitor connections IF you are not using both stage monitors. If you need to kill the lows to the mains, use the EQ in the PMP-3000.
Use the EQ that is USUALLY on the subwoofer to kill the highs to the sub.
Lot less cables and hardware.
REMEMBER for equipment safety, power ALL interconnected equipment from the same source be it a receptacle or power distribution system.
Powering parts of a system from receptacles strewn around a room is asking for trouble of ground loops and ground faults.
Apr 24, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Hello, Effects and EQ hook up problem
Many of those connections REQUIRE using TRS cables (stereo style) rather than TS cables (mono style). It is possible you have mixed the cables if it worked before.
Any cable plugged into an "insert" should be a TRS (tip-ring-sleeve) cable.
Look up these connections in your 1604 manual.
Feb 18, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
Run a sub woofer to a peavey board
I would recommend using a separate active crossover such as the Peavey 23XO and a separate amp for your subs.
Jun 20, 2009 | Peavey Pv 2600 Power Amplifier
Hooking up sound system
The RSQ player goes into the input section of the mixer.
The mixer effect send goes to the Quadraverb input and the output of the Quadraverb goes back to the effect in on the mixer. Now the Main out on the mixer goes to the EQ then the EQ goes to the compressor/limitor to power amp to speakers.
Apr 02, 2009 | Stanton Sa3 DJ Mixer With Eq System
Eq on channel a doesn't work on 2 units
It could be an internal ground connection on the EQ that's broken ( maybe inside the connector) ..I repaired numerous peavey products and broken grounds are common.
Feb 11, 2009 | Peavey EQ215FX Home Equalizer
363 people viewed this question
Top Phonic Audio Players & Recorders Experts
Greg Cann
Greg Cann
tom8341
Level 1 Expert
Are you a Phonic Audio Player and Recorder Expert? Answer questions, earn points and help others
