Question about Philips DVDR3320 DVD Recorder/VCR
Playing recorded DVDs on PC or other DVD player
Recorded DVD +RW or +R that I create on the Phillips recorder are not recognised/playable on my PC or other DVD recorders. I get the message "DVD not formatted, do I wish to format now" response. I've tried this in my home PC and office laptop and get the same response. Also friends are unable to play my recorded DVDs in their DVD players (not Phillips). Are recordings on the Phillips recorder captured in a perculair format that is only recognised by to Phillips DVD players?
  • Hartbox Aug 18, 2008
    For a while now I have been able to take a DVD recording, (from my Philips DVDR3305), and carry out a final edit, i.e. adding menus in the computer before finalising it.
    Just recently any DVD recordings that I have done, the PC is not recognising any content on the disc at all, I have two DVD recording drives in my PC:
    NEC DVD_RW ND-3550A
    HL-DT-ST DVD-RAM GSA-H54L
    When the disc loads I double-click My Computer and the content appears to be blank as if you have inserted a blank disc, I then take it back into the DVD recorder just to check that the disc still works, and it plays fine - I could finalise it at this stage but want to add some menus etc. before I do.
    Any ideas????
    Thanks
  • 476 Answers
Recordings from your DVD recorder should play on other DVD players as long as you finalize the recording on your recorder.
A PC should recognise an un-finalized, but only in a DVD writer drive.
There is a firmware upgrade available for this model. Follow this link and select your particular country version DVDR3320/XX
http://www.support.philips.com/support/html/index_gb_en.html#../~scripts/xsltransformsearch.asp?url=http://www.sms.philips.com/catalogue/list?sid=SMS||type=CONSUMER||locale=gb_en||mode=prod_text||item=dvdr3320v||page=1||show=50&xsl=search_result.xsl
Select Software & Drivers and click on the link to the zip file.
Follow the on-screen instructions.
Posted on Mar 02, 2008
DVDs recorded from VHS with Toshiba DVR670 will not play on any PC or DVD player
Possible that the format is not recognised or if a program needs to be installed into the PC for playback.
If the VHS was not compressed and then digitised , the format can be having errors and so is not playing. we need to cross check this out before we can confirm the error.
Please test with the recorded version on another PC and also try with another recorder.
Oct 05, 2011 | Toshiba DVR670 Player
Recorder works great but cannot play DVDs recorded from television on my computer. These recordings were made of several films over six hours on DVD-RW discs. I have Windows 7 and have tried all types...
Recordings made on DVD-RW discs cannot be played in other players, including many PC DVD-ROM drives; incompatible format. If you had recorded your TV/video material onto a DVD-R in the recorder, for example, then finalised the disc, it would work in your PC and any DVD player.
But since you used a re-writable video/data DVD, it won't work outside of the recorder - that's why you can't play it (or if it was written on your PC, your recorder won't read it - incompatible disc).
If you don't wish to finalise the RW disc (I don't recommend it - plus I wouldn't blame you for not wanting to do that), you could copy it from one recorder to another, unless your PC has a capture card - which allows the outputs of your DVD recorder to connect to the PC inputs. Using relevant DVD software (for example, ULead DVD factory), you may be able to 're-author' the contents of your recording, and create a DVD-R copy which WILL work in all players that way - use DVD-R (or DVD+R if your PC and other players allow that format) for 'permanent' video recording - use re-writable discs for backups, test recordings, temporary stuff, and PC data files. There are many inexpensive software programs available. Have a look sometime at your leisure. See what they are like.
Even if you could copy the DVD contents in a Windows program, regardless of the software used, there is no guarantee that the copy you make will work outside of the player and/or original recorder, because it would require a lot of time and effort to achieve, and unless you know what you're doing with the program, you could waste a lot of time (and blank discs) in the process - it only adds to the frustration.
I am glad to hear your recorder has no major faults at present - that's great. No expensive workshop repair cost headaches; just frustration with discs (especially if they become drink coasters).
DVD-RW is ideal for test video recordings and PC data, but is limited when it comes to compatible playback/usage outside of the device it was written/recorded on.
DVD+RW discs on the other hand, when titled/ top menu created, can be played on a PC or player without finalising. You can even direct copy a DVD+RW straight to a DVD-R - it works in most cases.
The upshot of this is you haven't lost anything, and with the exception of perhaps a few dollars for a pack of either DVD+RW, DVD+R, or DVD-R discs (any brand), it didn't cost a fortune. You can also retain any DVD-RW discs you have previously used.
The simplest and cheapest options are often the best ones.
Mar 24, 2011 | Panasonic DMR-ES10 DVD Recorder
I have dubbed vcr tape to a Sony DVD-RW disc and tried playing it back through a toshiba player and it keeps coming up Bad Disk. My PC won't even recognise it. When started dubbing the screen displayed 1hr...
Did you say you used a DVD-RW disc to transfer a videotape onto? The reason your PC won't recognise that disc is because the data format on it is a different language to what PCs understand - plus an unfinalised DVD-RW won't play in other DVD players - it is usually an incompatible format.
(DVD+RW discs with titles/top menus created in video mode CAN be played on a PC DVD drive or a normal DVD player as can finalised DVD-R discs (DVD-R discs MUST be recorded and finalised in the same recorder for compatible playback). DVD-RW discs can only be viewed on the unit they were written/recorded on.
The other reason for the 'remaining space' on the disc you describe showing less than 120 minutes is due to a title recently being recorded or erased - unless you format it - the 120 minute / 4.7GB DVD-RW will not show full available space. Erasing titles on re-writable DVDs does not increase space. The same rule applies to unfinalised +R / -R discs (you cannot re-format these to get the space back once recorded - they are 'once only' writables)
I recommend you invest in some DVD-R discs and re-copy your VHS tape to that - then if you are satisfied with the result, title etc., finalise the DVD-R - it will play on any DVD player or PC with DVD support (or it should). These discs are relatively inexpensive to buy just about anywhere.
Final note: do NOT finalise the DVD-RW you recorded (I hope you haven't already done this) - simply format/erase it - re-use it for something else or keep it until you need it.
You can use any brand of DVD, just take note of the format before recording/playing.
Mar 21, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I can't get my cd's I recorded on my sony dvd player
Check file extensions of files on your recorded cd's. Add file extension to Roxio, Windows Media player and check your drive settings.
Apr 22, 2009 | Sony DRU840A DVD-RAM Burner
Recorded discs wont play on an other dvd player
you have to finalise the disc when finished recording then it plays on any dvd player
Feb 15, 2009 | Philips DVDR3380/05 DVD Recorder
Hi
This is problem exactly with finalizing for finalizing after disk burning You need to press stop button and finalising menu will appear in your display at that time you need to press Record button top finalize it will take a little time for finalizing then your DVD will play fine in all DVD players
Thanks
T.Boopathy
Aug 23, 2008 | Philips DVDR3455H/37B
Dvd-r or dvd-rw discs not recognised
my computer not reconocing tha sofware of my camera, not open fails.disk of sofware is error help me please
Aug 12, 2008 | Sony Handycam DCR-DVD108 DVD Camcorder
Recording to DVDs to be compatible to play in other DVD players
Do U have a DVD RW player on Ur PC? Use a DVD R type to record/copy for a better chance to play on other DVD players.
Mar 30, 2008 | Computers & Internet
Zenith xbr411 DVD recorder
See the manual, page 8:
What are “Recording modes”? for DVD-RW
There are two recording modes available using this
recorder: VR mode and Video mode. When recording to
a DVD-R disc, recordings are always in Video mode.
DVD-RW discs can be formatted for VR mode recording
or Video mode recording.
VR mode recording
• 4 different picture quality/recording time settings available
(SP, LP, EP, XP)
• Not playable on regular DVD players
• Recordings can be extensively edited
• Total number of titles on the disc should be less than
99.
(SP, LP, EP, XP)
• Playable on regular DVD players (after finalizing)
• Limited editing features
99.
Note :
DVD-Video Format (Video mode) is a new format for
recording on DVD-R/RW discs that was approved by
the DVD Forum in 2000. You may therefore experience
problems playing recordable DVD discs in some players.
Symptoms include video artifacts, audio and/or
video dropouts and playback suddenly stopping.
Our company cannot take responsibility for problems
playing discs recorded on this VCR/DVD Recorder in
other players.
May 24, 2007 | Zenith XBR411 DVD Recorder/VCR
Philips DVDR3320 DVD Recorder/VCR Logo
289 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
